HP ProBook 450 G3 - Specification
Product description
Preinstalled
  • Windows 10 Pro 64
  • Windows 10 Home 64
  • Windows 8.1 Pro 64
  • Windows 8.1 64
  • Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)
  • Windows 7 Professional 32 (available through downgrade rights from Windows 10 Pro)
  • FreeDOS 2.0
Web only support
  • Windows 10 Enterprise 64
  • Windows 8.1 Enterprise 64
  • Windows 7 Enterprise 64
  • Windows 7 Enterprise 32
Processors
Intel Core i7-6500U with Intel HD Graphics 520 (2.5 GHz, up to 3.1 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores)
Intel Core i5-6200U with Intel HD Graphics 520 (2.3 GHz, up to 2.8 GHz with Intel Turbo Boost Technology, 3 MB cache, 2 cores)
Intel Core i3-6100U with Intel HD Graphics 520 (2.3 GHz, 3 MB cache, 2 cores)
Intel Celeron 3855U with Intel HD Graphics 510 (1.6 GHz, 2 MB cache, 2 cores)
Intel Pentium 4405U with Intel HD Graphics 510 (2.1 GHz, 2 MB cache, 2 cores)
Chipset is integrated with processor
Graphics (integrated)
Intel HD Graphics 510 or Intel HD Graphics 520
HD content required to view HD images.
Internal
  • Non-touch: 15.6 in diagonal HD1 anti-glare flat LED-backlit (1366 x 768)
  • Non-touch: 15.6 in diagonal full HD anti-glare slim LED-backlit (1920 x 1080)
  • Touch: 15.6 in diagonal HD1 anti-glare flat LED-backlit touch screen (1366 x 768)
External: Up to 32-bit per pixel color depth
VGA: Port supports resolutions up to 2048 x 1536 external resolution at 60 Hz
HDMI: Supports direct connection to high-definition displays with up to 4096 x 2160 at 24 Hz resolution and 7-channel audio with one convenient cable (not included)
Storage and drives
Supports SATA, 7 mm/9.5 mm, 2.5 in Hard Drives
  • 500 GB - 5400 RPM Hard Drive
  • 500 GB - 5400 RPM Solid State Hard Drive (8 GB Cache)
  • 500 GB - 7200 RPM Hard Drive
  • 1 TB - 5400 RPM Hard Drive
  • 2 TB - 5400 RPM Hard Drive
For hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up 30 GB for Windows 10 is reserved for system recovery software.
Optical drives
Support optional external USB drive CD/DVD R/RW
Memory
Two SODIMM slots. Both slots are customer accessible / upgradeable. DDR3L PC3-12800 (Transfer rates up to 1600 MT/s.) Supports Dual Channel Memory.
Standard
  • 2048 MB Total System Memory (2048 MB x 1)
  • 4096 MB Total System Memory (4096 MB x 1)
  • 6144 MB Total System Memory (4096 MB + 2048 MB) (Dual Channel)
  • 8192 MB Total System Memory (4096 MB x 2) (Dual Channel)
  • 8192 MB Total System Memory (8192 MB x 1)
  • 12288 MB Total System Memory (8192 MB + 4096 MB) (Dual Channel)
  • 16384 MB Total System Memory (8192 MB x 2) (Dual Channel)
Maximum
  • Upgradeable to 16384 MB in slots 1 and 2
Dual-channel
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed.
Networking
Broadband Wireless (WWAN)
HP hs3110 HSPA+ Mobile Broadband
HP lt4110 LTE/HSPA+ 4G Mobile Broadband
Wireless LAN (WLAN)
Realtek 802.11b/g/n (1x1)
Realtek 802.11b/g/n (1x1) and Bluetooth 4.0 Combo
Broadcom 802.11b/g/n (1x1) and Bluetooth 4.0 Combo
Broadcom 802.11a/b/g/n (2x2) and Bluetooth 4.0 Combo
Intel Dual Band Wireless-AC 3165 802.11a/b/g/n/ac (1x1) Wi-Fi and Bluetooth 4.0 Combo
Intel Dual Band Wireless-AC 8260 802.11a/b/g/n/ac (2x2) Wi-Fi and Bluetooth 4.2 Combo
Communications
Realtek Ethernet (10/100/1000)
The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Audio
HD audio with DTS Studio Sound
Two stereo speakers
Integrated microphone (dual-microphone array when equipped with optional webcam)
Headphone/microphone combo jack
Optional 720p HD webcam
Sold separately as an optional feature.
Internet access required.
Ports/slots
USB 3.0 (2)
USB 2.0 power port (2)
HDMI (1)
headphone/microphone combo (1)
AC power (1)
RJ-45 (1)
VGA (1)
Digital media slots
Multi Media Reader Slot
Supports SD, SDHC, SDXC
Keyboards/pointing devices/buttons and function keys
HP premium keyboard
  • The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. US and International key layouts are available. Includes a separate numeric keypad (HP ProBook 450 and 470 only.) Backlit keyboard available as an option.
Buttons and function keys
  • Separate launch buttons provide easy access to wireless on/off and speaker mute. Function keys provide control of features including: standby mode, display brightness, external display, microphone mute, volume down, volume up, and backlight toggle for backlit keyboard (select models only).
Function keys
ESC: system information
F1 - Sleep
F2 - Blank
F3 - Backlight toggle (for backlit keyboard) or Blank
F4 - Display switching
F5 - Brightness down
F6 - Brightness up
F7 - Blank
F8 - Volume down
F9 - Volume up
F10 - Mic mute
F11 - Blank
F12 – NumLock (430/440); Blank (450/470)
Hidden functions
Fn+R keys (Break)
Fn+S keys (Sys Rq)
Fn+C keys (Scroll lock)
Pointing devices
Touchpad with gestures support, on/off button with LED indicator, two-way scroll, two pick buttons
Touchpad
On/off button (on board)
Taps enabled as default
Gestures (enabled by default)
2 finger scrolling
2 finger zoom (pinch)
OSD (enable/disable)
Win8 2 Finger tap = right click
Win8 Edge Swipes
Disabled by default
3 finger flick
2 finger rotate
Momentum motion
1 finger vertical scroll
Software and security
BIOS
HP BIOSphere
HP DriveLock
HP Automatic DriveLock
HP BIOS Protection
Master Boot Record Security
Power On Authentication Pre-Boot Security Secure Erase
Hybrid Boot (Windows 8.1 & later)
Measure Boot (Windows 8.1 & later)
Secure Boot (Windows 8.1 & later)
Absolute Persistence Module
Multimedia
Cyberlink Power DVD, BD
Cyberlink Power2Go (Secure Burn)
Cyberlink YouCam BE (Windows 7 only)
Communication
HP GPS and Location (Windows 7 only)
HP Connection Manager with support for HP Mobile Connect (Windows 7 only)
HP Mobile Connect (Windows 8.1 & later)
Intel Wireless Display (WiDi) Software for Windows
Native Miracast Support
HP value add software
HP 3D DriveGuard
HP ePrint Driver
HP Hotkey
HP Recovery Manager
HP Recovery Disc Creator
HP Unified Recovery Manager (Windows 8.1 and 10 only)
HP Registration App (Windows 8.1 & later)
HP Support Assistant
HP Noise Reduction Software
3rd party
Foxit PhantomPDF Express for HP
HP Caller Dashboard Built by Thug Labs
Microsoft products
Buy Office
Bing Search
Skype
Manageability
HP Driver Packs
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM)
HP BIOS Config Utility (BCU)
HP Client Catalog
HP CIK for Microsoft SCCM
LANDESK Management
Client security software
HP Drive Encryption
HP Security Manager
Microsoft Security Essentials
Microsoft Defender
Security
Pre-boot Authentication
Security lock slot (Lock sold separately.)
Optional Fingerprint Reader
TPM
Power
Power supply
45 W Smart AC adapter
45 W Smart AC adapter 2-prong (Japan only)
65 W EM Smart AC adapter (China and India only)
Battery
HP 4-cell, 44 WHr Li-ion
Optional HP 6-cell, Long Life 55 WHr Li-ion (HP Fast Charge is available on 6-cell battery only.)
System standby time
4-cell (44 WHr) battery: Up to 15 days
6-cell (55 WHr) long life battery: Up to 16 days
Power conservation
Supports enhanced Intel SpeedStep technology (allows Battery Optimized Mode, Maximum Performance Mode, or Automatic mode)
AMD PowerPlay technology (discrete models)
Hibernation
Standby
ACPI compliance
Dimensions
Starting at 2.07 kg (4.56 lb)
Dimensions
Non-touch: 37.8 x 26.43 x 2.38 to 2.48 cm (14.88 x 10.41 x 0.94 to 0.98 in)
Touch: 37.8 x 26.46 x 2.55 to 2.65 cm (14.88 x 10.42 x 1 to 1.04 in)
System unit
Temperature
Operating: 0° to 35° C (32° to 95° F)
Non-operating: -20° to 60° C (-4° to 140° F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random vibration
Operating: 0.75 g
Non-operating: 1.5 g
Altitude (unpressurized)
Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
UL: Yes
CSA: No
FCC Compliance: Yes
ENERGY STAR 6.0: Select models
EPEAT: Registered Gold in United States
ICES: Yes
Australia / NZ A-Tick Compliance: Yes
CCC: Yes
Japan VCCI Compliance: Yes
KC: Yes
BSMI: Yes
CE Marking Compliance: Yes
BNCI or BELUS: Yes
CIT: Yes
GOST: Yes
Saudi Arabian Compliance (ICCP): Yes
SABS: Yes
UKRSERTCOMPUTER: Yes
15.6 in diagonal HD SVA anti-glare flat LED backlit (1366 x 768)
Outline dimensions (W x H x D)
360 x 224.3 x 3.8 mm (14.17 x 8.83 x 0.14 in)
Active area
344.2 x 193.5 mm (13.54 x 7.61 in)
420 g
Diagonal size
15.6 in
Surface treatment
Anti-glare
Contrast ratio
300:1
Refresh rate
60 Hz
Brightness
220 nits (typical)
Pixel resolution
1366 x 768
Interface
eDP 1.2 (1 lane)
LCD mode
SVA
PPI
101
Viewing angle
40/40/15/30
15.6 in diagonal FHD anti-glare flat LED backlit (1920 x 1080)
360 x 224.3 x 3.2 mm (14.17 x 8.83 x 0.12 in)
Active area
344.16 x 193.59
370 g
Diagonal size
15.6 in
Surface treatment
Anti-glare
Contrast ratio
300:1
Refresh rate
60 Hz
Brightness
220 nits (typical)
Pixel resolution
1920 x 1080
Interface
eDP 1.2 (2 lane)
LCD mode
SVA
PPI
142
Viewing angle
SVA 45/45/25/35
Storage and drives
500 GB 5400 rpm SATA hard drive
Drive weight
101 g (0.22 lb)
Capacity
500 GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum) 300 MB/s (Drive Capability)
Seek time
Single track: 3 ms
Average: 13 ms
Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
976,773,168
Operating temperature
0° to 60° C (32° to 140° F) (case temperature)
Featuers
ATA security
500 GB 5400 rpm SMART SATA II hybrid HDD/SSHD
Drive weight
95 g (0.209 lb)
Capacity
500 GB
Height
7 mm (0.276 in)
Width
70.1 mm (2.76 in)
Interface
ATA-8, SATA 2.6, 6.0 Gb/s, NCQ
Transfer rate
600 MB/s
Seek time
Single track: 2 ms
Average: 12 ms
Maximum: NIL ms
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
500 GB 7200 rpm SATA hard drive
Drive weight
115 g (0.25 lb)
Capacity
500 GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
300 MB/s
Seek time
Single track: 1.15 ms
Average: 11 ms
Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
1 TB 5400 rpm SATA hard drive
Drive weight
117 g (0.25 lb)
Capacity
1 TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Transfer rate
Synchronous 600MB/s (maximum)
Seek time
Single track: 2 ms
Average: 12 ms
Maximum: 22 ms
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Features
ATA security, S.M.A.R.T., NCQ, Ultra DMA
2 TB 5400 rpm hard drive
Drive weight
130 g (0.28 lb)
Capacity
2 TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Transfer rate
Seek time
Single track: 2 ms
Average: 12 ms
Maximum: 22 ms
Rotational speed
5400 rpm
Logical blocks
3,907,029,168
Features
Solid state drive 128 GB 2280 M2 SATA-3
Drive weight
10 g (0.022 lb)
Capacity
128 GB
Height
3.7 mm (0.14 in)
Width
22 mm (0.87 in)
Interface
ATA-8, SATA 3.0
Performance
Maximum sequential read: up to 520 MB/s
Maximum sequential write: up to 140 MB/s
Logical blocks
250,069,680
0° to 70° C (32° to 158° F) (ambient temperature)
Features
DIPM; TRIM; DEVSLP
Security features
ATA security
Optical drives
DVD+/-RW SuperMulti DL drive
Access times (typical)
< 140 ms CD
< 160 ms DVD
170 g
Maximum data transfer rate
24X CD-ROM
8X DVD
24X CD-R
24X CD-RW
8X DVD+R
8X DVD+RW
8X DVD-R
6X DVD-RW
6X - DVD+R Dual Layer
6X - DVD-R Dual Layer
5X DVD-RAM
Transfer mode
UDMA mode 5
Interface
Gen 1 SATA
Supported media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
Supported media (write)
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
Max media capacity (read)
8.5 GB
Max media capacity (write)
8.5 GB
Transport
Tray loading
Blue-ray ROM DVD+/-RW SuperMulti DL drive
< 190 ms CD-ROM
< 180 ms DVD-ROM
< 230 ms BD-ROM
170 g
Max data transfer rate
24X CD-ROM
8X DVD-ROM
24X CD-R
16X CD-RW
8X DVD+R
8X DVD+RW
8X DVD-R
6X DVD-RW
4X DVD+R Dual Layer
4X DVD-R Dual Layer
5X DVD-RAM
6X BD-ROM
Transfer mode
UDMA mode 5
Interface
Gen 1 SATA
CD-DA, , CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW. DVD-RAM, BD-ROM, BD-R, BD-RE
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-RAM
50 GB
8.5 GB
Transport
Tray loading
DVD-ROM drive
< 140 ms CD-ROM
< 160 ms DVD-ROM
24X CD-ROM
8X-DVD
Transfer mode
UDMA mode 5
Interface
Gen 1 SATA
None
8.5 GB
8.5 GB
Transport
Tray loading
Security
HP synaptics VFM 495 fingerprint reader (optional)
Mobile voltage operations
Realtek ALC 3227 low power high definition audio codec
0° – 70° C (32° – 158° F)
Current consumption at 3.3 V
Less than 70 mA peak imaging and scrolling
Less than 25 mA hardware finger detection Advanced Power Management
High-rate image capture
Up to 240 image frames /sec
ESD resistance
IEC 61000-4-2 level 4 (±15KV)
Detection matrix
200 pixel wide fingerprinting image
16.5 x 3 mm sensor area
508 dpi resolutuion, 256 levels of grayscale
Networking/communications
Realtek 802.11 b/g/n (1x1)
Wireless LAN standards
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
2.402 - 2.482 GHz
The FCC has declared as of September 1, 2014 products that utilize passive scanning on channel 12/13 and are capable of transmitting must fully comply with requirements of 15.247 or otherwise disable those channels.
Data rates
802.11b: 1, 2, 5.5, 11 Mbps
802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
802.11n: MCS 0 ~ MCS 07, (20MHz)
Modulation
Direct Sequence Spread Spectrum
BPSK, QPSK, CCK, 16-QAM, 64-QAM
Security
IEEE and Wi-Fi compliant 64 / 128 bit WEP encryption for a/b/g mode only
AES-CCMP: 128 bit in hardware
802.1x authentication
WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
WPA2 certification
IEEE 802.11i
Cisco Certified Extensions, all versions through CCX4 and CCX Lite
WAPI
Network architecture models
Ad-hoc (peer to peer)
Infrastructure (access point required)
Roaming
IEEE 802.11 compliant roaming between access points
Output power
802.11b : +16 dBm minimum
802.11g : +14 dBm minimum
802.11a : +14 dBm minimum
802.11n HT20(2.4GHz) : +13 dBm minimum
802.11n HT40(2.4GHz) : +13 dBm minimum
802.11n HT20(5GHz) : +12 dBm minimum
802.11n HT40(5GHz) : +12 dBm minimum
Power consumption
Transmit: 2.0 W
Receive: 1.6 W
Idle mode (PSP): 180 mW (WLAN Associated)
Idle mode: 60 mW (WLAN unassociated)
Radio disabled: 30 mW
Power management
ACPI and PCI Express compliant power management 802.11 compliant power saving mode
Receiver sensitivity
802.11b, 1Mbps: -94 dBm maximum
802.11b, 11Mbps: -86 dBm maximum
802.11g, 6Mbps: -88 dBm maximum
802.11g, 54Mbps: -74 dBm maximum
802.11a, 6Mbps: -86 dBm maximum
802.11a, 54Mbps: -72 dBm maximum
802.11n, MCS07: -69 dBm maximum
802.11n, MCS15: -66 dBm maximum
Antenna type
High efficiency antenna with spatial diversity, mounted in the display enclosure.
Two embedded 2.4 GHz antennas are provided to the card to support WLAN and Bluetooth communications (Support Dual antenna or Single antenna, depend on platform requirement)
Form factor
PCI-Express M.2 MiniCard
Dimensions
Type 2230: 2.3 x 22 x 30 mm (0.09 x 0.86 x 1.18 in)
Type 1630: 2.3 x 16 x 30 mm (0.09 x 0.62 x 1.18 in)
Type 2230: 2.8 g
Type 1630: 2 g
Operating voltage
3.3v +/- 9%
LED activity
LED Amber – Radio OFF; LED White – Radio ON
Realtek 802.11 b/g/n (1x1) + Bluetooth combo
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
2.402 - 2.482 GHz
Data rates
Modulation
Security
WPA2 certification
IEEE 802.11i
WAPI
Ad-hoc (peer-to-peer)
Roaming
Output power
Power consumption
Transmit: 2.0 W
Receive: 1.6 W
Power management
802.11b, 1Mbps : -94 dBm maximum
802.11b, 11Mbps : -86 dBm maximum
802.11g, 6Mbps : -88 dBm maximum
802.11g, 54Mbps : -74 dBm maximum
802.11n, MCS07 : -69 dBm maximum
802.11n, MCS15 : -66 dBm maximum
Antenna type
Two embedded antennas for 2.4GHz are provided to the card to support WLAN and Bluetooth communications. (Support Dual antenna or Single antenna, depend on platform requirement)
Form factor
Dimensions
Type 2230: 2.8 g
Type 1630: 2 g
Operating voltage
3.3v +/- 9%
Temperature
Operating: –10° to 70° C (14° to 158° F)
Non-operating: –40° to 80° C (–40° to 176° F)
Humidity
Operating: 10% to 90% (non-condensing)
Non-operating: 5% to 95% (non-condensing)
Altitude
Operating: 0 to 3,048 m (10,000 ft)
Non-operating: 0 to 15,240 m (50,000 ft)
LED activity
HP integrated module with Bluetooth 4.0+ EDR wireless technology
Bluetooth specification
4.0+ EDR compliant
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
3 Mbps data rate; throughput up to 2.17 Mbps
Synchronous Connection Oriented links up to 3, 64 kbps, voice channel
Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit power
The Bluetooth component operates as a Class II Bluetooth device with a maximum transmit power of +4 dBm for BR and EDR.
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Selective Suspend 17 mW
Range
Up to 10 m (33 ft)
Electrical interface
USB 2.0 compliant
Bluetooth software supported
Full support of Bluetooth Security Provisions
Power management
Microsoft Windows ACPI, and USB Bus Support
Self-configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Security certifications
All necessary regulatory approvals for supported countries, including FCC (47 CFR) Part 15C, Section 15.247 and 15.249
Power management
ETS 300 328, ETS 300 826
Low Voltage Directive IEC950
Certifications
UL, CSA, and CE Mark
Serial Port Profile (SPP)
Service Discovery Application Profile (SDAP)
Dial-Up Networking (DUN)
Generic Object Exchange Profile (GOEP)
Object Push Profile (OPP)
File Transfer Profile (FTP)
Synchronization Profile (SYNC)
Hard Copy Cable Replacement (HCRP)
Personal Area Networking Profile (PAN)
Human Interface Device Profile (HID)
FAX Profile (FAX)
Basic Imaging Profile (BIP)
Headset Profile (HSP)
Hands Free Profile (HFP)
Advanced Audio Distribution Profile (A2DP)
Broadcom 802.11 b/g/n (1x1) + Bluetooth combo
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
802.11 b/g/n
2.402 - 2.482 GHz
Data rates
Modulation
Security
WPA2 certification
IEEE 802.11i
WAPI
Roaming
Output power
Power consumption
Transmit: 2.0 W
Receive: 1.6 W
Power management
Antenna type
Two embedded antennas for 2.4 GHz are provided to the card to support WLAN and Bluetooth communications. (Support Dual antenna or Single antenna, depend on platform requirement)
Form factor
Dimensions
Type 2230: 2.8 g
Type 1630: 2 g
Operating voltage
3.3v +/- 9%
Temperature
Humidity
Altitude
LED activity
4.0+ EDR compliant
Frequency band
2402 to 2480 MHz
Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
Transmit power
The Bluetooth component shall operate as a Class II Bluetooth device with a maximum transmit power of +4 dBm for BR and EDR
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Range
Up to 10 m (33 ft)
USB 2.0 compliant
Point to Point, Multipoint Pico Nets up to 7 slaves
Microsoft Windows Bluetooth software
Power management
Security
Certifications
FAX Profile (FAX)
Broadcam 802.11 a/b/g/n (2x2) and Bluetooth 4.0 combo
IEEE 802.11a
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
  • 2.402 - 2.482 GHz
    The FCC has declared as of January 1, 2015 products that utilize passive scanning on channel 12/13 and are capable of transmitting must fully comply with requirements of 15.247 or otherwise disable those channels.
802.11a
  • 4.9 – 4.95 GHz (Japan)
  • 5.15 – 5.25 GHz
  • 5.25 – 5.35 GHz
  • 5.47 – 5.725 GHz
  • 5.825 – 5.850 GHz
    Indonesia only supports 5.725 - 5.825 GHz (CH149 - CH161)
Antenna structure
2 transmit; 2 receive (2x2)
Data rates
802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
802.11n: MCS 0 ~ MCS 15, (20MHz, and 40MHz)
Modulation
Direct sequence spread spectrum
CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security
WPA2 certification
IEEE 802.11i
WAPI
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations
Roaming
IEEE 802.11 compliant roaming between band Access Points
Output power
Power consumption
Transmit: 2.0 W
Receive: 1.6 W
Power management
Reciver sensitivity
802.11a, 6Mbps : -86 dBm maximum
802.11a, 54Mbps : -72 dBm maximum
Antenna type
Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO and Bluetooth communications
Form factor
Dimensions
Type 2230: 2.8 g
Type 1630: 2 g
Operating voltage
3.3v +/- 9%
Humidity
Operating: -10° to 70° C (14° to 158° F)
Non-operating: -40° to 80° C (-40° to 176° F)
Altitude
LED activity
LED Amber - Radio OFF; LED White - Radio ON
4.0+ EDR compliant
Frequency band
2402 to 2480 MHz
Transmit power
The Bluetooth component operates as a Class II Bluetooth device with a maximum transmit power of +4 for BR and EDR.
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Selective suspend 17 mW
Range
Up to 10 m (33 ft)
USB 2.0 compliant
Bluetooth software supported link topology
Point to point, multipoint Pico nets up to 7 slaves
Full support of Bluetooth security provisions
Power management
Security
Certifications
ETS 300 328, ETS 300 826 Low Voltage Directive IEC950 UL, CSA, and CE
Mark Serial Port Profile (SPP)
FAX Profile (FAX)
Realtek ethernet (10/100/1000)
Ethernet features
10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
1000 Mbit/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023 clauses 40)
Auto-Negotiation (Automatic Speed Selection)
Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
IEEE 802.1p QoS (Quality of Service) Support
IEEE 802.1q VLAN support
IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
IEEE 802.3az EEE (Energy Efficient Ethernet)
Jumbo Frame 9K
Auto MDI/MDIX Crossover cable detection
Power management
ACPI compliant - multiple power modes
Situation-sensitive features reduce power consumption Advanced link down power saving for reducing link down power consumption
Performance features
TCP/IP/UDP Checksum Offload (configurable)
Protocol Offload (ARP & NS)
Large send offload and Giant send offload Receiving Side Scaling
Manageability
Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame); Wake-on-LAN from off (Magic Packet only)
PXE 2.1 Remote Boot
Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
Comprehensive diagnostic and configuration software suite Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Realtek PCIe GBE Ethernet Family Controller
Audio/multimedia
DTS studio sound
Implementation: conexant
Function controls: volume up, volume down, and mute
Full duplex: yes
Microphone in: stereo
Headphone/line out: stereo
Integrated microphone: yes, dual digital microphone array
Audio output quality
Frequency response: 20 Hz - 20k Hz
Signal to noise ratio: 106 dB (DAC), 102 dB (ADC)
Total harmonic distortion: 91 dB THD+n on line out/HP (0.003%)
Play sampling rate: up to 192 k Hz
Record sampling rate: up to 96 k Hz
DAC: 16, 20, or 24-bit
ADC: 16, 20, 24-bit
Integrated stereo speakers
Power rating: 2 watts
Impedance: 4 ohms
Power
HP 45W smart AC adapter
Dimensions
9.5 x 4.0 x 2.65 cm (3.74 x 1.57 x 1.04 in)
175 g (0.386 lb)
Input
90 to 265 VAC
Input efficiency
87.74% at 115 VAC and 88.4% at 230 VAC
Input frequency range
47 to 63 Hz
Input AC current
1.4 A at 90 VAC
Output power
45 W
DC output
19.5 V
Hold-up time
5 MS at 115 VAC input
Output current limit
< 8.0 A
Over voltage protection
< 29 V max automatic shutdown
Over short protection
Auto-recovery and no damage
Connector
3-pin, grounded, mates with interchangeable cords
Environmental design
Operating temperature: 0° to 35° C (32° to 95° F)
Non-operating (storage) temperature: -20° to 85° C (-4° to 185° F)
Altitude: 0 to 5,000 m (0 to 16,400 ft)
Humidity: 20% to 95%
Storage humidity: 10% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives
Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE.
MTBF - over 200,000 hours at 25°C ambient condition.
HP 65W EM smart AC adapter (PRC, India only)
Dimensions
12.65 x 5 x 3 cm (4.98 x 1.97 x 1.18 in)
290 g (0.62 lb)
Input
90 to 265 VAC
Input efficiency
87% at 115 VAC
47 to 63 Hz
Input AC current
1.7 A at 90 VAC
Output power
65 W
DC output
19.5 V
Hold-up time
< 11.0 A
Connector
HP 65W smart AC adapter
Dimensions
290 g (0.62 lb)
Input
90 to 265 VAC
Input efficiency
87% at 115 VAC
47 to 63 Hz
Input AC current
1.7 A at 90 VAC
Output power
65 W
DC output
19.5 V
Hold-up time
< 11.0 A
Connector
Batteries
HP 4-cell, long life 44 WHr Li-ion
Dimensions (H x W x L)
33.4 x 275.8 x 20.6 mm (1.32 x 10.86 x 0.81 in)
0.3 kg (0.66 lb)
Cells/type
4 cell Lithium-Ion
Voltage
14.8 V
Amp-hour capacity
3 Ah
Watt-hour capacity
44 Wh
Temperature
Operating (charging): 0˚ to 45˚ C (32˚ to 113˚ F)
Operating (discharging): -10˚ to 60˚ C (14˚ to 122˚ F)
Non-operating: -20˚ to 60˚ C (-4˚ to 122˚ F)
Battery re-charge time
System in off or standby mode: < 3 hours
Fuel gauge LED
No
1 year
Optional travel battery available
No
HP 6-cell, long life 55 WHr Li-ion
45.59 x 275.8 x 33.89 mm (1.79 x 10.85 x 1.33 in)
330 g (0.72 lb)
Cells/type
Cylindrical ICR18650 C4
Voltage
10.68 V
Amp-hour capacity
5.15 Ah
Watt-hour capacity
55 Wh
Temperature
Operating (discharging): -10˚ to 60˚ C (14 to 140˚ F)
Non-operating: -20˚ to 60˚ C (-4˚ to 140˚ F)
System on: 3 - 5 hours
Fuel gauge LED
No
3 year or 1000 cycles
No
