HP Z32s 31.5-inch IPS UHD Display - Overview
Product description
Product features
Feature
Type
31.5-inch IPS w/LED backlight
Viewable image area
80 cm (31.5 in) widescreen; diagonally measured
Panel active area (W x H)
69.69 x 39.2 cm (27.43 × 15.43 in)
Resolution
3840 x 2160 at 60 Hz (UHD)
Aspect ratio
16:9
Viewing angle*
Up to 178° horizontal/178° vertical typical
Brightness*
300 cd/m2
Contrast ratio (typical)*
1000:1 Static; 5,000,000:1 Dynamic (DCR)
Response times*
8 ms typical (G-to-G)
Pixel pitch*
0.182 ms
Pixels per inch (PPI)*
140
Backlight lamp life (to half brightness)*
40,000 hours to minimum
Color gamut (typical)*
Adobe RGB
Color support*
10-bit color depth
* Performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
