    Fix HP Printer issue on macOS
HP LaserJet Pro M402, M403 - Clear paper jams in the duplexer
Use the following procedure to check for paper in all possible jam locations in the automatic duplexer.
  1. Completely remove Tray 2 from the printer.
    Figure : Remove the tray
  2. Push the green button to release the duplex pan.
    Figure : Push the green button
  3. Remove any jammed paper.
    Figure : Remove the jammed paper
  4. Close the duplex pan.
    Figure : Push up on the duplex pan
  5. Reinsert Tray 2.
    Figure : Close the tray
