HP LaserJet Enterprise M506 - Clear paper jams in Tray 1
Use the following procedure to clear paper jams in Tray 1. When a jam occurs, the control panel displays an animation that assists in clearing the jam.
  1. If most of the sheet of paper is visible in the tray, slowly pull the jammed paper out of the printer. Make sure that the entire sheet is removed. If it tears, continue with the following steps to find the remnants.
    If most of the sheet of paper has been pulled inside the printer, continue with the following steps.
    Figure : Remove the jammed paper
  2. Press the top-cover-release button on the left side of the printer.
    Figure : Press the release button
  3. Open the front door.
    Figure : Open the front door
  4. Remove the toner cartridge.
    Figure : Remove the toner cartridge
  5. Lift the jam-access cover and slowly remove any jammed paper. Be careful not to tear the paper.
  6. Reinsert the toner cartridge.
    Figure : Install the toner cartridge
  7. Close the front door.
    Figure : Close the front door
