This document provides the procedures to remove and replace the Tray 1 rollers.
Before performing service
Turn the printer power off
Disconnect the power cable.
warning:
To avoid damage to the printer, turn the printer off, wait 30 seconds, and then remove the power cord before attempting to service the printer.
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
Tray 1 rollers part number
E6B67-67906
Tray 1 rollers with instruction guide
Required tools
#2 Phillips screwdriver with a magnetic tip
After performing service
Turn the printer power on
Connect the power cable.
Use the power switch to turn the power on.
Post service test
Make sure that the printer initializes to a Ready state.
Print a configuration page to make sure that the printer is functioning correctly.
