HP DeskJet 2130 Printers - Blinking Lights
This document is for HP DeskJet 2130, 2131, 2132, 2134, 2136, DeskJet Ink Advantage 2134, 2135, 2136, and 2138 All-in-One printers.
The following sections describe the most common errors indicated by combinations of blinking (flashing) lights displayed on the control panel, followed by solutions for each combination. Find the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
    Figure : Printer control panel with descriptions of the buttons and lights
    Image: Printer control panel showing descriptions of the buttons and lights
  1. Cancel button
  2. Resume button and light
  3. Start Copy Black button
  4. Start Copy Color button
  5. Power button and light
  6. Ink Alert light (black)
  7. Ink Alert light (tri-color)
Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
