HP OfficeJet 7510 Printers - Setting Up the Printer Hardware
This document is for the HP OfficeJet 7510 Wide Format All-in-One printers.
To set up a printer for the first time, remove the printer from the box and all package materials, connect the power cable, set control panel preferences, load paper into the input tray, and then install the ink cartridges.
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  2. Remove tape and package materials from inside and outside of the printer.
    Figure : Remove the tape and package materials from inside and outside the printer
    Image: Remove the tape and package materials from inside and outside the printer
  3. Remove the protective film from the printer control panel.
    Make sure you remove all hardware and materials from the box before you discard or recycle the box and package materials.
  4. To install the input tray, line up the input tray extender with the input tray.
  5. Push the input tray extender onto the input tray until it locks into place.
    Figure : Installing the paper tray extender
    Image: Installing the paper tray extender
  6. Place the output tray on top of the input tray extender, and then push the tray forward until it snaps into place.
  7. Install the output tray.
    Figure : Installing the output tray
    Image: Installing the output tray
  8. Raise the scanner lid to remove package materials beneath.
    Figure : Raising the scanner lid
    Image: Raising the scanner lid
  9. Remove all tape and package materials from the scanner glass.
  10. Close the scanner lid.
    Figure : Closing the scanner lid
    Image: Closing the scanner lid
Step 2: Connect the power cord and set your preferences
Plug the printer into a power source, turn on the printer, and then set your preferences.
Do not connect a USB cable at this time. The connection to the computer is set during the driver and software installation.
    Figure : Connect the power cord and power supply
    Image: Connect the power cord and power supply
  2. Turn on the printer.
    Figure : Press the power button to turn on the printer
    Image: Press the power button to turn on the printer
  3. To set your preferences on the printer control panel, touch your preferred language, and then touch Continue to confirm your choice.
    Figure : Touching your preferred language on the printer control panel
    Image: Touching your preferred language on the printer control panel
Step 3: Load paper into the input tray
Load plain, U.S. letter or A4 paper into the input tray.
  1. Lift the output tray.
    Figure : Lift the output tray
    Image: Lift the output tray
  2. Slide out the paper-width guides as far as possible.
    Figure : Slide out paper-width guides
    Image: Slide out paper-width guides
  3. Pull out the input tray, and then extend it to the desired paper size.
    Figure : Pull the input tray for desired paper size
    Image: Pull the input tray for desired paper size
  4. Load the stack of paper in portrait orientation with the print-side facing down in the center of the input tray, and then slide the stack forward until it stops.
    Figure : Push in the stack of paper
    Image: Push in the stack of paper
    Do not load paper while the printer is printing. Jams or paper feed issues might occur.
  5. Slide the paper-width guides so that they rest against the stack of paper, and then lower the output tray.
    Do not push the guides in so tightly that they bind against the paper.
      Figure : Adjust the paper-width guides
      Image: Adjust the paper-width guides
    1. Adjust the paper-width guides
    2. Lower the output tray
  6. Pull out the output tray extension, and then lift the paper catch.
    Figure : Pull out the output tray extension
    Image: Pull out the output tray extension
Step 4: Install the ink cartridges
Install the HP ink cartridges that shipped in the box with your printer.
When you first set up the printer, you must install the ink cartridges that shipped in the box. These ink cartridges are labeled SETUP, and they calibrate your printer before the first print job. Failure to install the SETUP ink cartridges during the initial printer setup causes an error.
  1. Open the ink cartridge access door by pulling the edge of the ink cartridge access door forward.
  2. Wait until the carriage is idle and silent before you proceed.
    Figure : Opening the ink cartridge access door
    Image: Opening the ink cartridge access door
  3. Locate the SETUP ink cartridges and remove the tape or other package materials.
    Figure : Removing tape or package materials from the ink cartridges
    Image: Removing tape or package materials from the ink cartridges
  4. Hold the ink cartridge so that the ink cartridge contacts are facing toward the printer.
  5. Slide the new ink cartridge into its slot, and then gently push it forward until it locks into place.
    Make sure that the letter on the ink cartridge matches the letter and colored dot on the ink cartridge slot.
    Figure : Sliding the new ink cartridge into its slot
    Image: Sliding the new ink cartridge into its slot
  6. Repeat these steps to install each ink cartridge.
  7. Close the ink cartridge access door.
    Figure : Closing the ink cartridge access door
    Image: Closing the ink cartridge access door
Your HP printer has been setup and is ready to be connected.
Country: Flag Vietnam
