HP EliteDesk 800 35W G2 Desktop Mini PC Specifications
Product image
Audio specifications
Specification
Type
Integrated
HD stereo codec
Realtek 2-channel ALC221 codec
Audio I/O ports
Front microphone-in (150-K ohm input impedance)
Rear Line-In/Microphone input (150-K ohm input impedance, function is configurable by audio driver)
Rear Line-Out (190 ohms Output Impedance, expects at least a 10-K ohm load)
Front Headphone-Out (0.5 Ohm Output Impedance, expects at least a 32 ohm load) Front Microphone/Headphone jack is re-task able to provide Microphone input, line-in or Headphone output to support connecting two headphones to the front of the system. When configured as a second front headphone output, both front headphone outputs are always driven with the same signal.
All ports are 3.5 mm
Internal speaker amplifier
1.5 W amplifier for the internal speaker only. External speakers must be powered externally. Rear Line-in audio port is re-taskable as either Line-in or Microphone-in.
Multi-streaming capable
Multi-streaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to and from the front and rear jacks.
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes - Uses OS soft wavetable
Analog audio
Yes
Number of channels on line-0ut
Stereo (Left and right channels)
Internal speaker
Yes
External speaker jack
Yes
Input/output devices
HP Conferencing Keyboard
Specification
Physical characteristics
Keys
110 (US) Layout, 111 (EU) Layout – depending upon country
Dimensions (L x W x H)
2.16 x 44.05 x 15.50 cm (0.85 x 17.34 x 6.10 in)
700 g (24.69 lb)
Connectivity
USB cable
Feature summary
Full-size ultra-quiet keyboard with numerical pad and 12 function keys
One-touch simplicity for Microsoft Lync or Skype for Business calls with dedicated keys and LED light indicators
Illuminated keys
Incoming call – Blinks Green
Call in progress –Green
Microphone mute – Orange
Audio mute – Orange
Screen sharing – Orange
Stop webcam – Orange
Other call control keys
End/decline Call
Volume up and down rocker key
Microsoft Lync / Outlook
Fn+F12 – Lync or Skype for Business Calendar will open. If Lync or Skype for Business is not available will bring Outlook Calendar
Fn+F11 – Lync or Skype for Business Contact will open. If Lync or Skype for Business is not available will bring Outlook Contact list
* Fn+11 and Fn+12 function keys are not supported in Microsoft Windows 8.x Metro mode
Functions keys
Fn+F10 – System settings
Fn+F9 – Devices
Fn+F8 – Search
Fn+F7 – Blank
Fn+F6 – Up brightness adjustment
Fn+F5 – Down brightness adjustment
Fn+F4 – Display options
Fn+F3 – File explorer
Fn+F2 – System lock
Fn+F1 – System sleep
System requirements
Available USB port
Windows 7, Windows 8.x, and Windows 10
Server: Microsoft Lync Server 2010 or 2013 and Skype for Business Server 2015
Client: Microsoft Lync 2013 version 15.0.46xx or newer or Skype for Business
Limited support for Microsoft Lync 2010, Microsoft Lync 2013 Basic and Microsoft Metro Mode
Screen brightness functions supported in select HP systems
Approvals EMC product safety
FCC; CE; ACA (C-tick); EAC, UL, CE Mark
HP USB Business Slim Keyboard
Specification
Keys
104, 105, 106, 107, 109 layout (depending upon country)
436.8 ± 1.5 x 137.6 ± 1.0 x 21.0 ± 1.0 cm (171.97 x 68.35 x 8.27 in)
0.6± 0.08 kg (1.32 lb) minimum
Electrical
Operating voltage
+ 4.4 – 5.25 VDC
Power consumption
50 mA maximum (with 5 VDC power supplied and three LEDs ON)
System interface
USB Type A plug connector
ESD
Contact discharge: 2, 4,6,8 KV
Air discharge: 2, 4, 8,10,12.5 KV
EMI - RFI
Conforms to FCC rules for a Class B computing device
Microsoft PC 99 - 2001
Functionally compliant
Mechanical
Keycaps
Low-profile design
Switch actuation
60 ± 12.5 g nominal peak force with tactile feedback
Switch life
10 million keystrokes (Life tester)
Switch type
Contamination-resistant switch membrane
Key-leveling mechanisms
For all double-wide and greater-length keys
Cable length
1.8 m (6 ft)
Mechanically compliant
Environmental
Acoustics
43 dBA maximum sound pressure level
Temperature
Operating: 10° to 50° C (50° to 122° F)
Non-operating: -30° to 60° C (-22° to 140° F)
Humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 20% to 80% (non-condensing at ambient)
Shock
Operating: 40 g, six surfaces
Non-operating: 80 g, six surfaces
Vibration
Operating: 2 g peak acceleration
Non-operating: 4 g peak acceleration
Drop (out of box)
66 cm (26 in) on carpet, six-drop sequence
Drop (in box)
76.2 cm (30 in) on concrete, 16-drop sequence
Approvals
UL, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, KC
Ergonomic compliance
ANSI HFS 100, ISO 9241-4, and TUVGS
Kit contents
Keyboard
Installation guide
Warranty card
Safety and comfort guide
HP PS/2 Keyboard
Specification
Keys
46.28 x 16.43 x 2.79 cm (18.22 x 6.47 x 1.1 in)
0.9 kg (2 lb) minimum
Electrical
Operating voltage
+ 5 VDC ± 10%
Power consumption
50 mA maximum (with three LEDs ON)
System interface
PS/2 6-pin mini din connector
ESD
CE level 4, 15 kV air discharge
EMI - RFI
Mechanical
Keycaps
Low-profile design
Switch actuation
55 g nominal peak force with tactile feedback
Switch life
20 million keystrokes (using Hasco modified tester)
Switch type
Cable length
1.8 m (6 ft)
Environmental
Acoustics
50 dBA maximum sound pressure level
Temperature
Operating: 0° to 40° C (32° to 104° F)
Non-operating: -30° to 65° C (-22° to 149° F)
Humidity
Operating: 15% to 80% (non-condensing at ambient)
Non-operating: 15% to 90% (non-condensing at ambient)
Shock
Operating: N/A
Non-operating: 65 in 2.9 ms, six surface; 30g 266 inch/second; 50 g 266 inch/second six surface
Vibration
Non-operating: Starting at 5 Hz, vary the frequency of vibration from 5 to 500 Hz and back to 5 Hz at a Logarithmic sweep rate of 1 octave per minute.
Drop (out of box)
Drop (in box)
76 cm (29.93 in) on concrete, 16-drop sequence
Approvals
CUL, ICES-003 Class B, FCC, CE Mark,TUV GS, VCCI, BSMI, C-Tick, KC
HP PS/2 Business Slim Keyboard
Specification
Keys
436.8 ± 1.5 x 137.6 ± 1 x 21.0 ± 1 cm (171.97 x 68.35 x 8.27 in)
600 ± 80 g (1.32 lb)
Electrical
Operating voltage
+ 4.4 – 5.25VDC
Power consumption
System interface
ESD
Contact discharge: 2, 4,6,8KV
Air discharge: 2, 4, 8,10,12.5KV
EMI - RFI
Mechanical
Keycaps
Low-profile design
Switch actuation
Switch life
Switch type
Cable length
1.8 m (6 ft)
Environmental
Acoustics
Temperature
Operating:
Non-operating:
Operating humidity
Operating:
Non-operating:
Operating shock
Operating:
N/A
Non-operating:
65 inch 2.9 ms, six surface; 30 g 266 inch/second; 50 g 266 inch/second six surface
Operating vibration
Operating:
Non-operating:
Drop (out of box)
Drop (in box)
Approvals
HP Wireless Business Slim Keyboard and Mouse
Specification
Keyboard
Dimensions (H x L x W)
436.8 ± 1.5 x 137.6 ± 1 x 21 ± 1 cm (171.97 x 68.35 x 8.27 in)
Weight - without two AA Alkaline batteries
560 ± 80 g (1.23 lb)
Mouse
37 x 115 x 62.9 mm (1.46 x 4.53 x 2.47 in)
67 g (0.15 lb)
Receiver
8.4 x 45.5 x 18.4 mm (0.33 x 1.79 x 0.72 in)
5.9 g (0.21 oz)
Cable length - minimum
1.8 m (6 ft)
Range
10 m (32.8 ft)
System requirements1
Available USB port for the receiver
CD-ROM Drive
This system may require upgraded and/or separately purchased hardware and/or a DVD drive to install the Windows 7 software and take full advantage of Windows 7 functionality. See http://www.microsoft.com/windows/windows-7/ for details.
Approvals
Product safety
UL; CSA /TUV (Europe only); CE Mark; CB Report
Ergonomics
ANSI; ISO (Europe only); GS Mark (Germany only)
EMC
FCC; CE; ACA (-tick); BSMI; KC ; VCCI
CE mark
EN 55022:2010; EN 55024; EN 301489-1; EN 61000
Design guidelines for PCs
PC 99 – connector overmold colors; PC 2001 – full functionality
Telecom
All local telecom requirements and approvals for intended markets
USA
FCC Title 47 CFR, Par 15, Subpart C; other local requirements
Country support
Argentina, Australia, Austria, Belgium, Brazil, Bulgaria, Canada, Chile, China, Croatia Czech Republic, Cyprus, Denmark, Ecuador, Estonia, Finland, France, Germany, Greece, HK, Hungary, India, Indonesia, Ireland, Israel, Italy, Japan, Korea, Latvia, Lithuania, Luxemburg, Malta, Mexico, Malaysia, Netherlands, Norway, NZ, Peru, Philippines, Poland, Portugal, Romania, Russia, Singapore, Slovakia, Slovenia, South Africa, Spain, Sweden, Switzerland, Taiwan, Thailand, Turkey, UK, Ukraine, United Arab Emirates, US, Venezuela, Vietnam, and up to 193 countries worldwide
Environmental
Keyboard contains 25% post-consumer recycled plastic material.
HP USB PS/2 Washable Keyboard
Specification
Physical Characteristics
449 x 168 x 35 mm (17.67x 6.62 x 1.38 in)
0.77 kg (1.7 lb)
Keys
104 (US) Layout, 105 (EU) layout – depending upon country
Electrical
Operating voltage
+ 5VDC ± 5%
Power consumption
System interface
ESD
EMI - RFI
Mechanical
Keycaps
Stepped profile design
Switch actuation
Switch life
Switch type
Cable length
2.2 m (7 ft)
Acoustics
Environmental
Temperature
Non-operating: -20° to 65° C (4° to 149° F)
Humidity
Operating: 10% to 95% (non-condensing at ambient)
Non-operating: 0% to 95% (non-condensing at ambient)
Shock
Vibration
Drop (out of box)
Drop (in box)
107 cm (42 in) on concrete, 16-drop sequence
Operating system support
Windows 7
Windows Vista
Windows XP Professional
Approvals
UL, cUL, FCC, CE, TUV GS, VCCI, BSMI, C-Tick, KCC, USB-IF, WHQL, EN/IEC 60601-1, IP66/NEMA4X
HP USB Smart Card (CCID) Keyboard
Specification
46.3 x 16.1 x 3.3 cm (18.2 x 6.3 x 1.3 in)
Keys
Form factor
USB basic smart card keyboard
Colors
Carbonite/Silver
Electrical
Operating voltage
+ 5 VDC ± 5%
Power consumption
100 mA maximum (with four LEDs ON)
System interface
ESD
EMI - RFI
Mechanical
Languages
30+ available
Keycaps
Standard design
Switch actuation
Switch life
Switch type
Contamination-resistant membrane
Cable length
1.8 m (6 ft)
Acoustics
Environmental
Temperature
Humidity
Shock
Vibration
Drop (out of box)
Drop (in box)
SmartCard function
Support
All ISO 7816 smart cards
Interface
Reads from and writes to all ISO7816-1, 2, 3, 4 memory and microprocessor smart cards (T = 0, T = 1)
SCM STCIII
Standard APIs supported
PC/SC, EMV2000, CT-API
Power
USB Port
Short circuit detection (protects smart card and reader)
Power supply compliant with ISO7816 and EMV (5V, 60 mA)
Supports 3-V and 5-V cards
Power consumption
100-mA maximum draw
Communication
From card: 9600 bps to 330,000 bps
From computer: 12 Mbps (USB transfer speed)
Landing mechanism
Contact device: Friction contact
Card insertions rating: Up to 100,000 insertion cycles
Interface modes
CCID protocol
Reader performance interface
USB connection
Electro-magnetic standards
Europe: 2004/108/EC
USA: USAFCC part 15
Approvals
CE-Mark, UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, MIC, EMV2000, USB-IF
ISO 9241-4, TUVGS
Kit contents
Keyboard, I/O Security and Documentation CD, warranty card
HP USB 1000dpi Laser Mouse
Specification
37.3 x 114.97 x 62.86 mm (1.47 x 4.53 x 2.47 in)
102 g (3.360 oz)
Cable length
180 cm (70.9 in)
System requirements
Available USB port
Environmental
Temperature
Non-operating: -20° to 60° C (-4° to 140° F)
Humidity
Mechanical
Resolution
1000 dpi
Tracking speed
45 cm/s
Cable length
180 cm (70.9 in)
Power supply specifications
Specification
Standard efficiency
65W active PFC 89% average efficiency at 115V
90W active PFC 89% average efficiency at 115V
80 PLUS bronze
N/A
80 PLUS gold
N/A
80 PLUS platinum
N/A
91/93/90% efficient at 20/50/100% load (230 V)
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50/60 Hz
Operating line frequency
47 – 63 Hz
Rated input current
N/A
DC Output
+19.5V
Current leakage (NFPA 99: 2102)
Less than 500 microamps of leakage current at 120 VAC with the ground wire disconnected, as required for Non-patient Electrical Appliances and Equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 microamps of leakage current at 120 VAC with the ground wire intact with normal polarity, as required for Non-patient Electrical Appliances and Equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power supply fan
N/A
Power cord length
N/A
External power adapter
N/A
Dimensions
N/A
Total cord length
N/A
Physical specifications
Specification
Chassis (H x W x D)
175 x 34 x 177 mm (6.9 x 1.3 x 7 in)
System volume
1.05 L (62..79 cu in)
System weight
1.3 kg (2.9 lb)
Max supported weight
35 kg (77 lb)
Stand Dimensions
19.5 x 117 x 160 mm (77x 4.6 x 6.3 in)
Weight: 47 g (0.1 lbs)
Packaging   (H x W x D)
198 x 290 x 500 mm (7.8 x 11.4 x 19.7 in)
Shipping Weight
4.1 kg (9 lb)
Palletization profile
8-units per layer
10/12-layer max.
80/96 per pallet
47.126 x 39.291 x 98.622 in (including pallet)
