Document ID: c04784159
Version: 1
Advisory: HP ZBook 15 and HP ZBook 17 Mobile Workstation - the Computer Stops Responding When Resuming From Standby if Using M2 PCIe Drive With DriveLock Password Enabled
Release date : 02-Sep-2015
Last updated : 02-Sep-2015
DESCRIPTION
The computer hangs (stops responding) when resuming from Standby. This occurs if:
  • the main hard drive is an M2 PICe drive
    and
  • a DriveLock password is set
SCOPE
Systems:
  • HP ZBook 15 G2 Mobile Workstation
  • HP ZBook 17 G2 Mobile Workstation
  • HP ZBook 17 G2 Mobile Workstation (ENERGY STAR)
  • HP ZBook 17 G2 Mobile Workstation Bundle
BIOS versions:
Version 01.09
RESOLUTION
Workaround the issue by disabling the DriveLock password in BIOS (F10 Setup).
Resolve the issue by updating the BIOS to version 1.11 (no need to disable DriveLock):
SoftPaq Description
Release Notes
Download SoftPaq
HP Notebook System BIOS Update
Version: 01.11
Revision: A Pass: 1
Hardware platforms affected : HP ZBook 15 G2 Mobile Workstation, HP ZBook 17 G2 Mobile Workstation, HP ZBook 17 G2 Mobile Workstation (ENERGY STAR), HP ZBook 17 G2 Mobile Workstation Bundle
Support Communication Cross Reference ID : IA04784159
