HP Products - for and Search - - ABC 123 (Portal H1 24pt)
This document is to be used for document publication testing. The entire document needs to be validated in ALL of the following environments:
  • Latest version of Windows using the latest version of Edge and Internet Explorer, and IE 11
  • Recent release of Mobile Android using latest version of Chrome
  • Latest version of Mac OS using latest version of Safari
  • Recent iOS on Apple mobile device using latest version of Safari
In the title elements above (long and short), "Test Document" is emphasized, "Publication" is marked as user.input, there is a non-breaking space between ABC and 123, a lin break exists after the right parenthesis, and the last item is an inline graphic with a URL and alt text.
XREFs
Click each of the following XREF links to make sure they are working properly. Note any problems or unexpected behaviors.
L1: Normal
Review the following nested lists for proper labeling of list items. The order should present itself as 1. 2. 3. > a. b. c. > i. ii. iii. > i. ii. iii. If not, note this as a problem.
  1. Ordered list item
  2. Ordered list item
  3. Ordered list item
    1. Ordered list item within an ordered list item.
    2. Ordered list item within an ordered list item.
    3. Ordered list item within an ordered list item.
L2: Normal
Paragraph text.
L3: Normal
Paragraph text.
L4: Normal
Paragraph text.
Tests specific to the Portal implementation only
These test are for the Portal only. They validate that certain aspects of the presentation, fonts and tagging are correct.
To validate the H tags for headings, either install a Chrome extension such as H-Tag, or use the browser’s dev tools to inspect the headings.
To validate the fonts, install a Chrome extension that displays in pixels as well as points, such as Font Finder.
The following abbreviations are used in this instruction:
  • HPSL HP Simplified Light
  • HPSR HP Simplified Regular
  • HPSB HP Simplified Bold
Validate other fonts sizes
Validate that the font sizes of the following items are correct. This paragraph should be HPSL 16px.
This note text should be HPSL 16px
This caution text should be HPSL 16px
  warning:
This Warning text should be HPSL 16px
  1. Ordered list item should be HPSL 16px.
    1. Ordered list item within an ordered list item should be HPSL 16px.
L2 should be HPSL 27px
L3 should be HPSL 20px
L4 should be HPSL 18px
Validate video
The video specifications are below:
  1. Validate thumbnail is present and padding, etc., are correct according to the image.
  2. Validate video opens in a modal when clicked and that it plays.
  3. Validate video eyebrow is present and formatted as HP Simplified Bold 14px.
  4. Validate video title is HP Simplified Regular 18px.
  5. Validate video description is present and formatted as HP Simplified Light 18px.
Validate notes, cautions and warnings
The note specifications are below:
Text text text text text text text text text text text text text text text text text text text text text bolded text bolded text bolded text bolded text bolded text bolded text.
  1. Validate padding, etc., are correct according to the image.
  2. Validate the string “NOTE” is blue 006699 HPSR 16px.
  3. Validate the body of the note is HPSL 16px.
The caution/warning specifications are below:
  warning:
  1. Validate that the padding etc., are correct according to the Note specifications.
  2. Validate that the string “Caution” and “Warning” text is red D7410B HPSR 16px.
Validate accordion (expandable) section functionality
The accordion specifications are below:
In the following expandable section:
  1. Validate that the accordion heading is preceded by a + symbol.
  2. Hover over the top-level heading and validate the + symbol changes to blue and that the background changes to grey.
  3. Select the accordion heading and check it opens.
  4. Validate that the open accordion heading is preceded by a X symbol.
  5. Repeat for each heading until they’re all open.
  6. Close each heading in turn and validate that they return to the “closed” condition.
Validate tables on normal monitors (laptop, desktop)
The table specifications are below:
Use the following table to validate formatting.
Table header HPSR 16px
  1. Validate table padding, etc., are correct, according to the specifications.
  2. Validate the table header fonts.
  3. Validate the table copy fonts.
Validate tables on smartphone
The table specifications for mobile are below:
Use the following table to validate formatting on a smartphone.
Validate on Android and iOS.
  2. Validate that the table has wrapped/reformatted correctly.
  3. Validate that the table is functional and that all of it can be viewed.
  4. Validate in both landscape and portrait.
  5. Validate the table header fonts.
  6. Validate the table copy fonts.
