HP 240 G4 Notebook PC Specifications
Product image
Product features
Specification
Windows 8.1 versions
Windows 7 Pro (available through downgrade rights from Windows 8.1 Pro)
FreeDOS 2.0
Processor
Intel Core i5 processor
Intel Core i3 processor
Intel Pentium processor
Intel Celeron processor
Graphics
Integrated Intel HD Graphics
Discrete AMD Radeon R5 M330
Memory
Up to 8 GB
Hard drives
Up to 1 TB
14 in diagonal HD SVA anti-glare flat LED-backlit (1366 x 768)
Keyboard / pointing devices
Full-sized textured black island-style keyboard
Touchpad with multi-touch gestures enabled
Ports
VGA port and HDMI port (for connecting to high-resolution displays)
Audio / multimedia
Audio:
Integrated microphone
Webcam:
Integrated webcam
Wireless connectivity options
Broadcom 802.11b/g/n (1x1) WiFi and Bluetooth 4.0 combo
Realtek 802.11b/g/n (1x1) WiFi and Bluetooth 4.0 combo
Realtek 802.11b/g/n (1x1) Wi-Fi
Product specifications
Operating system (preinstalled)
Windows 8.1 Pro 64*
Windows 8.1 64*
Windows 7 Professional 64 (available through downgrade rights from Windows 8.1 Pro 64)**
FreeDOS 2.0
*Not all features are available in all editions or versions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows functionality.
**This system is preinstalled with Windows 7 Pro software and also comes with a license and media for Windows 8.1 Pro software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data.
Processors
Intel Core i5-5200U with Intel HD Graphics 5500 (2.2 GHz, up to 2.7 GHz with Intel Turbo Boost Technology, 3 MB cache, 2 cores)
Intel Core i3-5010U with Intel HD Graphics 5500 (2.1 GHz, 3 MB cache, 2 cores)
Intel Core i3-4005U with Intel HD Graphics 4400 (1.7 GHz, 3 MB cache, 2 cores)
Intel Pentium N3700 (1.60 GHz, turbo up to 2.40 GHz), 1600MHz/2 MB L2, Quad 6W
Intel Celeron N3050 (1.60 GHZ turbo up to 2.16 GHz) 1600MHz/2 MB L2, Dual 6W
1. Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
Intel SoC (chipset is integrated with processor)
Graphics
Integrated:
  • Intel HD Graphics 5500
  • Intel HD Graphics 4400
  • Intel HD Graphics
Discrete:
  • AMD Radeon R5 M330 (2 GB DDR3 dedicated, switchable)*
HD content required to view HD images.
*Discrete graphics memory uses part of the total system memory for video performance. System memory dedicated to video performance is not available for other use by other programs.
Internal: 14 in diagonal HD* SVA anti-glare flat LED-backlit (1366 x 768)
External: Up to 32-bit per pixel color depth
VGA: Port supports resolutions up to 1920 x 1200 external resolution at 60 Hz
HDMI: v 1.4 supporting up to 1920 x 1080 at 60Hz (HDMI cable sold separately.)
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
*HD content required to view HD images.
Storage and drives
Primary storage bay
  • Supports all 7mm / 9.5 mm, SATA 2.5 in Hard Drives
Hard Drives*
  • 500 GB 5400 rpm SATA Hard Drive
  • 750 GB 5400 rpm SATA Hard Drive
  • 1 TB 5400 rpm SATA Hard Drive
  • 500 GB 7200 rpm SATA Hard Drive
For hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
Optical drives
Fixed optical drive: DVD+/-RW SuperMulti DL Drive
Double-layer discs can store more data than single layer discs. However, double-layer discs burned with this drive may not be compatible with many existing single-layer DVD drives and players. Note that this drive cannot read or write to 2.6 GB single-sided/5.2 GB double-sided – version 1.0 media. Don’t copy copy-right protected materials.
Memory
Standard (Two SODIMM slots)
  • DDR3L - 1600 SDRAM (Transfer rates up to 1600 MT/s)
  • Dual channel support
Memory is non customer accessible / upgradeable
  • 2048 MB (2048 MB x 1)
  • 4096 MB (2048 MB x 2)
  • 4096 MB (4096 MB x 1)
  • 6144 MB (2048 MB x 1 + 4096 MB x 1)
  • 8192 MB (4096 MB x 2)
  • 8192 MB (8192 MB x 1)
Maximum
  • Up to 8 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed.
Networking
Wireless
  • Broadcom 802.11b/g/n (1x1) WiFi and Bluetooth 4.0 Combo
  • Realtek 802.11b/g/n (1x1) WiFi and Bluetooth 4.0 Combo
  • Realtek 802.11b/g/n (1x1) Wi-Fi
  • Intel Dual Band Wireless-AC 3160 802.11a/b/g/n/ac (1x1) WiFi and Bluetooth 4.0 Combo (for Brazil RCTO only)
Compatible with Miracast-certified devices (Windows 8.1)
Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited.
Sold separately or as an optional features.
Communications
Realtek Ethernet (10/100) NIC
Realtek Ethernet (10/100/1000) NIC (On select models)
Audio
DTS Sound+
Dual speakers
Single digital microphone
Multimedia
VGA Webcam (select models):
640 x 480 by 24 frames per second
HD* camera - Fixed (no tilt) (select models)
1280 x 720 by 30 frames per second
Internet access required
Keyboards / pointing devices / buttons and function keys
Touchpad with multi-touch gestures enabled. (Taps enabled as default. Default on for 2-finger scroll and pinch.)
Ports / slots
USB 3.0 - 1
USB 2.0 - 2
VGA - 1
HDMI - 1
headphone/line-out - 1
microphone/line-in - 1
AC power - 1
RJ-45 - 1
Digital media slots: supports SD/SDHC/SDXC, supports mini versions with adapter
Software and Security
Preinstalled
Buy Office
Cyberlink Power DVD (Available on select models)
CyberLink Media Suite
CyberLink Power2Go
HP Connected Photo
Security
Firmware TPM* (Available on select models)
Security Lock slot (Lock sold separately)
*Requires Windows 8.1
Power
Power supply
HP 45 W Smart AC adapter (UMA SKU)
HP 65 W Smart AC adapter (Discrete SKU)
HP 65 W EM Smart AC adapter (China and India)
Primary batter
3-cell, 31 WHr Li-ion
4-cell, 41 WHr Li-ion
Power conservation
Hibernation
Standby
ACPI compliance
Physical specifications
Non-Touch: starting at 1.9 kg (4.19 lb) (Weight will vary by configuration)
Dimensions (W x D x H)
Non-Touch: 34.54 x 24.15 x 2.39 cm (13.59 x 9.51 x .09 in)
