HP L5015tm 15-inch Retail Touch Monitor - Specifications
Product details
Specification
Model
1517L
Colors
Black (Elo standard color)
LCD panel
Active matrix TFT LCD with LED backlighting
15-inch
Aspect ratio
4:3
Useful screen area
228 x 304 mm (8.98 x 11.97 in)
Native (optimal) resolution
1024 x 768
Other supported resolutions
1024 x 768 at 60Hz, 75Hz
800 x 600 at 56Hz, 60Hz, 75Hz
720 x 400 at 70Hz
640 x 480 at 60Hz, 75Hz
Colors
16.2 million
Brightness (typical)
LCD panel: 250 nits
with AccuTouch: 200 nits
with IntelliTouch: 225 nits
with iTouch: 225 nits
Response time - total (typical)
16 msec
Viewing angle (typical)
Horizontal: +/-80° or 160° total
Vertical: +/-70° or 140° total
Contrast ratio (typical)
700:1
On-screen display (OSD)
Controls: menu, up, down, select, power
Setting: contrast, brightness, H-position, V-position, auto-adjust, aspect ratio, sharpness, color, temperature, clock, phase, OSD timeout, OSD language, recall, defaults
Languages: English, French, Italian, German, Spanish, Japanese, Traditional Chinese, Simplified Chinese
Input video format
Analog VGA on female DE-15 connector
Video input frequency
Input video horizontal frequency range: 31.5-60 kHz
Input video vertical frequency range (frame rate): 56-75 Hz
Touch interface
Serial (RS232) and USB
Power supply
Internal AC; optional external DC brick
Input voltage
AC: 100-240 VAC, 50/60 Hz
DC: +12VDC +/-5%
Input connector
AC: IEC 60320 C6
DC: Coaxial power jack (2 mm pion diameter; 6.4 mm barrel diameter, 8.8 mm barrel length)
Power consumption (typical)
On (monitor only): 12 W
Sleep (monitor only): 1.7 W
Off (monitor only): 1.3 W
Monitor dimensions (with stand)
358 x 197 x 319 mm (14.1 x 7.8 x 12.5 in)
Shipping box dimensions (W x D x H)
455 x 228 x 416 mm (17.9 x 9 x 16.4 in)
Unpackaged: 4.3 kg (9.5 lb)
Packaged; 7.3 kg (16 lb)
Temperature
Operating: 0° - 40° C (32° - 104° F)
Storage: -20° - 60° C (-4° - 140° F)
Humidity (non-condensing)
Operating: 20% - 80%
Storage: 10% - 90%
MTBF
50,000 hours demonstrated
Mounting option
75 mm VESA mount
Agency certifications
Argentinian S-Mark, Australia C-Tick, Canada cUL, IC, China CCC, Europe CE, Japan VCCI, Korea KCC, e-Standby, Mexico CoC, Taiwan BSMI Mark, United States UL, FCC, International CB
RoHS, China RoHS, WEEE, IMERC
Country: Flag Vietnam
