Document ID: c04778339
Version: 1
Advisory: HP EliteBook Folio 1020 G1 and HP Elite x2 1011 G1 Notebook PC - the Computer Does Not Start After Updating the BIOS to Version 1.08
Release date : 25-Aug-2015
Last updated : 26-Aug-2015
DESCRIPTION
When flashing the BIOS, after the update completes the computer shuts down to restart but then it remians in the off state or it may begin to restart and then hang with a blank screen. It should restart and boot to the operating system.
The issue occurs when updating the BIOS directly form version 1.05 or 1.06 to version 1.08.
NOTE: when installing version 1.08 using the HP SoftPaq exceutable, this will not be an issue because the SoftPaq will first install 1.07, then 1.08. The issue would only occur if you had extracted the binaries and installed 1.08 without first installing 1.07.
SCOPE
Systems:
  • HP Elite x2 1011 G1
  • HP EliteBook Folio 1020 G1 Notebook PC
  • HP EliteBook Folio 1020 G1 Special Edition Notebook PC
RESOLUTION
Avoid the issue by updating the BIOS to version 1.07 first and then updating to version 1.08.
If the issue has already occurred, recover the computer as follows:
If the computer is in the off state, press the power button briefly to start it.
If the computer hangs (for 1 minute or more) with a blank screen, press and hold the power button for 9 seconds to perform a full shutdown. Then press the power button again to start the computer.
Hardware platforms affected : HP Elite x2 1011 G1, HP EliteBook Folio 1020 G1 Notebook PC, HP EliteBook Folio 1020 G1 Special Edition Notebook PC
Support Communication Cross Reference ID : IA04778339
