HP Color LaserJet Enterprise MFP M577 - Replace the toner cartridges
The following information provides details about the toner cartridges for the printer, and it includes instructions to replace them.
Toner-cartridge information
This printer indicates when the toner-cartridge level is low and very low. The actual toner-cartridge life remaining can vary. Consider having a replacement cartridge available to install when print quality is no longer acceptable.
To purchase cartridges or check cartridge compatibility for the printer, go to HP SureSupply at www.hp.com/go/suresupply. Scroll to the bottom of the page and verify that the country/region is correct.
The printer uses four colors and has a different toner cartridge for each color: yellow (Y), magenta (M), cyan (C), and black (K). The toner cartridges are inside the front door.
Item
Cartridge number
Part number
HP 508A Black Original LaserJet Toner Cartridge
Standard-capacity replacement black toner cartridge
508A
CF360A
HP 508X High Yield Black Original LaserJet Toner Cartridge
High-capacity replacement black toner cartridge
508X
CF360X
HP 508A Cyan Original LaserJet Toner Cartridge
Standard-capacity replacement cyan cartridge
508A
CF361A
HP 508X High Yield Cyan Original LaserJet Toner Cartridge
High-capacity replacement cyan toner cartridge
508X
CF361X
HP 508A Yellow Original LaserJet Toner Cartridge
Standard-capacity replacement yellow toner cartridge
508A
CF362A
HP 508X High Yield Yellow Original LaserJet Toner Cartridge
High-capacity replacement yellow toner cartridge
508X
CF362X
HP 508A Magenta Original LaserJet Toner Cartridge
Standard-capacity replacement magenta toner cartridge
508A
CF363A
HP 508X High Yield Magenta Original LaserJet Toner Cartridge
High-capacity replacement magenta toner cartridge
508X
CF363X
High-yield toner cartridges contain more toner than standard cartridges for increased page yield. For more information, go to www.hp.com/go/learnaboutsupplies.
Do not remove the toner cartridge from its package until it is time to replace it.
To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover the green imaging drum if the toner cartridge must be removed from the printer for an extended period of time.
The following illustration shows the toner-cartridge components.
    Figure : Toner-cartridge components
  1. Handle
  2. Imaging drum
  3. Protective shield
  4. Memory chip
If toner gets on clothing, wipe it off by using a dry cloth and wash the clothes in cold water. Hot water sets toner into fabric.
Information about recycling used toner cartridges is in the toner-cartridge box.
Remove and replace the cartridges
  1. Open the front door.
    Figure : Open the door
  2. Grasp the handle of the used toner cartridge and pull out to remove it.
    Figure : Remove the toner cartridge
  3. Remove the new toner cartridge from its protective shell by tearing off the plastic strip and opening the package. Save all packaging for recycling the used toner cartridge.
    Figure : New toner cartridge
  4. Hold both ends of the toner cartridge and rock it 5-6 times.
    Figure : Shake the toner cartridge
  5. Remove the protective shield from the toner cartridge.
    Figure : Remove the protective shield
  6. Support the toner cartridge underneath with one hand while holding the cartridge handle with the other. Align the toner cartridge with its slot on the shelf, and then insert the toner cartridge into the printer.
    Avoid touching the green imaging drum. Fingerprints on the imaging drum can cause print defects.
    Figure : Install the toner cartridge
  7. Close the front door.
    Figure : Close the door
  8. Pack the used toner cartridge and the protective shield into the box that the new cartridge came in. See the enclosed recycling guide for information about recycling.
    HP helps recycle Original HP cartridges—it’s easy and free with the HP Planet Partners program, available in more than 50 countries/regions and territories around the world1).
    To find information about how to recycle used HP cartridges, please go to www.hp.com/recycle.
    Figure : Recycle the used cartridge
1) Program availability varies. For more information, visit www.hp.com/recycle.
