HP Scanjet Enterprise Flow 5000 s3 - LCD Reader
LCD Reader
The LCD Reader is software that outputs the status of the LCD on the scanner front panel to the computer monitor as the LCD changes. The LCD Reader enables accessibility software tools to express what is being shown on the scanner front panel.
The LCD Reader is English-only.
To use the LCD Reader, follow these steps:
  1. On your hard drive, navigate to C:\Program Files\Common Files\HP\Scanjet\, and then to the 5000 s3 directory.
  2. To open the program, double-click hplcd.exe.
The LCD Reader is not able to display the LCD text when there is a USB connection error or the scanner is off.
