HP Notebook - 15-ac175ur (ENERGY STAR) Product Specifications
P3M21EA
Intel® Core™ i5-5200U with Intel HD Graphics 5500 (2.2 GHz, 3 MB cache, 2 cores)
4 GB DDR3L SDRAM (1 x 4 GB)
Video Graphics
AMD Radeon R5 M330 Graphics (2 GB DDR3 dedicated)
Hard Drive
2 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal HD BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
38.43 x 25.46 x 2.43 cm
2.19 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
VGA webcam (front-facing) with integrated digital microphone
DTS Studio Sound™ with 2 speakers
HP Lounge; HP 3D DriveGuard
Pre-installed software
Evernote; Skype
