HP and Compaq Desktop PCs - Motherboard Specifications, (March)
Figure : The March motherboard
Motherboard description
Manufacturer: Pegatron
HP name: March
SSID: 2B3B
Form Factor
Femto AIX15: 16x16 cm (6.3x6.3 in)
The chipset on this motherboard is combined with the processor into a single integrated circuit called System on a Chip (SoC). This technology combines the processor and chipset functionality into a single physical package.
Processor upgrade information
The motherboard supports the AMD Beema E2-6110, AMD Beema A4-6210, and AMD Beema A6-6310 APUs only. The processor is not upgradable.
Memory upgrade information
Single channel memory architecture
Two 204-pin DDR3 SODIMM sockets
Non-ECC memory only, unbuffered
Supports the following:
E2-6110 APU: Supports up to PC3-12800 (DDR3-1600)
A4-6210 APU: Supports up to PC3-12800 (DDR3-1600)
A6-6310 APU: Supports up to PC3-14900 (DDR3-1866)
Supports 1 GB, 2 GB, 4 GB and 8 GB SODIMMs
Supports up to 4 GB on 32-bit systems
32-bit systems cannot address a full 4.0 GB of memory.
Supports up to 16 GB (unbuffered) on 64-bit systems
Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
Video
Integrated AMD Graphics
AMD Beema E2-6110: Integrated AMD Radeon R2 Series Graphics
AMD Beema A4-6210: Integrated AMD Radeon R3 Series Graphics
AMD Beema A6-6310: Integrated AMD Radeon R4 Series Graphics
Audio
Realtek ALC3228-CG audio
Audio Codec: Realtek ALC3228-CG
Built-in speaker amplifier with 1.5 W per channel
Audio jack presence detection
Network
LAN: 1000BASE-T
Technology: Realtek RTL8161GSH
Data transfer speeds: up to 10/100/1000 Mb/s
Transmission standards: 1000BASE-T Ethernet
Expansion Slots
One M.2 slot for WLAN
I/O Ports and Jumpers
Side I/O ports
Figure : March side I/O panel
Headphone/Microphone jack
Memory card reader
USB 3.0: 2
HDD LED
Back I/O ports
Figure : March back I/O panel
DC power in
Power LED
LAN (Ethernet)
HDMI
USB 2.0: 3
Jumpers
Figure : Clear CMOS and clear password jumpers in the default positions
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
