    We are upgrading our website
HP 285 Pro G1 Microtower Business PC - Overview
Product Description
Product Features
Feature
AMD A78 FCH
Processor
AMD A8-6500B APU with Radeon HD 8570D Graphics (3.5 GHz, 4 MB cache, 4 cores)
AMD A6-6400B APU with Radeon HD 8470D Graphics (3.9 GHz, 1 MB cache, 2 cores)
AMD A6-5400B APU with Radeon HD 7540D Graphics (3.6 GHz, 1 MB cache, 2 cores)
AMD A4-6300B APU with Radeon HD 8370D Graphics (3.7 GHz, 1 MB cache, 2 cores)
AMD A4-5300B APU with Radeon HD 7480D Graphics (3.4 GHz, 1 MB cache, 2 cores)
Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing system required. Performance will vary depending on your hardware and software configurations. AMD’s numbering is not a measurement of higher performance.
Graphics
Integrated: AMD Integrated HD Graphics Varies by Processor
Discrete: AMD Radeon HD 8350 1GB FH PCIe x16 GFX (optional)
HD content required to view HD images.
Memory
Both slots are customer accessible / upgradeable, supports dual channel memory
Form factor:
2GB DDR3-1600 UDIMM (1x2GB)
4GB DDR3-1600 UDIMM (1x4GB)
4GB DDR3-1600 UDIMM (2x2GB) (Dual Channel)
8GB DDR3-1600 UDIMM (2x4GB) (Dual Channel)
Type:
1600MHz DDR3
Maximum:
16 GB
Number of slots:
2 UDIMM
Full availability of 4 GB or more of memory requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3 GB all memory may not be available due to system resource requirements. Memory modules support data transfer rates up to 1600 MT/s; actual data rate is determined by the system’s configured processor. See processor specifications for supported memory data rate.
Storage
Supports SATA 3.5-in 6Gb/s HDDs*
500 GB 7200 RPM SATA Hard Disk Drive
1 TB 7200 RPM SATA Hard Disk Drive
Removable
HP Multi-Format Digital Media Card Reader (optional)
*For hard drives and solid state drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) and 30 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
Fixed optical drives
SuperMulti DVD-RW Drive
DVD-ROM
Optical drives are optional or add on features. Duplication of copyrighted material is strictly prohibited. Actual speeds may vary. Double Layer media compatibility will widely vary with some home DVD players and DVD-ROM drives. Note that DVD-RAM cannot read or write to 2.6GB Single Sided/5.2 Double Sided-Version 1.0 Media.
Audio / multimedia
Integrated Realtek ALC221 High Definition audio (all ports are stereo)
Microphone and Headphone front ports (3.5 mm)
Line-out and Line-in rear port (3.5 mm)
Standard internal speaker
Networking
Ethernet (RJ-45)
Integrated 10/100/1000M Gigabit Ethernet Controller
Wireless*
HP 802.11 b/g/n 1x1 Wireless PCIe (optional)
Wireless cards are optional or add-on features and requires separately purchased wireless access point and internet service. Availability of public wireless access points limited.
Ports
Front I/O ports
USB 2.0 ports - 2
Microphone in - 1
Headphone out - 1
Rear I/O ports
USB 2.0 ports - 2
USB 3.0 ports - 2
RJ45 network connection - 1
Audio Line out - 1
Audio Line in - 1
VGA - 1
Display Port - 1
PS/2 ports (keyboard and mouse) - 2
Serial Port - 1
2nd Serial Port (optional, select countries only) - 1
Parallel (optional, select countries only) - 1
Internal I/O ports
PCIe x 16 - 1
PCIe x 1 - 1
PCI 2.1 - 1
Bays
3.5-in Hard Disc Drive Bay - 2
5.25-in Optical Disc Drive Bay - 1
Keyboards and pointing devices
Universal USB wired Windows 8 keyboard
Universal USB wired optical mouse
HP PS/2 keyboard
HP PS/2 mouse
HP USB mouse
Keyboards and mouse are optional or add-on features.
Service and support
On-site Warranty: One-year (1-1-1) limited warranty delivers, next business day 2 service for parts and labor and includes free telephone support 24 x 7. One-year onsite and labor are not available in all countries. Service offers terms up to 5 years by choosing an optional HP Care Pack.
Terms and conditions may vary by country. Certain restrictions and exclusions apply. Other warranty variations may be offered in your region.
On-site service may be provided pursuant to a service contract between HP and an authorized HP third-party provider, and is not available in certain countries. Global service response times are based on commercially reasonable best effort and may vary by country.
Technical telephone support applies only to HP-configured and third-party HP qualified hardware and software. Toll-free calling and 24 x 7 support may not be available in some countries.
Software Overview
Feature
  • Microsoft Windows 8.1 Pro (64-bit) downgrade to Windows 7 Pro (64-bit)*
  • Microsoft Windows 8.1 Pro (64-bit) downgrade to Windows 7 Pro (32-bit)*
  • Microsoft Windows 8.1 Pro (64-bit)*
  • Microsoft Windows 8.1 (64-bit)*
    Windows 7 Home Basic Edition (32-bit) (China Only)*
  • Microsoft Windows 8.1 for China (64-bit)*
  • Microsoft Windows 8.1 with Bing 2015 (Emerging Markets) (64-bit)*
  • Windows 7 Pro (64-bit)*
  • Windows 7 Pro (32-bit)*
  • Windows 7 Pro (National Academic) (32-bit) *
  • Ubuntu Linux
    For all Preinstalled operating systems HP provides Microsoft WHQL certified (where applicable) drivers on www.hp.com at the time of product announcement.
    *Not all features are available in all editions or versions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows functionality.
Preinstalled (varies by country)
Browser and toolbars
  • Internet Explorer 11
Optical disc drive read / write
  • CyberLink PowerDVD
  • CyberLink Power2Go
Utilities and support
  • HP Recovery Manager
  • HP Support Assistant
  • HP ePrint (driver*)
*Requires an Internet connection to HP web-enabled printer and HP ePrint account registration (for a list of eligible printers, supported documents and image types and other HP ePrint details, see www.hp.com/go/businessmobileprinting
Country: Flag Vietnam
