HP Pavilion x360 - 13-s103nf (ENERGY STAR) Product Specifications
P5Q01EA
Intel® Core™ i3-6100U with Intel® HD Graphics 520 (2.3 GHz, 3 MB cache, 2 cores)
6 GB DDR3L SDRAM (1 x 2 GB, 1 x 4 GB)
Video Graphics
Hard Drive
1 TB 5400 rpm SATA
33.8 cm (13.3") diagonal HD IPS WLED-backlit touch screen (1366 x 768)
Display size (diagonal)
33.8 cm (13.3")
Keyboard
Full-size island-style keyboard
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
32.74 x 22.36 x 2.25 cm
1.71 kg
45 W AC power adapter
3-cell, 48 Wh Li-ion prismatic
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY with 2 speakers
HP Games by WildTangent; HP Lounge; HP 3D DriveGuard
Pre-installed software
Evernote; Netflix; Skype
