HP Z228 Microtower Workstation - Specifications
Product Details
Specification
Monitors/displays
HP DreamColor LP2480zx Professional Display
HP Z Display Z30i 30-inch IPS LED Backlit Monitor
HP Z Display Z27i 27-inch IPS LED Backlit Monitor
HP Z Display Z24i 24-inch IPS LED Backlit Monitor
HP Z Display Z23i 23-inch IPS LED Backlit Monitor
HP Z Display Z22i 21.5-inch IPS LED Backlit Monitor
HP ZR2740w 27-inch LED Backlit IPS Monitor
HP ZR2440w 24-inch LED Backlit IPS Monitor
HP ZR2330w 23-inch IPS LED Backlit Monitor
Multimedia and audio devices
Integrated Realtek HD ALC221 Audio
Controller cards
HP IEEE 1394b FireWire PCIe Card
Racking and physical security
HP Business PC Security Lock Kit
Input devices
HP USB 1000dpi Laser Mouse
HP USB Optical 3-Button Mouse
HP USB Optical Mouse
HP PS/2 Mouse
HP USB Keyboard
HP PS/2 Keyboard
Other hardware
HP Power Cord Kit
HP Serial Port Adapter
CECP Qualified Configuration
HP Performance Advisor
HP Remote Graphics Software (RGS) 6.0
PDF Complete - Corporate Edition
MS Office Home & Business 2013
Cyberlink PowerDVD and Power2Go
HP PC Hardware Diagnostics UEFI
HP Client Security Software
Operating systems
Genuine Windows 7 Professional 64-bit
Windows 8.1 Pro 64-bit
Windows 8.1 Simplified Chinese Edition 64-bit
Ubuntu 14.04
System board form factor
ATX 24.38 x 24.38 mm (9.6 x 9.6 in)
Processor socket
Single LGA 1150
CPU bus speed
DMI
Intel PCH C226
PCI express connectors
PCI Express Gen3 x16 slot (x16 electrical/x16 mechanical) - 1
PCI Express Gen2 x16 slot (x4 electrical/x16 mechanical) - 1
PCI Express Gen2 x1 slot (x1 electrical/x4 mechanical) - 1
PCI Express Gen2 x1 slots (x1 electrical/x1 mechanical) - 1
IEEE 1394 connector(s)
Internal: USB 2.0 - 2
HD integrated audio
Integrated TPM 1.2
CMOS battery holder - Lithium
USB or PS/2
Integrated trusted platform module
280 W, 90% efficiency, wide-ranging, active PFC Power Supply
280W Standard Efficiency wide-ranging, active PFC Power Supply option available in some countries.
Power supply headers
90-264 VAC
Power switch, power LED & hard drive LED header
100–240 VAC
Clear password jumper
50-60 Hz
Keyboard/mouse
47–63 Hz
Operating voltage range
Typical: 444 btu/hr (112 kcal/hr)
Maximum: 890 btu/hr (224 kcal/hr)
Rated voltage range
80 x 25 mm variable speed
System configuration (high-end)
2 x 1.0 TB 7200 rpm SATA HDDs; DVD-RW SuperMulti ODD 4 GB (2 x 2 GB) 1600 MHz
Environmental requirements
Operating: 3,000 m (10,000 ft)
Non-operating: 9,100 m (30,000 ft)
Vibration
Operating random: 0.5 g (rms), 5-300 Hz
Non-operating random: 2.0 g (rms), 10-500 Hz
Humidity
Above 5,000 ft (1524 m) altitude, maximum operating temperature is de-rated by 1.8° F (1° C) per 1,000 ft (305 m) elevation increase
Maximum altitude
Dynamic (new)
Tool-less
Includes system board and memory information
Processors
Specification
Intel Xeon processor E3-1200 v3 family (Z228/Z1G2)
Intel Xeon processor E3-1241v3, Quad-Core, 8 MB cache, 3.5 GHz, up to 3.9 GHz with Intel Turbo Boost Technology
Intel Xeon processor E3-1231v3, Quad-Core, 8 MB cache, 3.4 GHz, up to 3.8 GHz with Intel Turbo Boost Technology
Intel Xeon processor E3-1226v3, Quad-Core, 8 MB cache, 3.3 GHz, up to 3.7 GHz with Intel Turbo Boost Technology
4th generation Intel Core processor family
Intel Core i7-4790 processor, Quad-Core, 8 MB cache, 3.6 GHz, up to 4.0 GHz with Intel Turbo Boost Technology
Intel Core i5-4590 processor, Quad-Core, 6 MB cache, 3.3 GHz, up to 3.7 GHz with Intel Turbo Boost Technology
Intel Core i3-4160 processor, Dual-Core, 3 MB cache, 3.6 GHz
Dual Core Intel Pentium Processors (Z228)
Intel Pentium G3240 processor, Dual-Core, 3 MB cache, 3.1 GHz
Storage/Hard Drives
Hard Drive Controllers
Specification
Integrated SATA Controller (Z228)
Integrated SATA Controller, RAID 0,1 supported: 5 x 6 Gb/s ports
Factory integrated RAID on motherboard for SATA drives
RAID 0 Configuration – Striped Array
RAID 1 Configuration – Mirrored Array
Graphics
CTO
Specification
DDR3-1600 nECC Unbuffered DIMMs CTO
HP 32 GB (4 x 8 GB) DDR3-1600 nECC RAM
HP 16 GB (2 x 8 GB) DDR3-1600 nECC RAM
HP 16 GB (4 x 4 GB) DDR3-1600 nECC RAM
HP 8 GB (2 x 4 GB) DDR3-1600 nECC RAM
HP 4 GB (1 x 4 GB) DDR3-1600 nECC RAM
DDR3-1600 ECC Unbuffered DIMMs CTO
HP 32 GB (4 x 8 GB) DDR3-1600 ECC RAM
HP 16 GB (2 x 8 GB) DDR3-1600 ECC RAM
HP 16 GB (4 x 4 GB) DDR3-1600 ECC RAM
ECC RAM
HP 8 GB (1 x 8 GB) DDR3-1600 ECC RAM
HP 4 GB (1 x 4 GB) DDR3-1600 ECC RAM
AMO
Specification
DDR3-1600 nECC Unbuffered DIMMs AMO
HP 8 GB (1 x 8 GB) DDR3-1600 non-ECC RAM
DDR3-1600 ECC Unbuffered DIMMs - AMO
Optical and Removable Storage
Networking and Communications
Memory
Specification
Memory expansion slots
4 DDR3 memory slots
Memory type supported
DDR3, UDIMM (Unbuffered), ECC & non-ECC
Memory modes
Non-Interleaved for single channel. Interleaved when both channels are populated.
Memory speed supported
1600 MHz DDR3
Memory protection
ECC available on data
Maximum memory
32 GB
Memory configuration (supported)
4 GB and 8 GB non-ECC, 4 GB and 8 GB ECC unbuffered DIMMs are supported.
ECC and non-ECC memory DIMMs cannot be mixed on the same system.
Supported Drive Interfaces
Specification
SATA
Integrated (5) Serial ATA interfaces (6 Gb/s SATA). One port can optionally be used for eSATA.
RAID 0 and 1 supported. Factory integrated RAID is Microsoft Windows only.
Integrated graphics
Intel HD Graphics 4600 (on Core i5/i7-4xxx processors)
Intel HD Graphics P4600 (on Intel Xeon E3-12x5v3 processors)
Based on Unified Memory Architecture (UMA)- A region of system memory is reserved and dedicated to the graphics display.
Support for Microsoft DirectX 11, OpenGL 4.0 and OpenCL 1.2 on Intel HD Graphics P4600; 3 DP 1.2 graphics ports integrated on motherboard.
Supports up to three simultaneous displays across DP outputs.
Max. resolution supported: 3840 x 2160 at 60Hz
Network controller
Integrated Ethernet PHY Connection I217LM. Management capabilities: WOL, PXE 2.1 and AMT 9.0
Serial
1 rear port
2nd serial
Yes- requires optional Serial Port Adapter Kit
Rear
2 IEEE 1394b (requires optional PCIe 1394b card)
Front
USB 3.0 - 2
USB 2.0 - 2
Rear
USB 3.0 - 2
USB 2.0 - 4
Physical Security and Serviceability
Specification
Access panel
Tool-less, except for the processor heatsink.
Hard drives
Yes
Expansion cards
Yes
Processor socket
Tool-less
Green user touch points
Screw-in
Color-coordinated cables and connectors
Yes
Memory
Yes
System board
Yes
Dual color power and HD LED on front of computer
Consists of an operating system DVD (OSDVD) and a driver DVD (DRDVD). OSDVD restores the original operating system. DRDVD will provide all drivers for the system. The DRDVD may also contain applications that originally shipped with the system for optional installation. Applications can also be obtained from HP.com. OSDVD and DRDVD are orderable with the system and available from HP Support.
Configuration record SW
Yes, causes a fail-safe power off when held for 4 seconds
Over-temp warning on screen
Yes (optional): Locks side cover and secures chassis from theft 0.22-in diameter padlock loop at rear of system
Serial, USB, audio, network, enable/disable port control
Yes, prevents an unauthorized person from changing the workstation configuration
Removable media write/boot control
Yes
Power-on password
Yes
Setup password
A T-15 Torx or flat blade screwdriver is needed to remove the CPU heatsink before the CPU can be removed. CPU removal is tool-less
3.3V aux power LED on system PCA
No
CPUs and heatsinks
Yes, blue (normal), red (fault)
Front power LED
Yes
Front hard drive activity LED
Recovers corrupted system BIOS
Front ODD activity LED
Air cooled forced convection
Internal speaker
80 mm x 80 mm x 25 mm 4-wire PWM (non-serviceable)
System/emergency ROM flash recovery
Not applicable- CPU heatsink is passive
Cooling solutions
92 mm x 92 mm x 25 mm 4-wire PWM (non-serviceable)
Power supply fans
No
CPU heatsink fan
HP PC Hardware Diagnostics (UEFI) enables hardware level testing outside the operating system on many components. The diagnostics can be invoked by pressing F2 at POST, and is available as a download from HP Support.
Chassis fan
No
Memory heatsink fan
Advanced Configuration and Power Management Interface (ACPI). Allows the system to wake from a low power mode and controls system power consumption, making it possible to place individual cards and peripherals in a low-power or powered-off state without affecting other elements of the system
Yes (Default disable)
Access panel key lock
No
ACPI-ready hardware
Requires T15 Torx or flat blade screwdriver
Trusted platform module chip
Yes, rear (all), middle (none), front (none)
Integrated chassis handles
Yes
CMOS battery holder
Standard BIOS 32-bit Service Directory Proposal v0.4
DIMM connectors
Full BIOS support for PCI Express through industry standard interfaces.
BIOS
Specification
BIOS 32-bit Services
BIOS Boot Specification v1.01. Provides more control over how and from what devices the workstation will boot.
PCI 3.0 support
WMI is Microsoft's implementation of Web-Based Enterprise Management (WBEM) for Windows. WMI is fully compliant with the Distributed Management Task Force (DMTF) Common Information Model (CIM) and WBEM specifications.
ATAPI
Users can define a specific day-of-week and time for the system to power on
BBS
Review and customize system configuration settings controlled by the BIOS
WMI support
Recovers system BIOS in corrupted Flash ROM
BIOS power on
Saves BIOS settings to USB flash device in human readable file. Repset.exe utility can then replicate these settings on machines being deployed without entering Computer Configuration Utility (F10 Setup)
ROM Based Computer Setup Utility (F10)
System Management BIOS 2.7.1, for system management information
System/emergency ROM flash recovery with video
Disables the ability to boot from removable media on supported devices
Replicated setup
Alerts management console if memory is removed or changed
SMBIOS
Monitors the temperature state within the chassis.
Three modes:
  • NORMAL - normal temperature ranges
  • ALERTED - excessive temperatures are detected, raises a flag so action can be taken to avoid shutdown or provide for a smoother system shutdown.
  • SHUTDOWN - excessive temperatures are encountered. Automatically shuts down the computer without warning before hardware component damage occurs.
Boot control
Provides secure, fail-safe ROM image management from a central network console.
Updates can be performed before starting the OS. Updates can be periodically scheduled.
Memory change alert
Allows the system to enter and resume from low power modes (sleep states). Enables an operating system to control system power consumption based on the dynamic workload.
Makes it possible to place individual cards and peripherals in a low-power or powered-off state without affecting other elements of the system. Supports ACPI 4.0 for full compatibility with 64-bit operating systems.
Thermal alert
A user-defined string stored in non-volatile memory that is displayed in the BIOS splash screen.
Remote ROM flash
System administrators can power on, restart, and power off a client computer
ACPI (Advanced Configuration and Power Management Interface)
Specification
Ownership tag
Allows for very low power consumption with quick resume time.
Remote wakeup / remote shutdown
Allows a new or existing system to boot over the network and download software, including the operating system.
ASF 2.0 compliant
Reports the system BIOS revision level in Computer Configuration Utility (F10 Setup). Version is available through an industry standard interface (SMBIOS) so that management SW applications can use and report this information.
Instantly available PC (suspend to RAM - ACPI sleep state S3)
Allows management SW to read revision level of the system board. Revision level is digitally encoded into the HW and cannot be modified.
Remote system installation via F12 (PXE 2.1) (remote boot from server)
Assesses system health at boot time with selectable levels of testing.
ROM revision levels
System automatically detects addition of new hardware.
System board revision level
The system can be booted without a keyboard.
Start-up diagnostics (power-on self-test)
Common BIOS image supports System Configuration Utility (F10 Setup) menus in 12 languages with local keyboard mappings.
Auto setup when new hardware installed
The user or IT administrator to set a unique tag string in non-volatile memory.
Keyboard-less operation
Allows I/O slot parameters (option ROM enable/disable) to be configured individually.
Localized ROM setup
Control parameters are set according to detected hardware configuration for optimal acoustics.
Asset tag
(Pre-video) critical errors are reported via beeps and blinks on the power LED.
Pre-slot control
AMT 9.0; Allows workstation status to be monitored on a remote console
Adaptive cooling
Helps to prevent the installation of unauthorized versions of a BIOS (a rogue BIOS) from a virus, malware, or other code that could lead to compromised system security, data access, physical service, or even system board replacement.
Pre-boot diagnostics
A feature in the HP BIOS that prevents changes and/or infections to the Master Boot Record. Useful in protecting from viruses.
Intel Active Management Technology (AMT)
The HP BIOS offers a write-protected boot block ROM that provides recovery from a failed flashing of the computer BIOS. This special recovery mode prevents the system from becoming unusable or “bricked” when a BIOS update is interrupted.
Boot Block Emergency Recovery Mode (BIOS Recovery)
UEFI 2.3.1
