    We are upgrading our website
HP Pavilion Notebook - 15-ab251ng (ENERGY STAR) Product Specifications
T1F52EA
Intel® Core™ i5-6200U with Intel® HD Graphics 520 (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB DDR3L SDRAM (1 x 8 GB)
Video Graphics
NVIDIA GeForce 940M (2 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal HD BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
38.45 x 26.11 x 2.52 cm
2.29 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY; Dual speakers
HP Games by WildTangent; HP Lounge; HP 3D DriveGuard
Pre-installed software
Evernote; Netflix; Skype
