    Apache Log4j Update
HP ProBook 455 G3 Notebook PC - Specification
Features
Operating system (preinstalled)
Windows 10 Pro 64
Windows 8.1 Pro 64
Windows 8.1 64
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)
This system is preinstalled with Windows 7 Professional software and also comes with a license and media for Windows 10 Professional software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data.
Windows 7 Professional 32 (available through downgrade rights from Windows 10 Pro) (Japan only)
Windows 7 Professional 64 (available through downgrade rights form Windows 8.1 Pro)
This system is preinstalled with Windows 7 Pro software and also comes with a license and media for Windows 8.1 Pro software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data
Windows 7 Professional 32 (available through downgrade rights form Windows 8.1 Pro) (Japan only)
FreeDOS 2.0
Ubuntu Linux (not available with AMD Discrete A4 or A8 APUs)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows functionality.
Operating system (Web only supported)
Windows 10 Enterprise 64
Windows 8.1 Enterprise 64
Windows 7 Enterprise 64
Windows 7 Enterprise 32
Processors
AMD A10-8700P APU with Radeon R6 Graphics (1.8 GHz, up to 3.2 GHz, 2 MB L2 Cache, 4 cores)
AMD A8-7410 APU with Radeon R5 Graphics (2.2 GHz, up to 2.5 GHz, 2 MB L2 Cache, 4 cores)
AMD A4-7210 APU with Radeon R3 Graphics (1.8 GHz, up to 2.2 GHz, 2 MB L2 Cache, 4 cores)
This system requires a separately purchased 64-bit operating system and 64-bit software products to take advantage of the 64-bit processing capabilities of AMD technology. Multi-core processing with AMD technology is designed to improve performance of this system. Given the wide range of software applications available, performance will vary. AMD's numbering is not a measurement of clock speed. Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
Graphics
Integrated UMA Graphics
  • AMD A10-8700P APU with Radeon R6 graphics
  • AMD A8-7410 APU with Radeon R5 graphics
  • AMD A4-7210 APU with Radeon R3 graphics
AMD Switchable Discrete Graphics
  • AMD A8-7410 APU with Radeon R7 M340 graphics, with 2 GB dedicated DDR3 video memory
  • AMD A4-7210 APU with Radeon R7 M340 graphics, with 2 GB dedicated DDR3 video memory
AMD Dual Graphics: AMD A10-8700P APU with Radeo R8 M350DX graphics, with 2 GB dedicated DDR3 video memory
Internal: 15.6-inch diagonal HD* anti-glare LED-backlit (1366 x 768)
External: Up to 32-bit per pixel color depth
VGA: Port supports resolutions up to 2048 x 1536 at 60 Hz
Available on A4 and A8 APUs only. Supports either VGA or HDMI. Cannot support both VGA and HDMI simultaneously.
HDMI: v1.4
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
*HD content required to view HD images.
Storage and drives
Primary storage bay
  • Supports all 7 mm / 9.5 mm, SATA 2.5 in hard drives
  • 500 GB 5400 rpm HDD
  • 500 GB 7200 rpm HDD
  • 1 TB 5400 rpm HDD
HP 3D DriveGuard (Windows only): The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive
For hard drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10 and Windows 8.1) of system disk is reserved for the system recovery software.
Memory
Standard
  • Two SODIMM slots (customer accessible)
  • Single Channel Support
  • DDR3L-1600 (transfer rates up to 1600 MT/s)
  • 2048 MB total system memory (2048 MB x 1)
  • 4096 MB total system memory (4096 MB x 1)
  • 6144 MB total system memory (4096 MB + 2048 MB) (single channel)
  • 8192 MB total system memory (4096 MB x 2) (single channel)
  • 8192 MB total system memory (8192 MB x 1)
  • 12288 MB total system memory (8192 MB + 4096 MB) (single channel)
  • 16384 MB total system memory (8192 MB x 2) (single channel)
Maximum
  • 16384 MB in slots 1 and 2
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system performs at the lower memory speed.
Networking
Wireless
  • Realtek 802.11 b/g/n (1x1)
  • Realtek 802.11b/g/n (1x1) Wi-Fi and Bluetooth 4.0 Combo*
  • Broadcom 802.11b/g/n (1x1) Wi-Fi and Bluetooth 4.0 Combo*
  • Broadcom 802.11 a/b/g/n (2x2) Wi-Fi Bluetooth 4.0 Combo*
Wireless access point and Internet service required and sold separately.
Availability of public wireless access points limited.
Bluetooth 4.0 is only supported via Combo card.
*Sold separately or as an optional feature.
Communications
  • Integrated Ethernet 10/100/1000 (Gigabit) NIC
Audio
HD Audio with DTS Studio Sound
Integrated microphone (mono on non-webcam models only)
Integrated microphone (dual Array on webcam models only)
2 Stereo Speakers
Function keys for microphone mute, volume up, volume down
Stereo Audio-out (headphone)
Stereo Audio-in (microphone)
Optional Webcam* HP Camera (720p HD) (Internet access required)
Clickpad
Multitouch gestures enabled
Support Windows 8 modern trackpad gestures
Taps enabled as default
Stylus writing support
Keyboards/pointing devices
HP Premium Keyboard
The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. US and International key layouts are available. Includes a separate numeric keypad. Backlit keyboard available as an option.
Buttons and function keys
Separate launch buttons provide easy access to wireless on/off and speaker mute. Function keys provide control of features including: standby mode, display brightness, external display, microphone mute, volume down, volume up, and backlight toggle for backlit keyboard (select models only).
Function keys
ESC - System Information
F1 - Sleep
F2 - Blank
F3 - Backlight Toggle (for backlit keyboard) or Blank
F4 - Display Switching
F5 - Brightness Down
F6 - Brightness Up
F7 - Blank
F8 - Volume Down
F9 - Volume Up
F10 - Mic Mute
F11 - Blank
F12 - Blank
Hidden functions
Fn+R - Break
Fn+S - Sys Rq
Fn+C - Scroll Lock
Touchpad
On/off button (on board)
Gestures (enabled by default)
  • 2 Finger Scrolling
  • 2 Finger Zoom (Pinch)
  • OSD (enable/disable)
  • Win 8 2 Finger tap = right click
  • Win 8 Edge Swipes
Disabled by default
  • 3 Finger Flick
  • 2 Finger Rotate
  • Momentum Motion
  • 1 Finger Vertical Scroll
Preinstalled software and security
BIOS
HP BIOSphere
Available only on business PCs with HP BIOS.
HP DriveLock, HP Automatic DriveLock
HP BIOS Protection
May require a manual recovery step if all copies of BIOS are compromised or deleted.
Master Boot Record Security
Power On Authentication
Pre-Boot Security
Secure Erase
For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88.
Hybrid Boot (Windows 8.1 & later)
Measure Boot (Windows 8.1 & later)
Secure Boot (Windows 8.1 & later)
Absolute Persistence Module
Absolute agent is shipped turned off, and will be activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Multimedia
Cyberlink Power DVD, BD
Cyberlink Power2Go (Secure Burn)
Cyberlink YouCam BE (Windows 7 only)
Communication
HP GPS and Location (Windows 7 only)
GPS access requires an unobstructed path to multiple satellites. Performance may be affected if/when used inside of buildings, bridges or heavily congested metropolitan areas. Requires separately purchased GPS navigation software available from multiple GPS applications.
HP Connection Manager with support for HP Mobile Connect (Windows 7 only)
HP Mobile Connect (Windows 8.1 & later)
HP Mobile Connect is only available on preconfigured devices with WWAN.
Native Miracast Support
Miracast is a wireless technology your PC can use to project your screen to TVs, projectors, and streaming media players that also support Miracast. You can use Miracast to share what you’re doing on your PC and present a slide show.
HP Value Add Software
HP 3D DriveGuard
HP ePrint Driver
Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees may apply. Print times and connection speeds may vary.
HP Hotkey
HP Recovery Manager
HP Recovery Disc Creator
HP Unified Recovery Manager (Windows 8.1 and 10 only)
HP Registration App (Windows 8.1 & later)
HP Support Assistant
HP Noise Reduction Software
HP Pixel Sharp
3rd Party
Foxit PhantomPDF Express for HP
Microsoft products
Buy Office
Bing Search
Skype
Skype is not offered in China.
Manageability
Preinstalled
  • HP SoftPaq Download Manager (SDM)
  • LANDESK Management (subscription required)
Not preinstalled (available on manageability website)
  • HP Driver Packs
  • HP BIOS Config Utility (BCU)
  • HP Client Catalog
  • HP CIK for Microsoft SCCM
  • HP System Software Manager (SSM)
Client security software
The Absolute Persistence agent is shipped turned off, and must be activated by customers when they purchase a subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S.
HP Drive Encryption
Data is protected prior to Drive Encryption login. Turning the PC off or into hibernate logs out of Drive Encryption and prevents data access.
HP Security Manager
Microsoft Security Essentials
Opt in and internet connection required for updates.
Microsoft Defender
Security
Pre-boot Authentication
Security lock slot (Lock sold separately)
Optional Fingerprint Reader (sold separately)
TPM
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Power supply
Models with discrete graphics: HP 65W Smart AC Adapter
Models with integrated graphics:
  • HP 45W Smart AC Adapter
  • HP 45W Smart AC Adapter (two prong) (Japan only) (1.0 m power cord only)
Primary battery
HP 4-cell battery - 44 WHr Li-ion
Optional HP 6-cell battery- 55 WHr Long Life Li-ion
Power cord length 1 meter or 1.8 meter
Weight and dimensions
Starting at 2.15 kg (4.74 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
37.80 x 26.43 x 2.38 cm (14.88 x 10.41 x 0.94 in)
Height varies depending upon where on the notebook the measurement is made.
Other weights (sold separately or as an optional feature)
ODD, 4 cell Battery: 2.26 kg (4.98 lb)
No-ODD, 6 cell Battery: 2.27 kg (5 lb)
ODD, 6 cell Battery: 2.38 kg (5.25 lb)
Ports/slots
Ports
2 USB 3.0 Ports
2 USB 2.0 Ports
1 HDMI
1 VGA
1 RJ-45 /Ethernet
1 Headphone/Microphone Combo Jack
1 Power Adapter connector
All cables are sold separately.
Media reader slot
Support SD/SDHC/SDXC
Push-Push Insertion/Removal
System unit
Stand-alone power requirements (AC power)
Nominal Operating Voltage
19.5V
Average Operating Power
21W
Maximum Operating Power
Discrete < 65W
UMA < 45W
Temperature
Operating
0° to 35° C (32° to 95° F) (not writing optical)
5° to 35° C (41° to 95° F) (writing optical)
Non-operating
-20° to 60° C (-4° to 140° F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
UL
Yes
CSA
Yes
FCC Compliance
Yes
ENERGY STAR
Select models
Configurations of the HP ProBook 455 G3 that are ENERGY STAR qualified are identified as HP ProBook 455 G3 ENERGY STAR on HP websites.
EPEAT
Registered Gold in United States
EPEAT registration varies by country.
ICES
Yes
Australia / NZ A-Tick Compliance
Yes
CCC
Yes
Japan VCCI Compliance
Yes
KC
Yes
BSMI
Yes
CE Marking Compliance
Yes
BNCI or BELUS
Yes
CIT
Yes
GOST
Yes
Saudi Arabian Compliance (ICCP)
Yes
SABS
Yes
UKRSERTCOMPUTER
Yes
Item
15.6-inch diagonal LED HD (1366 x 768) anti-glare
Dimensions (W x H)
36.0 x 22.43 cm (14.17 x 8.83 in)
500g (1.10 lb)
Diagonal Size
(39.6 cm (15.6 in )
Surface Treatment
Anti-glare
Contrast Ratio
400:1 (min)
Refresh Rate
60 Hz
Brightness
200 nit (typical)
Pixel Resolution
Pitch
0.252 mm
Format
1366 x 768
Configuration
RGB Stripe
Backlight
LED
PPI
106 ppi
Viewing Angle
±30° Horizontal, ±10° Vertical (minimum)
30/30/20/10 (Left/Right/Down/Up) (minimum)
45/45/35/25 (Left/Right/Down/Up) (typical)
Storage and drives
500 GB 5400 rpm SATA hard drive
Drive Weight
101 g (0.22 lb)
Capacity
500 GB
Height
7 mm ( 0.27 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer Rate
Maximum
300 MB/s (Drive Capability)
Rotational Speed
5400 rpm
Logical Blocks
976,773,168
Operating Temperature
0° to 60° C (32° to 140° F) [case temp]
Seek Time
(typical reads, including settling)
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Features
ATA Security
500 GB 7200 rpm SATA Hard Drive
Drive Weight
115 g (0.25 lb)
Capacity
500 GB
Height
7 mm (0.27 in)
Width
70 mm (2.75 in)
Interface
Transfer Rate
Maximum
Rotational Speed
7200 rpm
Logical Blocks
976,773,168
Seek Time
Single Track
1.5 ms
Average
11 ms
Maximum
22 ms
Features
ATA Security
1 TB 5400 rpm SATA Hard Drive
Drive Weight
115 g (0.25 lb)
Capacity
1 TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer Rate
Maximum
Rotational Speed
5400 rpm
Logical Blocks
1,953,525,168
Seek Time
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Features
ATA Security
Networking/communications
Wireless LAN standards
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
  • 2.402 – 2.482 GHz
    The United States Federal Communication Commissions (FCC) has declared as of September 1, 2014, products that utilize passive scanning on channel 12/13 and are capable of transmitting must fully comply with requirements of 15.247 or otherwise disable those channels.
Data rates
802.11b: 1, 2, 5.5, 11 Mbps
802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
802.11n: MCS 0 ~ MCS 07, (20MHz)
Modulation
Direct Sequence Spread Spectrum BPSK, QPSK, CCK, 16-QAM, 64-QAM
Security
  • IEEE and Wi-Fi compliant 64 / 128 bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through CCX4 and CCX Lite
  • WAPI
Network architecture models
Ad-hoc (peer to peer)
Infrastructure (access point required)
Roaming
IEEE 802.11 compliant roaming between access points
Output power
  • 802.11b : +16dBm minimum
  • 802.11g : +14dBm minimum
  • 802.11a : +14dBm minimum
  • 802.11n HT20(2.4GHz) : +13dBm minimum
  • 802.11n HT40(2.4GHz) : +13dBm minimum
  • 802.11n HT20(5GHz) : +12dBm minimum
  • 802.11n HT40(5GHz) : +12dBm minimum
Power consumption
Transmit: 2.0 W (max)
Receive: 1.6 W (max)
Idle mode (PSP): 180 mW (WLAN Associated)
Idle mode: 60 mW (WLAN unassociated)
Radio disabled: 30 mW
Power management
ACPI and PCI Express compliant power management 802.11 compliant power saving mode
Receiver sensitivity
802.11b, 1Mbps : -94dBm maximum
802.11b, 11Mbps : -86dBm maximum
802.11g, 6Mbps : -88dBm maximum
802.11g, 54Mbps : -74dBm maximum
802.11a, 6Mbps : -86dBm maximum
802.11a, 54Mbps : -72dBm maximum
802.11n, MCS07 : -69dBm maximum
802.11n, MCS15 : -66dBm maximum
Antenna type
High efficiency antenna with spatial diversity, mounted in the display enclosure
Two embedded antennas for 2.4GHz are provided to the card to support WLAN and Bluetooth communications. (Support dual antenna or single antenna, depend on platform requirement)
Form factor
PCI-Express M.2 Mini Card
Dimensions
Type 2230: 2.3 x 22.0 x 30.0 mm
Type 1630: 2.3 x 16.0 x 30.0 mm
Type 2230: 2.8 g
Type 1630: 2 g
Operating voltage
3.3v +/- 9%
Temperature
Operating: –10° to 70° C (14° to 158° F)
Non-operating: –40° to 80° C (–40° to 176° F)
Humidity
Operating: 10% to 90% (non-condensing)
Non-operating: 5% to 95% (non-condensing)
Altitude
Operating: 0 to 3,048 m (10,000 ft)
Non-operating: 0 to 15,240 m (50,000 ft)
LED activity
LED Amber – Radio OFF; LED White – Radio ON
Realtek 802.11b/g/n (1x1) + Bluetooth Combo
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
  • 2.402 – 2.482 GHz
Data rates
Modulation
Security
  • IEEE 802.11i
  • WAPI
Roaming
Output power
Power consumption
Power management
Antenna type
Form factor
Dimensions
Type 2230: 2.8 g
Type 1630: 2 g
Operating voltage
3.3v +/- 9%
Temperature
Humidity
Altitude
LED activity
HP Integrated Module with Bluetooth 4.0+EDR Wireless Technology
Bluetooth specification
4.0+EDR Compliant
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
3 Mbps data rate; throughput up to 2.17 Mbps
Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit power
The Bluetooth component shall operate as a Class II Bluetooth device with a maximum transmit power of +4 dBm for BR and EDR.
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Selective Suspend 17 mW
Range
Up to 10 m (33 ft)
Electrical interface
USB 2.0 compliant
Bluetooth software supported link topology
Microsoft Windows Bluetooth Software
Point to Point, Multipoint Pico Nets up to 7 slaves
Bluetooth software supported security
Full support of Bluetooth Security Provisions
Power management
Microsoft Windows ACPI, and USB Bus Support
Power management certifications
Self-configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Security
All necessary regulatory approvals for supported countries
Bluetooth profiles supported certifications
FCC (47 CFR) Part 15C, Section 15.247 & 15.249
ETS 300 328, ETS 300 826
Low Voltage Directive IEC950
UL, CSA, and CE Mark
Serial Port Profile (SPP)
Service Discovery Application Profile (SDAP)
Dial-Up Networking (DUN)
Generic Object Exchange Profile (GOEP)
Object Push Profile (OPP)
File Transfer Profile (FTP)
Synchronization Profile (SYNC)
Hard Copy Cable Replacement (HCRP)
Personal Area Networking Profile (PAN)
Human Interface Device Profile (HID)
FAX Profile (FAX)
Basic Imaging Profile (BIP)2
Headset Profile (HSP)
Hands Free Profile (HFP)
Advanced Audio Distribution Profile (A2DP)
HP Integrated Module with Bluetooth 4.0+EDR wireless technology
4.0+EDR compliant
Frequency band
2402 to 2480 MHz
Transmit power
The Bluetooth component operates as a Class II Bluetooth device with a maximum transmit power of +4 dBm for BR and EDR.
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Range
Up to 10 m (33 ft)
Microsoft Windows Bluetooth software
USB 2.0 compliant
Power management
Microsoft Windows ACPI, and USB bus support
Security certifications
All necessary regulatory approvals for supported countries/regions, including FCC (47 CFR) Part 15C, Section 15.247 & 15.249
Full support of Bluetooth security provisions
Certifications
FAX Profile (FAX)
Broadcom 802.11 b/g/n (1x1) + Bluetooth combo
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
  • 2.402 – 2.482 GHz
    The FCC has declared as of January 1, 2015, products that utilize passive scanning on channel 12/13 and are capable of transmitting must fully comply with requirements of 15.247 or otherwise disable those channels.
802.11a/n
  • 4.9 – 4.95 GHz (Japan)
  • 5.15 – 5.25 GHz
  • 5.25 – 5.35 GHz
  • 5.47 – 5.725 GHz
  • 5.825 – 5.850 GHz
    Indonesia supports only 5.725 - 5.825 GHz (CH149 - CH161)
Data rates
  • 802.11b: 1, 2, 5.5, 11 Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11n: MCS 0 ~ MCS 07, (20MHz)
Modulation
Security
  • IEEE 802.11i
  • WAPI
Roaming
Output power
Power consumption
Idle mode (PSP): 180 mW (WLAN associated)
Power management
Antenna type
Two embedded antennas for 2.4GHz are provided to the card to support WLAN and Bluetooth communications. (Supports dual antenna or single antenna, depending on platform requirement)
Form factor
Dimensions
Type 2230: 2.8 g
Type 1630: 2 g
Operating voltage
3.3v +/- 9%
Temperature
Humidity
Altitude
LED activity
4.0+EDR compliant
Frequency band
2402 to 2480 MHz
Transmit power
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Range
Up to 10 m (33 ft)
USB 2.0 compliant
Power management
Certifications
FAX Profile (FAX)
Broadcom 802.11 a/b/g/n (2x2) + Bluetooth combo
IEEE 802.11a
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
  • 2.402 – 2.482 GHz
802.11a/n
  • 5.15 – 5.25 GHz
  • 5.25 – 5.35 GHz
  • 5.47 – 5.725 GHz
  • 5.825 – 5.850 GHz
Antenna Structure
2 transmit; 2 receive (2x2)
Data rates
802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
Modulation
Security
WPA2 certification
IEEE 802.11i
WAPI
Roaming
Output power
802.11n HT20 (2.4GHz) : +13dBm minimum
802.11n HT40 (2.4GHz) : +13dBm minimum
802.11n HT20 (5GHz) : +12dBm minimum
802.11n HT40 (5GHz) : +12dBm minimum
Power consumption
Power management
Antenna type
Form factor
Dimensions
Type 2230: 2.8 g
Type 1630: 2 g
Operating voltage
3.3v +/- 9%
Temperature
Humidity
Altitude
LED activity
4.0+EDR compliant
Frequency band
2402 to 2480 MHz
Transmit power
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Range
Up to 10 m (33 ft)
USB 2.0 compliant
Power management
Certifications
All necessary regulatory approvals for supported countries/regions, including FCC (47 CFR) Part 15C, Section 15.247, and 15.249
Security
FAX Profile (FAX)
Realtek Ethernet (10/100/1000)
Ethernet features
10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
1000 Mbit/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023 clauses 40)
Auto-Negotiation (Automatic Speed Selection)
Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
IEEE 802.1p QoS (Quality of Service) Support
IEEE 802.1q VLAN support
IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
IEEE 802.3az EEE (Energy Efficient Ethernet)
Jumbo Frame 9K
Auto MDI/MDIX Crossover cable detection
Power management
ACPI compliant - multiple power modes
Situation-sensitive features reduce power consumption
Advanced link down power saving for reducing link down power consumption
Performance features
TCP/IP/UDP Checksum Offload (configurable)
Protocol Offload (ARP & NS)
Large send offload and Giant send offload
Receiving Side Scaling
Manageability
Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft
Wake-Up Frame; Wake-on-LAN from off (Magic Packet only)
PXE 2.1 Remote Boot
Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
Comprehensive diagnostic and configuration software suite
Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 to fully support ASPM L0s/L1 and CLKREQ
NIC Device Driver Name
Realtek PCIe GBE Ethernet Family Controller
Audio hardware
Specification
Implementation
Conexant
Function key volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone In
Stereo
Headphone/line Out
Stereo
Yes, dual digital microphone array
Audio Output Quality
Specification
Frequency response
20Hz – 20kHz
Signal to noise ratio
106 dB (DAC), 102dB (ADC)
Total harmonic distortion
91dB THD+n on Line Out/HP (0.003%)
Play sampling rate(s)
Record sampling rate(s)
Up to 192kHz
Up to 96Khz
DAC
16, 20 or 24-bit
ADC
16, 20 or 24-bit
Integrated Stereo Speakers
Specification
Power Rating
2 Watts
Impedance
4 Ohms
Power
Item
Specification
Dimensions
126.5 x 50 x 30 mm (4.98 x 1.97 x 1.18 in)
290g (0.62 lb) max
Input
90 to 265 VAC
Input Efficiency
87% min at 115 VAC
Input frequency range
47 to 63 Hz
Input AC current
1.7 A at 90 VAC
Output
Output power
65W
DC output
19.5V
Hold-up time
5 msec at 115 VAC input
Output current limit
< 11.0A
Over voltage protection
< 29V max automatic shutdown
Over short protection
Auto-recovery and no damage
Connector
3 pin/grounded, mates with interchangeable cords
Environmental Design
Operating temperature
Non-operating (storage) temperature
-20° to 85° C (-4° to 185° F)
Altitude
0 to 5,000 m (0 to 16,400 ft)
Humidity
20% to 95%
Storage Humidity
10% to 95%
EMI and Safety Certifications
CE Mark - full compliance with LVD and EMC directives
Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE.
MTBF - over 200,000 hours at 25°C ambient condition
Item
Specification
Dimenstions
9.5 x 4.0 x 2.65 cm (3.74 x 1.57 x 1.04 in)
175g (0.386 lb) max
Input
90 to 265 VAC
Input Efficiency
87.74% at 115Vac and 88.4% at 230Vac
47 to 63 Hz
Input AC current
1.4 A at 90 VAC
Output
Output power
45W
DC output
19.5V
Hold-up time
< 8.0A
Connector
Altitude
Humidity
20% to 95%
Storage Humidity
10% to 95%
Item
Specification
HP 4-cell, Long Life 44 WHr Li-ion
Dimensions
33.40 x 275.80 x 20.60 mm (1.32 x 10.86 x 0.81 inch)
0.3 kg (0.66 lb)
Cells/type
4 cell Lithium-Ion
Energy
Voltage
14.8V
Amp-hour capacity
3.0Ah
Watt-hour capacity
44Wh
Temperature
Operating (Charging)
0˚ to 45˚ C (32˚ to 113˚ F)
Operating (Discharging)
-10˚ to 60˚ C (14˚ to 122˚ F)
Non-operating
-20˚ to 60˚ C (-4˚ to 122˚ F)
Battery Re-Charge Time
System in OFF or Standby Mode
< 3 hours
Fuel Gauge LED
No
1 year
Optional Travel Battery Available
No
Item
Specification
HP 6-cell, Long Life 55 WHr Li-ion
Dimensions
45.59 x 275.8 x 33.89 mm (1.79 x 10.85 x 1.33 in)
330g (0.72 lb)
Cells/type
Cylindrical ICR18650 C4
Energy
Voltage
10.68V
Amp-hour capacity
5.15Ah
Watt-hour capacity
55Wh
Temperature
Non-operating
3 hours
System ON
3 to 5 hours
Fuel Gauge LED
N/A
3 years to 1000 cycles
No
