HP Notebook - 15-ac101ng (ENERGY STAR) Product Specifications
N9R55EA
Intel® Pentium® N3700 with Intel® HD Graphics (1.6 GHz, up to 2.4 GHz, 2 MB cache, 4 cores)
4 GB DDR3L SDRAM (1 x 4 GB)
Video Graphics
Intel HD Graphics
Hard Drive
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal FHD anti-glare WLED-backlit (1920 x 1080)
Display size (diagonal)
39.6 cm (15.6")
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo
External Ports
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
38.43 x 25.46 x 2.43 cm
2.19 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
VGA webcam (front-facing) with integrated digital microphone
DTS Studio Sound™ with 2 speakers
Windows 10 Home (64 bit)
HP Games by WildTangent; HP Lounge; HP 3D DriveGuard
Pre-installed software
Evernote; Netflix; Skype
