HP LaserJet Enterprise M604, M605, M606 - Printer specifications
The following specifications are correct at the time of publication, but they are subject to change. For current information, see www.hp.com/support/ljM604, www.hp.com/support/ljM605, www.hp.com/support/ljM606.
Technical specifications
Model name
M604n, M605n
E6B67A, E6B69A
M604dn, M605dn, M606dn
E6B68A, E6B70A, E6B72A
M605x, M606x
E6B71A, E6B73A
Paper handling
Tray 1 (100-sheet capacity)
Tray 2 (500-sheet capacity)
1 x 500-sheet paper feeder
The printer supports up to four optional paper feeders.
Optional
Optional
1,500-sheet high-capacity feeder
This accessory can be combined with up the three 1 x 500-sheet paper feeders.
Optional
Optional
Optional
Printer stand
Optional
Optional
Optional
Automatic duplex printing
Optional
Envelope feeder for printing up to 75 envelopes
Optional
Optional
Optional
Custom media tray for printing small-size paper (replaces the standard Tray 2)
Optional
Optional
Optional
500-sheet stapler/stacker
Optional
Optional
Optional
500-sheet stacker
Optional
Optional
Optional
500-sheet 5-bin mailbox
Optional
Optional
Optional
Connectivity
10/100/1000 Ethernet LAN connection with IPv4 and IPv6
Hi-Speed USB 2.0
Easy-access USB port for printing without a computer and upgrading the firmware
Hardware Integration Pocket for connecting accessory and third-party devices
HP Internal USB Ports
Optional
Optional
Optional
HP Jetdirect 3000w NFC/Wireless Accessory for printing from mobile devices
Optional
Optional
Not supported
Integrated HP near-field communication (NFC) and Wi-Fi Direct functionality for printing from mobile devices
Not supported
Not supported
HP Jetdirect 2900nw Print Server accessory for wireless connectivity
Optional
Optional
Optional
Memory
512 MB base memory, expandable to 1.0 GB or 1.5 GB by adding DIMM memory modules
HP Secure High-Performance Hard Disk
Optional
Optional
Optional
Security
HP Trusted Platform Module for encrypting all data that passes through the printer
Optional
Optional
Optional
Control-panel display and input
4-line graphical display with 10-key keypad
Not supported
Constant-view, color touchscreen control panel
Not supported
Not supported
Print
Prints 50 pages per minute (ppm) on A4 and 52 ppm on letter-size paper
M604n
M604dn
Prints 56 ppm on A4 and 58 ppm on letter-size paper
M605n
M605dn
M605x
Prints 63 ppm on A4 and 65 ppm on letter-size paper
M606dn
M606x
Easy-access USB printing (no computer required)
Supported operating systems
The following information applies to the Product-Specific Windows PCL 6 and OS X print drivers and to the in-box software installation CD.
Windows: The HP Software Installer CD installs the “HP PCL.6” or “HP PCL 6” version 3 driver, depending on the Windows operating system, along with optional software when using the full software installer. Download the “HP PCL-6” version 4 print driver from the printer-support Web site for this printer: www.hp.com/support/ljM604, www.hp.com/support/ljM605, www.hp.com/support/ljM606.
Mac computers and OS X: Mac computers and Apple mobile devices are supported with this printer. The OS X print driver and print utility are available for download from hp.com and may also be available via Apple Software Update. The HP installer software for OS X is not included in the in-box CD. Follow these steps to download the OS X installer software:
  1. Select Support Options, and then under Download Options select Drivers, Software & Firmware.
  2. Click the operating system version, and then click the Download button.
Driver installed
Notes
Windows® XP SP3, 32-bit
The “HP PCL.6” printer-specific print driver is installed for this operating system as part of the basic software installation. The basic installer installs the driver only.
The full software installer is not supported for this operating system.
Use UPD drivers for 64-bit operating systems.
Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the discontinued XP operating system.
Windows Vista®, 32-bit
Windows Server 2003 SP2, 32-bit
Microsoft retired mainstream support for Windows Server 2003 in July 2010. HP will continue to provide best effort support for the discontinued Server 2003 operating system.
Windows 7 SP1, 32-bit and 64-bit
The “HP PCL 6” printer-specific print driver is installed for this operating system as part of the full software installation.
Windows 8, 32-bit and 64-bit
Windows 8 RT support is provided through Microsoft IN OS Version 4, 32- bit driver.
Windows 8.1, 32-bit and 64-bit
Windows 8.1 RT support is provided through Microsoft IN OS Version 4, 32- bit driver.
Windows Server 2008 SP2, 32-bit
Windows Server 2008 SP2, 64-bit
Windows Server 2008 R2, SP 1, 64-bit
Windows Server 2012, 64-bit
The software installer does not support Windows Server 2012 but the “HP PCL 6” version 3 and “HP PCL-6” version 4 printer-specific print drivers do support it.
Download the driver from the HP Web site, and use the Windows Add Printer tool to install it.
Windows Server 2012 R2, 64 bit
The software installer does not support Windows Server 2012 but the “HP PCL 6” and “HP PCL-6” version 4 printer-specific print drivers do support it.
OS X 10.7 Lion, OS X 10.8 Mountain Lion, and OS X 10.9 Mavericks
For OS X, download the full installer from the support Web site for this printer.
For a current list of supported operating systems, go to www.hp.com/support/ljM604, www.hp.com/support/ljM605, www.hp.com/support/ljM606 for HP's all-inclusive help for the printer.
For details on client and server operating systems and for HP UPD PCL6, UPD PCL 5, and UPD PS driver support for this printer, go to www.hp.com/go/upd. Under Additional information, click Link to Supported products.
Mobile printing solutions
The printer supports the following software for mobile printing:
  • HP ePrint software
    The HP ePrint Software supports the following operating systems: Windows 7 SP 1 (32-bit and 64-bit); Windows 8 (32-bit and 64-bit); Windows 8.1 (32-bit and 64-bit); and OS X versions 10.6 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, and 10.9 Mavericks.
  • HP ePrint via email (Requires HP Web Services to be enabled and the printer to be registered with HP Connected)
  • HP ePrint app (Available for Android, iOS, and Blackberry)
  • ePrint Enterprise app (Supported on all printers with ePrint Enterprise Server Software)
  • HP Home and Biz app (Available for Symbian/Nokia devices)
  • Google Cloud Print 1.0 (Requires the printer to be registered with HP Connected and then registered with Google Cloud)
  • AirPrint
  • Android Printing
Printer dimensions
The following illustrations show the dimensions for the printers as sold, for the optional input and output accessories, and for several sample configurations of the printer combined with optional accessories.
Dimensions for the printers, as sold
Dimensions for the n models
Figure : Dimensions for the n models
Printer fully closed
Printer fully opened
1. Height
399 mm
574 mm
2. Depth
451 mm
754 mm
3. Width
425 mm
425 mm
22.6 kg
Dimensions for the dn models
Figure : Dimensions for the dn models
1. Height
399 mm
574 mm
2. Depth
537 mm
840 mm
3. Width
425 mm
425 mm
25.9 kg
Dimensions for the x models
Figure : Dimensions for the x models
1. Height
521 mm
695 mm
2. Depth
537 mm
840 mm
3. Width
425 mm
425 mm
32.5 kg
Dimensions for the input and output accessories
Dimensions for the 1 x 500-sheet paper feeder
Figure : Dimensions for the 1 x 500-sheet paper feeder
1. Height
121 mm
2. Depth
Tray closed: 448 mm
Tray opened: 864 mm
3. Width
415 mm
6.7 kg
Dimensions for the 1,500-sheet high-capacity input tray
Figure : Dimensions for the 1,500-sheet high-capacity input tray
1. Height
264 mm
2. Depth
Door closed: 448 mm
Door opened: 902 mm
3. Width
415 mm
13 kg
Dimensions for the stacker
Figure : Dimensions for the stacker
1. Height
304 mm
2. Depth
430 mm
3. Width
378 mm
3.2 kg
Dimensions for the stapler/stacker
Figure : Dimensions for the stapler/stacker
1. Height
371 mm
2. Depth
430 mm
3. Width
387 mm
4.2 kg
Dimensions for the 5-bin mailbox
Figure : Dimensions for the 5-bin mailbox
1. Height
522 mm
2. Depth
Rear door closed: 306 mm
Rear door opened: 589 mm
3. Width
353 mm
7.0 kg
Dimensions for the printer stand
Figure : Dimensions for the printer stand
1. Height
114 mm
2. Depth
653 mm
3. Width
663 mm
13.6 kg
Dimensions for sample combinations of the printers and optional accessories
The following information is for samples of various combinations of the printer and accessories. Several other combinations are possible. Use the information for the individual accessories to calculate dimensions for other combinations.
Combination one
Includes the printer plus these accessories:
  • One 1 x 500-sheet paper feeder
  • The 1,500-sheet high-capacity tray
  • The stacker output accessory
Dimensions for Combination one
Figure : Dimensions for Combination one
Printer and accessories closed
Printer and accessories fully opened
1. Height
1089 mm
1089 mm
2. Depth
537 mm
902 mm
3. Width
425 mm
425 mm
48.7 kg
Combination two
  • The stapler/stacker output accessory
Dimensions for Combination two
Figure : Dimensions for Combination two
1. Height
1156 mm
1156 mm
2. Depth
537 mm
902 mm
3. Width
425 mm
425 mm
49.7 kg
Combination three
  • The 5-bin mailbox output accessory
Dimensions for Combination three
Figure : Dimensions for Combination three
1. Height
1367 mm
1367 mm
2. Depth
537 mm
1468 mm
3. Width
425 mm
425 mm
52.5 kg
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Power consumption (average, in watts)1, 2, 3
Printer Series4
Printing
Sleep
Auto Off/Wake on LAN
Auto Off/Manual On
Off
720 W
3.9 W
0.7 W
Less than 0.1 W
Less than 0.1 W
HP LaserJet Enterprise M605
840 W
3.7 W
0.7 W
Less than 0.1 W
Less than 0.1 W
HP LaserJet Enterprise M606
870 W
3.7 W
0.7 W
Less than 0.1 W
Less than 0.1 W
1Values subject to change.
2Power reported is highest value measured for all printer models using standard voltages.
3Default time from Ready mode to Sleep = 1 minute
4Speed is: M604 – 50 ppm A4 size and 52 ppm Letter-size; M605 – 55 ppm A4 size and 58 ppm Letter-size; M606 – 62 ppm A4 size and 65 ppm Letter-size.
Electrical specifications
110-volt input voltage: 100 to 127 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
220-volt input voltage: 220 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and void the product warranty.
Acoustic emissions
HP LaserJet Enterprise M6041
Sound power level
Printing (50 ppm)
Ready
Declared per ISO 9296
LWAd = 7.1 Bels (A) [71 dB(A)]
LWAd = 4.2 Bels (A) [42 dB(A)]
Sound pressure level - Bystander position
Printing (50 ppm)
Ready
LpAm = 56 dB(A)
LpAm = 28 dB(A)
1Acoustic values are subject to change. Configuration tested: HP LaserJet Enterprise M604dn, printing on A4-size paper at 50 ppm in simplex mode.
HP LaserJet Enterprise M6051
Sound power level
Printing (56 ppm)
Ready
Printing (56 ppm)
Ready
LpAm = 56 dB(A)
LpAm = 27 dB(A)
1Acoustic values are subject to change. Configuration tested: HP LaserJet Enterprise M605x printing on A4-size paper at 56 ppm in simplex mode.
HP LaserJet Enterprise M6061
Sound power level
Printing (63 ppm)
Ready
Printing (63 ppm)
Ready
LpAm = 56 dB(A)
LpAm = 27 dB(A)
1Acoustic values are subject to change. Configuration tested: HP LaserJet Enterprise M606x, printing on A4-size paper at 63 ppm in simplex mode.
Operating-environment range
Operating-environment specifications
Environment
Recommended
Allowed
Temperature
15° to 30°C
15° to 32°C
Relative humidity
10% to 80% relative humidity (RH)
5% to 90% RH
Altitude
Not applicable
0 to 3048 m
