HP ZBook Studio G3 Mobile Workstation Specifications
Product image
Product features
Feature
Preinstalled
Windows 10 Pro 64
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)
FreeDOS 2.0
Web supported
Windows 10 Enterprise 64
Windows 7 Enterprise 64
Not all features are available in all editions and versions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows functionality.
Processor
Intel Xeon E3-1545M v5 with Intel Iris Pro Graphics P580
Intel Xeon E3-1505M v5 with Intel HD graphics P530
(2.80 GHz, 2133 MHz, 8 MB L3 Cache, 4 Cores, 45W) Up to 3.70 GHz with Intel Turbo Boost Technology
Intel Core i7-6820HQ with Intel HD graphics 530
(2.70 GHz, 2133 MHz, 8 MB L3 Cache, 4 Cores, 45W) Up to 3.60 GHz with Intel Turbo Boost Technology
Intel Core i7-6700HQ with Intel HD graphics 530
(2.60 GHz, 2133 MHz, 6 MB L3 Cache, 4 Cores, 45W) Up to 3.50 GHz with Intel Turbo Boost Technology
Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. Performance and clock frequency will vary depending on application workload and your hardware and software configurations. Intel’s numbering is not a measurement of higher performance.
The Intel Turbo Boost is based on max GHz for a single core.
Intel Core i7 with Vpro/Xeon with VPro Technology Capable
Intel Core i7 with vPro and XEON with vPro technology is a selectable feature that is available on units configured with select processors, a qualified Intel Centrino WLAN module and a preinstalled Windows operating system. It provides advances in remote manageability, security, energy efficient performance, and wireless connectivity. Intel Active Management Technology (iAMT) offers built-in manageability and proactive security for networked mobile workstations, even when they are powered off* or when the operating system is inoperable. It can help identify threats before they reach the network, isolate infected systems, and update regardless of their power state.
Some functionality of Intel Core i5 with vPro/Core i7 with vPro/Xeon with vPro technology, such as Intel Active Management technology and Intel Virtualization technology, requires additional third- party software in order to run. Availability of future "virtual appliances" applications for Intel Core i5 with vPro/Core i7 with vPro/XEON with vPro technology is dependent on third- party software providers. Compatibility with future "virtual appliances" is yet to be determined.
Mobile Intel CM236
Graphics
Intel Integrated
Intel Iris Pro graphics P580 (Available 1H16)
Discrete
NVIDIA Quadro M1000M with 2 GB dedicated GDDR5 video memory
NVIDIA Quadro mobile professional graphics support up to four independent displays when using an HP ZBook Dock with Thunderbolt™ 3 (sold separately) or DisplayPort 1.2 hubs with MST.
Microsoft DirectX 12 (Shader Model 5.0) and OpenGL 4.4 capable
Support dual-display ports through optional docking station
Internal
Internal 15.6-inch diagonal LED-backlit FHD UWVA IPS eDP anti-glare + Panel Self Refresh (PSR) (1920 x 1080)
15.6- in diagonal UHD+ UWVA IPS LED anti-glare (3840 x 2160)
15.6 in diagonal UHD UWVA IPS LED anti-glare + Panel Self Refresh (PSR) Dreamcolor (3840 x 2160) (available in 1H16)
15.6 in diagonal Touch LED-backlit FHD UWVA IPS (1920 x 1080) (available in 1H16)
External
Up to 30-bit (2^30) per pixel "Deep Color"
(total of 1,073,741,824 color variations)
Storage and drives
HP Z Turbo Drives (NVMe PCIe SSD)
256 GB NVMe PCIe SSD
512 GB (NVMe) PCIe SSD
1 TB NVMe PCIe SSD
M.2 SATA SSD
128 GB SATA 6 Gb/sec SATA SSD
M.2 SATA SED SSD
256 GB SATA self encrypting drive (SED)
512 GB SATA self encrypting drive (SED)
Drive controllers
M.2 storage slots (SATA): SATA-3 for SSD
HP Z Turbo Drive: PCIe NVMe SSD
RAID: 0, 1 supported
Memory
Standard
32 GB DDR4 1.35 V ECC or Non-ECC SDRAM (Transfer rates up to 2133MT/s)
Two SODIMM slots supporting dual-channel memory
4 GB, 8GB and 16 GB SODIMMs (for Intel Core Processors)
8 GB and 16 GB ECC SODIMMs (for Intel XEON Processors)
Maximum
Upgradeable to 32768 MB with optional 16384 MB SODIMMs in 2 slots
Dual-channel
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory channels.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed.
Networking / communications
Communications
Integrated Intel I219-LM gigabit network connection
Wireless
Secure, integrated wireless LAN options featuring support for the latest industry standards. Integrated Bluetooth is also available (factory configurable only) and is combined with the supported wireless LAN feature.
802.11 wireless LAN options
Intel Dual Band Wireless-AC 8260 802.11 AC/a/b/g/n (2x2) Wi-Fi + Bluetooth 4.0 Combo Adaptor (vPro)
Intel Dual Band Wireless-AC 8260 802.11 AC/a/b/g/n (2x2) W-iFi + Bluetooth 4.0 Combo Adaptor (non-vPro)
The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Audio / multimedia
Audio
Bang & Olufsen HD audio integrated stereo speakers
Integrated microphone (dual-microphone array when equipped with optional webcam)
Button for volume mute; function keys for volume up and down
Combo microphone-in / stereo headphone-out jack
Optional 720p HD webcam
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30 fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Keyboards / pointing devices / buttons
Backlit keyboard with function key control to toggle backlit brightness setting - off/full/half brightness The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook. This helps reduce the risk of damage to sensitive components underneath. The 85-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, function keys, and 18.7 x 18.4 mm key pitch (center-to-center spacing). U.S. and International key layouts are available. Other features include hot keys for instant access to power conservation and brightness.
Pointing Device
Large clickpad with On/Off button, two-way scroll, gestures, two integrated buttons within clickpad surface
Image sensor clickpad for enhanced performance and improved precision on scroll and gesture
Buttons and Function Keys
Separate launch buttons provide easy access to the following features: wireless on/off, volume mute. Function keys provide control of the following features: standby mode, external display, volume down, volume up, and display brightness.
Power
Power supply: External HP 150W Slim Smart AC adapter 153 x 66 x 22 mm (6 x 2.6 x 0.9 in)
Primary battery: HP Long Life 4-cell Prismatic Battery (64 WHr)
Power conservation:
NVIDIA Optimus
Hibernation
Standby
ACPI compliance
Ports/slots
Specification
Ports and slots
Left side:
(1) RJ-45 (Ethernet)
(1) USB 3.0 charging port
(1) USB 3.0
(1) Security lock slot
Right side:
(1) Power connector
(2) Thunderbolt 3 (supporting DP 1.2, USB 3.1 Gen2, PCIe Gen 3 devices)
(1) HDMI
(1) USB 3.0
(1) Stereo microphone in / headphone-out combo jack
Thunderbolt 3
Thunderbolt 3 ports supports DisplayPort 1.2, USB 3.1 Gen 2, and PCIe Gen 3 devices over the new USB-C port connector. The port is compatible with existing DisplayPort displays, devices, and cables. Install all the latest drivers for your Thunderbolt device before connecting the device to the Thunderbolt port. Thunderbolt cable and Thunderbolt device (sold separately) must be compatible with Windows.
SD Media Reader Slot Supports SD, SDHC, SDXC
Digital media slots
(1) SD UHS-II Flash Media slot – supports next generation SD (Secure Digital), backward compatible to SDHC, SDXC)
System Unit
Specification
Stand-alone power requirements (AC power)
Nominal operating voltage: 19.5 V
Average operating power: DreamColor - 25 W (Windows 7 64-bit)
Without DreamColor - 16.8 W (Windows 7 64-bit)
Max operating power: < 200 W
Temperature
Operating: 0° to 35° C (32° to 95° F)
Non-operating: -20° to 60° C (-4° to 140° F)
Relative humidity
Operating: 10% to 90% (non-condensing)
Non-operating: 5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating: 400 g, 2 ms, half-sine
Non-operating: 200 g, 2 ms, half-sine
Random vibration
0.75 grms
1.5 grms
Altitude
Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Industry standard certifications
UL
CSA
FCC compliance
ENERGY STAR: select models
EPEAT: gold
ICES: planned
Australia / NZ A-Tick compliance: planned
CCC: planned
Japan VCCI compliance: planned
KC: planned
BSMI: planned
CE marking compliance: planned
MIL STD 810G: planned
Displays
Specification
15.6 in diagonal LED-backlit FHD UWVA IPS eDP anti-glare + Panel Self Refresh (PSR) (1920 x 1080)
Active area: 34.4 x 19.4 cm (13.54 x 7.59 in)
Weight: 360 g
Surface treatment: AG
Contrast ratio: 600:1 (typ) - AG
Refresh rate: 60 Hz
Brightness: 300 nits
Pixel resolution:
Format
Configuration
1920 x 1080 (FHD)
RGB stripe
Backlight: LED
PPI: 141
Viewing angle: 85/85/85/85 (Left/Right/Down/Up) (typical)
15.6 in UHD UWVA IPS LED anti-glare (3840 x 2160)
Active area: 34.4 mm x 19.4 (13.54 x 7.59 in)
Dimensions : 39.6 cm (15.6 in)
Weight: 380 g
Contrast ratio: 400:1 (typ) - AG
Refresh rate: 60 Hz
Pixel resolution:
Format
Configuration
1920 x 1080 (FHD)
RGB stripe
Backlight: LED
PPI: 141
15.6 in UHD+ UWVA IPS LED anti-glare + Panel Self Refresh (PSR) Dreamcolor (3840 x 2160)
Dimensions : 34.6 x 19.4 cm (13.62 x 7.59 in )
Diagonal size: 39.6 cm (15.6 in)
Weight: 345 g
Contrast ratio: 1000:1 (typ) - AG
Refresh rate: 60 Hz
Brightness: 340 nits
Pixel resolution:
Format
Configuration
3840 x 2160 (FHD)
RGB stripe
Backlight: LED
PPI: 282
Storage/drives
128 GB M2 2280 SATA-3 TLC solid state drive
Drive weight
8.5 - 10 g (0.02 - 0.02 lb)
Capacity
128 GB
Height
2.23 - 3.58 mm (0.09 - 0.14 in)
Width
22 mm (0.87 in)
Interface
ATA-8, SATA 3.0
Performance
Maximum sequential read: up to 540 MB/s
Maximum sequential write: up to 300 MB/s
Logical blocks
250,069,680
Operating temperature
0° to 70° C (32° to 158° F) (ambient temperature)
Security features
ATA security, DIPM; TRIM; DEVSLP
256 GB 2280 SATA-3 self-encrypting drive (Opal 2) MLC solid state drive
Drive weight
< 10 g (0.02 lb)
Capacity
256 GB
Height
2.3 - 3.58 mm (0.09 - 0.14 in)
Width
22 mm (0.87 in)
Interface
ATA-8, SATA 3.0
Performance
Maximum sequential write: up to 460 MB/s
Logical blocks
500,118,192
HP Z turbo drive 256 GB, M.2 NVMe PCIe solid state drive
Drive weight
< 10 g (0.02 lb)
Capacity
256 GB
Height
2.3 mm (0.09 in)
Width
22.1 mm (0.87 in)
Generation
SM951 NVMe
NAND type
MLC
Form-factor (I/O)
M.2 2280
Interface
PCIe GEN3X4
Performance
Maximum sequential read: up to 2260 MB/s
Maximum sequential write: up to 1260 MB/s
Logical blocks
500,118,192
Security features
ATA Security; TRIM; L1.2
HP Z turbo drive 512 GB, M.2 NVMe PCIe solid state drive
Drive weight
10 g (0.02 lb)
Capacity
512 GB
Height
3.7 mm (0.14 in)
Width
22 mm (0.87 in)
Generation
SM951 NVMe
NAND type
MLC
Form-factor (I/O)
M.2 2280
Interface
PCIe GEN3X4
Performance
Logical blocks
1,000,215,216
Security features
Security
HP fingerprint sensor
Mobile voltage operations
3.0 V - 3.6 V
-10° – 75° C (14° – 167° F)
Current consumption image
36 mA peak
Low latency wait for finger
950 uA
Capture rate
3000 lines/sec
ESD resistance
IEC 61000-4-2 4B (±15KV)
Detection matrix
200*1 (plus another secondary line)
508 dpi
12*3 mm sensor area
Networking/communications
Specification
Ethernet features
10 Mbit/s operation (10BASE-T; IEEE 802.3; IEEE 802.3 clauses 13-14)
100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
1000 Mbit/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023. Clauses 40)
IEEE 802.3u auto-negotiation (automatic speed selection)
Full duplex operation at all speeds, half duplex operation at 10 and 100 Mbit/s
IEEE 802.1p QoS (Quality of Service) support
IEEE 802.1q VLAN support
IEEE 802.3x flow control (IEEE 802.3 clauses 31-32; configurable)
EEE 802.3az EEE (Energy Efficient Ethernet)
IEEE 802.1as/1588 conformance
Jumbo frame 9K
Auto MDI/MDIX Crossover cable detection
Power management
ACPI compliant - multiple power modes
Energy Detect Low Power Mode(Green Ethernet)
Performance
TCP/IP/UDP Checksum Offload (configurable)
Features
Protocol Offload( ARP & NS)
Large send offload and Giant send offload
Receiving Side Scaling
MACSec Offload (802.3ae)
Intel vPro
iSCSI Boot
RSS (Receive Side Scaling)
Ultra Low Power
Manageability
Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft
Wake-Up Frame); Wake-on-LAN from off (Magic Packet only)
PXE 2.1 remote boot
Statistics gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
Comprehensive diagnostic and configuration software suite
Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NOTE: Intel I219-LM Gigabit interface is not PCIe compliant. It operates at half of PCIe specification V1.1 (2.5GT/S) speed.
NIC device driver name
Intel Ethernet Network Connection I219-LM
Intel dual band wireless-N 8260AC 802.11 AC/a/b/g/n (2x2) Wi-Fi + Bluetooth 4.0 combo adaptor (vPro)
Specification
Wireless LAN Standards
IEEE 802.11a
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
IEEE 802.11ac
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
  • 2.40 – 2.48 GHz
Note: The FCC has declared as of January 1, 2015 products that utilize passive scanning on channel 12/13 and are capable of transmitting must fully comply with requirements of 15.247 or otherwise disable those channels.
802.11a/n
  • 4.9 – 4.95 GHz (Japan)
  • 5.15 – 5.25 GHz
  • 5.25 – 5.35 GHz
  • 5.47 – 5.73 GHz
  • 5.825 – 5.85 GHz
Indonesia only supports 5.73 - 5.83 GHz (CH149 - CH161)
Data rates
802.11b: 1, 2, 5.5, 11 Mbps
802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
802.11a: 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
802.11n: MCS 0 ~ MCS 15, (20MHz, and 40MHz)
802.11ac : MCS0 ~ MCS9, (1SS, and 2SS) (20MHz, 40MHz, and 80MHz)
Modulation
Direct Sequence Spread Spectrum
BPSK, QPSK, CCK, 16-QAM, 64-QAM, 256-QAM
Security
IEEE and Wi-Fi compliant 64 / 128 bit WEP encryption for a/b/g mode only
AES-CCMP: 128 bit in hardware
802.1 x authentication
WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
WPA2 certification
IEEE 802.11i
Cisco Certified Extensions, all versions through CCX4 and CCX Lite
WAPI
Network architecture
Ad-hoc (peer to peer)
Roaming
IEEE 802.11 compliant roaming between band access points
Output power
802.11b: +16 dBm minimum
802.11g: +14 dBm minimum
802.11a: +14 dBm minimum
802.11n HT20 (2.4 GHz): +14 dBm minimum
802.11n HT40 (2.4GHz): +12 dBm minimum
802.11n HT20 (5GHz): +14 dBm minimum
802.11n HT40 (5GHz): +12 dBm minimum
Maximum power consumption
Transmit: 2 watts (max)
Receive: 1.6 watts (max)
Idle mode(PSP): 180 mW (WLAN associated)
Idle mode: 50 mW (WLAN unassociated)
Connect standby: 10mW (WLAN+BT)
Radio disabled: 5 mW
Power management
ACPI and PCI Express compliant power management
802.11 compliant power saving mode
Receiver sensitivity
802.11b, 1 Mbps: -94 dBm maximum
802.11b, 11 Mbps: -86 dBm maximum
802.11g, 6 Mbps: -88 dBm maximum
802.11g, 54 Mbps: -74 dBm maximum
802.11a, 6 Mbps: -88 dBm maximum
802.11a, 54Mbps: -74 dBm maximum
802.11n, MCS07: -69 dBm maximum
802.11n, MCS15: -66 dBm maximum
802.11ac, 1SS, MCS-0: -86 dBm maximum
802.11ac, 1SS, MCS-9: -61 dBm maximum
802.11ac, 2SS, MCS-0: -83 dBm maximum
802.11ac, 2SS, MCS-9: -58 dBm maximum
Antenna type
High efficiency antenna with spatial diversity, mounted in the display enclosure
Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications
Form factor
PCI-Express M.2 MiniCard
Dimensions
Type 2230: 2.3 x 22 x 30 mm
Type 1630: 2.3 x 16 x 30 mm
Type 2230: 2.8g
Type 1630: 2g
Operating voltage
3.3 v +/- 9 %
Temperature
Operating: -10° to 70° C (14° to 158° F)
Non-operating: -40° to 80° C (-40° to 176° F)
Humidity
Non-operating: 5% to 95% (non-condensing)
Altitude
Operating: 3,048 m (0 to 10,000 ft)
Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
LED Amber - Radio OFF; LED White - Radio ON
HP integrated module with Bluetooth 4.0/4.1/4.2 wireless technology
Bluetooth specification
4.0/4.1/4.2 compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency band
2402 to 2480 MHz
Number of available channels
Legacy 0-79 (1 MHz) available channels
BLE: 0-39 (2 MHz/CH)
Data rates and throughput
BLE : 1 Mbps data rate; throughput up to 0.2 Mbps Legacy : Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
Legacy : Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric (3-DH5) or 864 kbps symmetric (3-EV5)
Transmit power
The Bluetooth component operates as a Class II Bluetooth device with a maximum transmit power of +4 dBm for BR and EDR.
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Selective Suspend 17 mW
Range
Legacy up to 10 m (33 ft)
BLE Up to 30 m (99 m)
Electrical interface
USB 2.0 compliant
Bluetooth software supported
Microsoft Windows Bluetooth Software
Link topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Self-configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Security certifications
Full support of Bluetooth Security Provisions
Power management
Microsoft Windows ACPI, and USB Bus Support
Certifications
UL, CSA, and CE Mark
FCC (47 CFR) Part 15C, Section 15.247 & 15.249
ETS 300 328, ETS 300 826
Low Voltage Directive IEC950
File Transfer Profile (FTP)
Synchronization Profile (SYNC)
FAX Profile (FAX)
Basic Imaging Profile (BIP)
Headset Profile (HSP)
Hands Free Profile (HFP)
Bluetooth profiles supported
Serial Port Profile (SPP)
Service Discovery Application Profile (SDAP)
Dial-Up Networking (DUN)
Generic Object Exchange Profile (GOEP)
Object Push Profile (OPP)
Hard Copy Cable Replacement (HCRP)
Personal Area Networking Profile (PAN)
Human Interface Device Profile (HID)
Advanced Audio Distribution Profile (A2DP)
Audio Video Remote Control Profile (AVRCP)
Bluetooth V4.1/V4.2 support feature
V4.1: ESR5/6/7 compliant
V4.2: ESR8 compliant, LE Secure Connection – Basic
Intel dual band wireless-N 8260AC 802.11 AC/a/b/g/n (2x2) Wi-Fi + Bluetooth 4.0 combo adaptor (non-vPro)
Specification
IEEE 802.11a
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
IEEE 802.11ac
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
  • 2.40 – 2.48 GHz
802.11a/n
  • 5.15 – 5.25 GHz
  • 5.25 – 5.35 GHz
  • 5.47 – 5.73 GHz
  • 5.825 – 5.85 GHz
Data rates
Modulation
Security
WPA2 certification
IEEE 802.11i
WAPI
Network architecture models
Infrastructure (Access Point Required)
Roaming
Output power
Idle mode (PSP): 180 mW (WLAN associated)
Power management
Antenna type
Form factor
Dimensions
Type 2230: 2.8g
Type 1630: 2g
Operating voltage
3.3 v +/- 9 %
Temperature
Humidity
Altitude
LED activity
Audio/multimedia
Bang & Olufsen
Implementation:
Conexant CX7501
Function key volume controls:
Volume up, volume down, and mute
Full duplex:
Yes
Microphone in:
Stereo
Headphone/line out:
Stereo
Integrated microphone:
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Frequency response:
20 Hz - 20 kHz
Signal to noise ratio:
106dB (DAC), 102dB (ADC)
Total harmonic distortion:
91dB THD+n on LineOut/HP (0.003%)
Noise floor:
-110 dB
Play Sampling Rate(s)
Up to 192 kHz
Record Sampling Rate(s)
Up to 96 kHz
DAC:
16, 20, or 24-bit
ADC:
16, 20, 24-bit
Integrated stereo speakers
Power rating:
1 watt
Impedance:
4 ohms
Power
HP 45W smart AC adapter
Dimensions (H x W x D)
153 x 66 x 22 mm (6.02 x 2.60 x 0.87 in )
165 g (748 g)
Input
100 to 240 VAC
Input Efficiency:
87% min at 115 VACC
Input frequency range:
47 to 63 Hz
Input AC current:
2.9 A at 90 VAC, 1.45 A at 180 VAC
Output
Output power:
200 W
DC output:
19.5 V
Hold-up time:
5 msec at 115 VAC input
Output current limit:
<16A, over voltage protection -29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
Operating temperature:
0° to 40° C (32° to 104° F)
Non-operating (storage) temperature:
-20° to 65° C (-4° to 149° F)
Altitude:
0 to 3,048 m (0 to 10,000 ft)
Humidity:
20% to80%
Storage humidity:
10% to 90%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives
Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE
MTBF - over 200,000 hours at 25°C ambient condition
HP long life 4-cell prismatic battery (64 WHr)
Dimensions
0.74 x 8.5 x 25.8 cm (0.29 x 3.35 x 10.2 in)
315 g
Cells/Type
4-cell; prismatic
Energy
Voltage: 15.2 V
Amp-hour capacity: 4.21 Ah
Watt-hour capacity: 64 Wh
Temperature
Operating (charging):
0° to 45° C (32° to 113° F)
Operating (discharging):
Non operating:
Battery re-charge time
System in OFF or standby mode: 3 hr
System ON: 3 to 5 hr
Fuel gauge LED
No
3 yr
3 yr platform warranty is required for a 3 yr Long Life Battery warranty
Physical specifications
Specification
Starting at 2 kg (4.4 lb)
Dimensions (W x D x H)
375 x 255 x 18 mm (14.76 x 10.04 x 0.71 in)
Software and security
BIOS
HP BIOSphere
Available only on business PCs with HP BIOS.
HP SureStart
HP DriveLock, HP Automatic DriveLock
HP BIOS protection
May require a manual recovery step if all copies of BIOS are compromised or deleted.
BIOS update via network
Master boot record security
Power on authentication
Pre-boot security
Secure erase
For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88.
Hybrid boot
Measure boot
Secure boot
Absolute Persistence Module
Absolute agent is shipped turned off, and will be activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Pre-boot authentication
Multimedia
Cyberlink Power DVD, BD
Cyberlink YouCam BE (Windows 7 only)
Communication
HP GPS and Location (Windows 7 only)
GPS access requires an unobstructed path to multiple satellites. Performance may be affected if/when used inside of buildings, bridges or heavily congested metropolitan areas. Requires separately purchased GPS navigation software available from multiple GPS applications.
HP Connection Manager with support for HP Mobile Connect (Windows 7 only)
HP Mobile Connect Pro (Windows 8.1 and later)
Intel Wireless Display (WiDi) Software for Windows 7
Native Miracast support
Miracast is a wireless technology your PC can use to project your screen to TVs, projectors, and streaming media players that also support Miracast. You can use Miracast to share what you’re doing on your PC and present a slide show.
HP value add software
HP 3D DriveGuard
HP ePrint Driver
Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees may apply. Print times and connection speeds may vary.
HP Hotkey
HP Recovery Manager
HP Recovery Disc Creator
HP Registration App (Windows 8.1 only)
HP Support Assistant
HP Noise Reduction Software
HP Performance Advisor
HP Remote Graphics Software
HP Velocity
3rd Party
Foxit PhantomPDF Express for HP
Microsoft products
Buy Office
Bing search
Skype
Skype is not offered in China.
Manageability
HP Driver Packs
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM)
HP BIOS Config Utility (BCU)
HP Client Catalog
HP CIK for Microsoft SCCM
LANDESK Management (subscription required)
Client security software
HP Security Manager
Microsoft Security Essentials
Opt in and internet connection required for updates.
Microsoft Defender
Standard
TPM 1.2/2.0
HP fingerprint reader
Other standard security features
One-step logon
Security lock slot
Support for Intel AT
Optional security features
HP Fingerprint Sensor (optional)
Absolute Data Protect with GPS Tracking - subscription based security solution providing the ability to track, initiate physical recovery, conduct asset management, and perform remote data delete by utilizing GPS technology. GPS functionality requires HP Mobile Broadband Module.
The Absolute Data Protect is shipped turned off, and must be activated by customers when they purchase a subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S.
HP Central Management
HP offers a variety of scalable hardware, software, and BIOS-based security features to help you defend your organization against viruses and other threats. These integrated security features safeguard what matters to you the most - your data, device and identity. Now, be confident your fleet of devices is protected in multiple layers of HP Client Security protection. HP BIOS Protection keeps you up and running with enhanced protection against virus attacks and other threats. And if the BIOS is accidently compromised, the auto recovery feature automatically restores it to its fully functional state. HP Sure Start detects and negates a BIOS attack with automatic recovery of the BIOS even when the installation is accidentally compromised (i.e. power outage). When HP Sure Start heals the BIOS an event log is generated that an IT administrator can retrieve so the business is aware of a BIOS attack. Golden copy of BIOS is stored in protected nonvolatile memory providing redundant, hardware-based protection against a new generation of attacks. This helps to future-proof your technology and business. An optional fingerprint reader to help keep your identity secure. The security cable slot helps keep your notebook physically secure. You can even permanently destroy data on your hard drive in preparation for your system disposal or redeployment with Secure Erase.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Environmental specifications
Eco-label certifications
US ENERGY STAR
IT ECO declaration
EPEAT
System configuration
The configuration used for the energy consumption and declared noise emissions data for the commercial notebook model is based on a "typically configured notebook"
Energy consumption
Mode
115 VAC
230VAC
100VAC
Normal operation
16.64 W
16.78 W
15.87 W
Sleep (ENERGY STAR low power mode)
1.01 W
1.07 W
1.01 W
Off
0.31 W
0.34 W
0.31 W
Energy efficiency data listed is for an ENERGY STAR compliant product if offered within the model family. HP computers marked with the ENERGY STAR Logo are compliant with the applicable U.S. Environmental Protection Agency (EPA) ENERGY STAR specifications for computers. If a model family does not offer ENERGY STAR compliant configurations, then energy efficiency data listed is for a typically configured PC featuring a hard disk drive, a high efficiency power supply, and a Microsoft Windows operating system.
Heat dissipation
Mode
115 VAC
230VAC
100VAC
Normal operation
57 BTU/hr
57 BTU/hr
54 BTU/hr
3 BTU/hr
4 BTU/hr
3 BTU/hr
Off
1 BTU/hr
1 BTU/hr
1 BTU/hr
Declared noise emissions (in accordance with ISO 7779 and ISO 9296)
System fan off
Sound power (LWAd, bels)
Sound pressure (LpAm, decibels)
Typically configured - idle
2.9
23
Fixed disk – random writes
2.9
23
Batteries
This battery(s) in this product comply with EU Directive 2006/66/EC
Batteries used in the product do not contain:
Mercury greater the 5ppm by weight
Cadmium greater than 10ppm by weight
Battery size: CR2025 (coin cell)
Battery type: lithium
Battery size: 6-cell high capacity lithium-Ion battery (optional 8 cell available)
Service and support
Limited 3-year or 1-year limited warranty options available, depending on country. Batteries have a default one year limited warranty except for Long Life batteries which will have same 1-year or 3-year limited warranty as the platform. Optional1 HP Care Pack Services are extended service contracts which go beyond your standard limited warranties.
