    Apache Log4j Update
HP ENVY Notebook 15-ae019tx Product Specifications
Product Name
15-ae019tx
Product Number
N1V51PA
2.4 GHz Intel Core i7-5500U with Intel HD Graphics 5500
Microprocessor Cache
4 MB cache, 2 cores
Memory
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video Graphics
NVIDIA GeForce GTX 950M (4 GB DDR3L dedicated)
15.6" diagonal FHD anti-glare WLED-backlit (1920 x 1080)
Hard Drive
1 TB 5400 rpm SATA
Network Card
Integrated 10/100/1000 Gigabit Ethernet LAN
Wireless Connectivity
802.11a/b/g/n/ac (1x1) and Bluetooth 4.0 combo (Miracast compatible)
WiDi
Sound
Bang & Olufsen with 4 speakers and 1 subwoofer
Keyboard
Island-style backlit keyboard with integrated numeric keypad
Pointing Device
External Ports
4 USB 3.0 (1 HP USB Boost)
1 HDMI
1 RJ-45
1 headphone/microphone combo
Dimensions
38.4 x 25.5 x 2.29 cm
Starting at 2.19 kg
Power
90 W AC power adapter
3-cell, 55.5 Wh prismatic
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Operating System:
Windows 8.1 (64-bit)
