- Updated to support Windows 10.
- Updated to the latest Intel Reference Code 2.8.0.
- Updated to the latest microcode version P48.
- Added a new F10 (BIOS) Setup option that allows password protection for the F9 and F12 menus.
- Fixed an issue where the computer would not report an error at POST when Computrace and Secure Boot were enabled.
- Reports the correct UEFI version as 2.3.1.
- ${title}
- ${title}
- ${title}
- ${title}
Document ID: c04772894
Version: 1
System BIOS Update 01.09 for HP Elite x2 1011 G1
Release date : 18-Aug-2015
Last updated : 18-Aug-2015
REASON FOR CHANGE
Quarterly refresh for factory and Web release only.
IMPACT OF CHANGE
If computer is updated from version 01.06 or older to version 01.09, is possible that computer could power off instead of auto-booting right after BIOS flash completion. If this happens, press the Power button and the computer will power on normally. To avoid this, it is recommended to upgrade to version 01.08 first.
The SoftPaq release for version 01.09 will automatically upgrade to 01.08 first, if it detects a BIOS version older or the same as 01.06. Running the SoftPaq a second time will upgrade to 01.09.
If the computer has version 01.07 or newer, then SoftPaq 01.09 will upgrade directly to 01.09.
Components affected:
HP Elite x2 1011 G1
DATE OF CHANGE
Effective date : 15-Aug-2015
Hardware platforms affected :
HP Elite x2 1011 G1 Tablet
© Copyright 2022 HP Development Company, L.P.
HP Inc. shall not be liable for technical or editorial errors or omissions contained herein. The information provided is provided "as is" without warranty of any kind. To the extent permitted by law, neither HP or its affiliates, subcontractors or suppliers will be liable for incidental, special or consequential damages including downtime cost; lost profits; damages relating to the procurement of substitute products or services; or damages for loss of data, or software restoration. The information in this document is subject to change without notice. HP Inc. and the names of HP products referenced herein are trademarks of HP Inc. in the United States and other countries. Other product and company names mentioned herein may be trademarks of their respective owners.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
