HP Designjet Z6800 and Z6600 Printer Series -Use a third-party profile
If you have obtained an ICC profile through means other than using the printer’s built-in profiling software (for instance from an Internet download or a third-party profiling software package), you can install it for use with your printer and paper.
The printer needs to know which paper type the profile corresponds to. First select a paper type from the list of papers that the printer recognizes. When selecting a paper type, try to pick one that resembles your actual paper type as closely as possible. The paper type determines the amount of ink that is used and other basic printing parameters, so making a good choice here is fundamental to achieving good results later on. If you find that you cannot obtain satisfactory results with the profile and paper type that you picked, try selecting different types, and use the one that works best.
If the paper that you are using is not listed, or if you cannot find a paper type that resembles yours closely enough, you can define a new type. See Use non-HP paperUse non-HP paper. The printer then calibrates itself for use with that paper, after which you can return to installing the ICC profile.
After you have selected the paper type, browse to the file that contains the ICC profile to use with your printer and paper. Normally, ICC profile file names end in the extension “.icc” (for International Color Consortium) or “.icm” (for Image Color Matching). The profile is stored in the correct system folder on your computer, and in the printer.
