HP 22uh LED Backlit Monitor - Product Specifications
The HP 22uh is a 54.6 cm (21.5 in) LED Backlit monitor.
Figure : HP 22uh LED Backlit Monitor
22uh monitor front view
L3N74AA
Features
The 22uh LED Backlit Monitor has the following features:
  • Multilingual OSD adjustment
  • Compatible with IBM VGA, extended VGA, VESA VGA, SVGA, XGA, and WXGA modes
  • Wide range of applicable voltages (AC 100-240V 50/60Hz ) enables direct use without any setting
  • Plug-and-play VESA DDC1/ 2B Standard
Technical specifications
Feature
Specification
Display size
54.6 cm (21.5 inch) diagonal
Panel active area (W x H): 56.8 cm x 37.8 cm (22.4 in x 14.9 in)
Display type
LED Backlight
Brightness
250 cd/m²
Inputs
1 VGA
1 DVI
1 HDMI
Horizontal frequency
24-80 kHz
Vertical frequency
50-76 Hz
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz
Contrast ratio
Up to 1000:1
Response time
5 ms
Power consumption
30 W
Operating temperature
0 degrees C to 40 degrees C (32 degrees F to 104 degrees F)
Storage temperature
-20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Relative Humidity
10 to 90%
Dimensions
H x W x D (unpacked):
37.8 x 56.8 x 15.5 cm (14.9 x 22.4 x 6.1 in)
Unpacked: 3.0 kg (6.6 lb)
