HP ProDesk 480 G2 Microtower Business PC - Overview
Product description
The HP ProDesk 480 G2 Series offers expandable desktop PC options that meet your everyday business needs with enough room to grow.
Product features
Feature
Intel 8 Series (H81 Express) Chipset
Graphics
Intel HD Graphics on all models (integrated on processor)
  • AMD Radeon HD 8350 (1 GB) FH PCIe x16*
  • AMD Radeon HD 8350 ( 1GB) PCIe x16
  • AMD Radeon HD 8470 (2 GB) FH*
  • AMD Radeon HD 8490 (1 GB) PCIe x16
  • NVIDIA GeForce GT630 (2 GB) FH PCIe x16**
  • NVIDIA NVS 310 x16 1st (no cbl)
  • NVIDIA NVS 315 (1 GB) PCIe x1
  • AMD Radeon R7 240 2GB FH PCIe x16
  • AMD Radeon R9 255 2GB PCIe x16
HD content required to view HD images.
Discrete graphics options cannot be configured with 180W power supply and Quad-Core Processor.
* Available only in China country/region
** Not configurable with 180W PSU
Adapters and cables
HP DMS-59 to Dual DisplayPort Cable
HP DMS-59 to Dual DVI Cable
HP DMS-59 to Dual VGA Cable
HP DisplayPort to DisplayPort Cable
HP DisplayPort to DVI-D Adapter
HP DisplayPort to HDMI Adapter
HP DisplayPort to VGA Adapter
HP Serial Port Adapter
HP Parallel Port Adapter
HP DisplayPort Cable
Storage
SATA Drives:
  • 2 TB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5-in
  • 2 TB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5-in - 2nd hard drive
  • 1 TB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5-in
  • 1 TB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5-in - 2nd hard drive
  • 500 GB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5-in
  • 500 GB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5in - 2nd hard drive
  • 500 GB, 7200 RPM SATA SED, 2.5-in (with 3.5-in adapter when installed in MT)
  • 500 GB, 7200 RPM SATA SED, 2.5-in (with 3.5-in adapter when installed in MT) - 2nd hard drive
Hybrid Drives:
  • 1 TB SATA 6G 2.5-in (8 GB cache) SSHD Drive (with 3.5-in adapter when installed in MT)
  • 1 TB SATA 6G 2.5-in (8 GB cache) SSHD Drive (with 3.5-in adapter when installed in MT) - 2nd hard drive
  • 500 GB SATA 6G 2.5-in (8 GB cache) SSHD Drive (with 3.5-in adapter when installed in MT)
  • 500 GB SATA 6G 2.5-in (8 GB cache) SSHD Drive (with 3.5-in adapter when installed in MT) - 2nd hard drive
  • 500 GB SATA 6G 2.5-in (8 GB cache) SSHD Drive w/caddy
  • 500 GB SATA 6G 2.5-in (8 GB cache) SSHD Drive w/caddy- 2nd hard drive
Solid State Drives:
  • 128 GB SATA 6G 2.5-in SSD (with 3.5-in adapter when installed in MT)
  • 128 GB SATA 6G 2.5-in SSD (with 3.5-in adapter when installed in MT) - 2nd hard drive
  • 128 GB SATA 6G 2.5-in SSD w/caddy
  • 128 GB SATA 6G 2.5-in SSD w/caddy - 2nd hard drive
Self-Encrypting Drive:
  • 500 GB 7200 RPM SATA 2.5 SED HDD
Self-Encrypting Solid State Drives
  • 500 GB 2.5-in FIPS 140-2 Self-Encrypting (SED) Solid State Drive
  • 500 GB 2.5in FIPS 140-2 Self-Encrypting (SED) Solid State Drive - 2nd hard drive
  • 500 GB 2.5-in FIPS 140-2 w/ca Self-Encrypting (SED) Solid State Drive
  • 500 GB 2.5-in FIPS 140-2 w/ca Self-Encrypting (SED) Solid State Drive - 2nd hard drive
  • 256 GB SATA 2.5-in Opal2 Self-Encrypting (SED) Solid State Drive SSD
  • 256 GB SATA 2.5-in Opal2 Self-Encrypting (SED) Solid State Drive - 2nd hard drive
  • 256 GB SATA 2.5-in w/ca Opal2 Self-Encrypting (SED) Solid State Drive
  • 256 GB SATA 2.5-in w/ca Opal2 Self-Encrypting (SED) Solid State Drive - 2nd hard drive
  • 256 GB SATA 2.5-in Self-Encrypting (SED) Solid State Drive (with 3.5-in adapter when installed in MT)
  • 256 GB SATA 2.5-in Self-Encrypting (SED) Solid State Drive (with 3.5-in adapter when installed in MT) - 2nd hard drive
  • 256 GB SATA 2.5-in w/caddy Self-Encrypting (SED) Solid State Drive
  • 256 GB SATA 2.5-in w/caddy Self-Encrypting (SED) Solid State Drive - 2nd hard drive
  • 180 GB SATA 2.5-in Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500)
  • 180 GB SATA 2.5-in Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500) - 2nd hard drive
  • 180 GB SATA 2.5-in Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500) w/caddy
  • 180 GB SATA 2.5-in Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500) w/caddy - 2nd hard drive
  • 128 GB SATA 2.5-in Opal2 Self-Encrypting (SED) Solid State Drive
  • 128 GB SATA 2.5-in Opal2 Self-Encrypting (SED) Solid State Drive- 2nd hard drive
  • 128 GB SATA 2.5-in Opal2 Self-Encrypting (SED) Solid State Drive w/ caddy
  • 128 GB SATA 2.5-in Opal2 Self-Encrypting (SED) Solid State Drive w/ caddy - 2nd hard drive
  • 120 GB SATA 2.5-in Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500)
  • 120 GB SATA 2.5-in Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500) - 2nd hard drive
  • 120 GB SATA 2.5-in Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500) w/ caddy
  • 120 GB SATA 2.5-in Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500) w/ caddy - 2nd hard drive
Frame/Carrier
  • HP Slim Removable SATA HDD Frame/Carrier
Optical Disc Drives
  • Slim DVD-ROM
  • Slim BDXL Blu-ray Writer
  • Slim SuperMulti
Media Card Reader**
  • SD Reader
*For hard drives and solid state drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) and 36 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
**Card sold separately
Memory
Form factor: Microtower
Type: DDR3 non-ECC up to 1600 MT/s
Maximum: 16GB
Number of Slots: 2 DIMM
* For systems configured with more than 3 GB of memory and a 32-bit operating system, all memory may not be available due to system resource requirements. Addressing memory above 4 GB requires a 64-bit operating system. Memory modules support data transfer rates up to 1600 MT/s; actual data rate is determined by the system's configured processor. See processor specifications for supported memory data rate.
Networking / Communications
Ethernet (RJ-45):
  • Realtek RTL8151GH-CG GbE LOM (standard)
  • Intel Ethernet I210-T1 PCIe x1 Gb Network Interface Card (optional)
Wireless*:
  • Intel Dual Band Wireless-N 7260 802.11 a/b/g/n PCI Express (optional)
  • HP WLAN 802.11 a/b/g/n 2x2 Dual Band PCIe x 1 WLAN/Bluetooth Card (optional)
  • Intel 7260 802.11 a/b/g/n PCIe x 1 WLAN Card (optional)
* Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
Audio / Multimedia
  • HD audio with Realtek ALC221 codec (all ports are stereo)
  • DTS Sound+ audio management technology
  • Microphone and headphone front ports (3.5 mm)
  • Line-out and Line-In rear Ports (3.5 mm)
  • Multi-streaming capable
  • Internal speaker (standard)
Keyboards and pointing devices
Keyboard:
  • HP PS/2 Keyboard
  • HP USB Keyboard
  • USB Smart card (CCID) Keyboard
  • HP USB and PS/2 Washable Keyboard
  • HP Wireless Keyboard and mouse combo*
Mice:
  • HP PS/2 Mouse
  • HP USB Mouse
  • HP USB 1000dpi Laser Mouse
  • HP USB and PS/2 Washable Mouse
* Keyboard contains 25% post-consumer recycled plastic material
Software overview
Feature
Operating systems
Preinstalled:
  • Windows 8.1 Pro (64-bit)*
  • Windows 8.1 (64-bit)*
  • Windows 7 Ultimate (32-bit)*
  • Windows 7 Ultimate (64-bit)*
  • Windows 7 Professional (32-bit)*
  • Windows 7 Professional (64-bit)*
  • Windows 7 Professional (32-bit) (available through downgrade rights from Windows 8.1 Pro)**
  • Windows 7 Professional (64-bit) (available through downgrade rights from Windows 8.1 Pro)**
  • Windows 7 Home Premium (32-bit)*
  • Windows 7 Home Premium (64-bit)*
  • Windows 7 Home Basic (32-bit)*
  • FreeDOS 2.0
For all Preinstalled operating systems HP provides Microsoft WHQL certified (where applicable) drivers on www.hp.com at the time of product announcement.
For all Supported operating systems HP performs testing of the OS, and makes available all HP value add software (OS dependent). Certified drivers are made available on www.hp.com within 30 days of product announcement.
* Not all features are available in all editions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows functionality. See http://www.microsoft.com (in English).
** This system is preinstalled with Windows 7 Professional software and also comes with a license and media for Windows 8.1 Pro software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data.
Web Support
  • Windows 7 Enterprise (32-bit or 64-bit)
