HP 25vx LED Backlit Monitor - Product Specifications
The HP 25vx is a 63.5 cm (25 in) LED Backlit monitor.
Figure : HP 25vx LED Backlit Monitor
25vx monitor front view
M6V68AA
Technical specifications
LED feature
Specification
Display size
63.5 cm (25 in) diagonal
Panel active area (width x height): 55.3 cm x 31.1 cm (21.8 in x 12.2 in)
Display type
LED Backlight
Aspect ratio
16:9
Brightness
250 nits
Color gamut
72%
Color support
16.7 M colors
Viewing angle
Horizontal: 178 degrees
Vertical: 178 degrees
Inputs
1 VGA
1 DVI-D
1 HDMI (with HDCP support)
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 8,000,000:1
Response time
7 ms gray to gray (with OD)
14 ms gray to gray (typical)
28 ms gray to gray (max)
Pixel pitch
0.288 mm
Pixels per inch
88
Power consumption
30 W max
Tilt
-5 to +25 degrees
Dimensions
H x W x D (unpacked):
42.9 x 57.7 x 19.3 cm (16.9 x 22.7 x 7.6 in)
Unpacked: 4.4 kg (9.7 lb)
Country: Flag Vietnam
