Document ID: c04821882
Version: 1
Advisory: HP Pro Tablet 608 G1 - Volume Control Buttons Do Not Work After Upgrade to Windows 10
Release date : 30-Sep-2015
Last updated : 30-Sep-2015
DESCRIPTION
The volume control buttons do not work and the Windows Device Manager indicates a problem with HID Button over Interrupt Driver (has Yellow Triangle with Exclamation Mark) after upgrading from Windows 8.1 to Windows 10.
SCOPE
Systems:
Operating Systems:
Microsoft Windows 10 Pro (64-bit)
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
HP Notebook System BIOS Update
Version: 01.05
Revision: A Pass: 1
NOTE: A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
Hardware platforms affected : HP Pro Tablet 608 G1
Support Communication Cross Reference ID : IA04821882
