HP Pavilion Gaming Notebook - 15-ak021tx Product Specifications
T0X73PA
Intel® Core™ i7-6700HQ with Intel® HD Graphics 530 (2.6 GHz, up to 3.5 GHz, 6 MB cache, 4 cores)
Intel HM170
8 GB DDR3L SDRAM (1 x 8 GB)
Video Graphics
NVIDIA GeForce GTX 950M (4 GB DDR3L dedicated)
Hard Drive
2 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal FHD anti-glare WLED-backlit (1920 x 1080)
Keyboard
Island-style backlit keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 USB 2.0; 2 USB 3.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.45 x 26.51 x 2.88 cm
Starting at 2.32 kg
90 W AC power adapter
4-cell, 48 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY; Dual speakers
FreeDOS 2.0
