HP LaserJet Enterprise M604, M605, M606 - Clear paper jams in the 5-bin mailbox
Use the following procedure to check for paper in all possible jam locations in the 5-bin mailbox. When a jam occurs, the control panel displays an animation that assists in clearing the jam.
  1. Remove any paper from the output bins.
    Figure : Remove paper from the output bins
  2. On the back of the 5-bin mailbox, open the jam-access door.
    Figure : Open the rear door
  3. If the paper is jammed at the top of the 5-bin mailbox, pull it straight down to remove it.
    Figure : Remove the jammed paper
  4. If the paper is jammed at the bottom of the 5-bin mailbox, open the rear output bin, and then pull straight up on the paper to remove it.
  5. Close the jam-access door and the rear output bin.
    Figure : Close the rear doors
