    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP 350 G2 Notebook PC Specifications
Product image
Product features
Feature
Chipset is integrated with processor
Processors
Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
Graphics
Integrated
  • Integrated UMA Graphics
Switchable Discrete Graphics
  • AMD Radeo R5 M240
  • 2G DDR3 with up to 2 GB of dedicated video memory
  • Internal
    15.6-inch diagonal LED-backlit HD* anti-glare (1366 x 768)
  • External
    Up to 32-bit per pixel color depth
  • VGA
    Port supports resolutions up to 1080p, 1920 x 1080 at 60Hz
  • HDMI**
    1.4 port supports up to 1080p, 1920 x 1080 at 60Hz
* HD content required to view HD images.
**HDMI cable sold separately.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Storage and drives
Hard drives
Support all 7mm/9.5mm, SATA 2.5-inch HDDs
Support for mSATA
Support Intel Smart Response Technology
Accelerometer / HDD protection support
  • 320 GB 5400 rpm SATA
  • 500 GB 5400 rpm SATA
  • 750 GB 5400 rpm SATA
  • 1 TB 5400 rpm SATA
  • 500 GB 7200 rpm SATA
Flash cache
32 GB mSATA*
* Not available with Celeron/Pentium/i3 CPUs.
Optical drives
  • Fixed optical drive
    DVD+/-RW SuperMulti DL* Drive
    Weight saver
* Double-layer discs can store more data than single layer discs. However, double-layer discs burned with this drive may not be compatible with many existing single-layer DVD drives and players. Note that this drive cannot read or write to 2.6 GB single-sided/5.2 GB double-sided – version 1.0 media. Don’t copy copy-right protected materials.
Memory
  • Standard
    DDR3L SDRAM (1600 MHz)
    Two SODIMM slots supporting dual-channel memory
    2048 MB Total System Memory
    4096 MB Total System Memory
    6144 MB Total System Memory
    8192 MB Total System Memory
    16348 MB Total System Memory
  • Maximum
    Upgradeable to 16384 MB with 8192 MB* SODIMMs in slots 1 and 2
  • Dual-channel
    Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed.
* Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB may not all be available due to system resource requirements.
Networking/Communications
Wireless
  • 802.11 b/g/n (1x1) wireless LAN module1,2
  • 802.11 b/g/n (1x1) + Bluetooth 4.0 Combo1,2
  • 802.11 a/b/g/n (2x2) + Bluetooth 4.0 Combo1,2
1. Sold separately or as an optional feature.
2. Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited.
Communications
  • Integrated Ethernet 10/100/1000 NIC
Audio/Multimedia
  • Audio
    DTS Sound
    Two integrated Stereo Speaker
    Headphone/Microphone-in Combo Jack
    Dual digital microphone
  • Webcam
    HP HD* Webcam**
    • Supports videoconferencing and still image capture
    • Improved quality for video streaming and still image capture (1280x720 resolution)
    • Up to 30 frames/sec
    • Fixed focus lens
** Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited.
Keyboards/Pointing Devices/Buttons and Function Keys
  • Keyboard
    Full size island style keyboard
    Spill resistant
  • Touchpad
    Multitouch gestures enabled
    Taps enabled as default
Display specifications
15.6" diagonal LED-backlit HD anti-glare flat (1366 x 768)
Specification
Active area (W x H)
34.4 x 19.4 cm (13.54 x 7.59 in)
Diagonal Size
39.6cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: .252 mm
  • Format: 1366 x 768
  • Configuration: RGB Stripe
Backlight
LED
PPI
101
Viewing angle
  • ±40° Horizontal, +10°/-30° Vertical (minimum)
  • 40/40/30/10 (Left/Right/Down/Up) (minimum)
Ports/slots
Specification
Ports
  • VGA – One
  • HDMI* – One
  • Headphone / Microphone-in combo jack – One
  • RJ-45 (Ethernet) - One
  • AC Smart Pin adapter plug – One
  • Two - USB 3.0 on one side
  • One - USB 2.0 on other side
Slots
HP Multi-Format Digital Media Reader
  • Support SD/SDHC/SDXC
  • Push-Push Insertion/Removal
Storage and drives
500GB* 7200 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum) 300MB/s (Drive Capability)
Seek time (typical reads, including settling)
  • Single Track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
976,773,168
Operating temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA security
1TB 5400 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.254 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Single Track: 3 ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Features
ATA security
750GB* 5400 rpm SATA Hard Drive
Specification
Drive weight
101 g (0.22 lb)
Capacity
750GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
1,465,149,168
Features
ATA security
500GB* 5400 rpm SATA Hard Drive
Specification
Drive weight
101 g (0.22 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Synchronous (maximum) 150MB/s (Drive Capability)
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
320GB* 5400 rpm SATA Hard Drive
Specification
Drive weight
101 g (0.22 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
625,142,448
Features
ATA security
* For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
Optical drive specifications
DVD+/-RW SuperMulti DL Drive
Specification
Access times
Random:
Less than 140 ms CD (typical)
Less than 160 ms DVD (typical)
Max data transfer rate
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 5X DVD-RAM
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
Supported Media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
Supported Media (write)
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
Max Media Capacity (read)
8.5GB
Max Media Capacity (write)
8.5GB
Transport
Tray Loading
Integrated Realtek 10/100/1000 NIC
Specification
Ethernet Features
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mbit/s operation (100BASE-T; IEEE 802.3ab; IEEE 802.3 clauses 21-30) ( Support in RTL8161FH-CG only)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32); configurable
Power Management
  • ACPI compliant - multiple power modes
  • Situation-sensitive features reduce power consumption
  • Advanced link down power saving for reducing link down power consumption
Performance Features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame); Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NIC Device Driver Name
Realtek PCIe FE Ethernet Family Controller
Atheros 802.11b/g/n WiFi Adapter*,**
Specification
Wireless LAN Standards
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency Band
2.402 - 2.482 GHz
Data Rates
  • 802.11b: 1, 2, 5.5, 11Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54Mbps
  • 802.11n: 150Mbps for MCS7
Frequency Support
20 MHz: 2.4 GHz bands
Modulation
  • Direct Sequence Spread Spectrum
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security1
  • Supports 64- and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 5) with Microsoft Windows 7 only
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations
Media Access Protocol
CSMA/CA (Collision Avoidance) with ACK
Network Architecture Models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output Power2
13.5 dBm, minimum
Power Consumption
  • Idle associated: 250 mW avg (CLKREQ enabled)
  • Idle unassociated: 100 mW avg
  • Transmit/Receive channel: 2.0 /1.6 W
Power Management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver Sensitivity3
  • 11b:-88dBm at 11Mbps
  • 11g:-74dBm at 54Mbps
  • 11n:-70dBm at 72Mbps
Antenna type
High efficiency dual antenna with spatial diversity, usually mounted in the display enclosure
Form Factor
PCI-Express Half-MiniCard
4 g
Dimensions
3.3 x 26.65 x 29.85 mm
Operating Voltage
3.3v +/- 9%
Temperature
  • Operating: -10° to 70° C
  • Non-operating: -40° to 80° C
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 0 to 3,048 m (10,000 ft)
  • Non-operating: 0 to 15,240 m (50,000 ft)
LED Activity
Amber LED on-Radio OFF; White LED on-Radio ON
1. Check latest software/driver release for updates on supported security features.
2. Maximum output power may vary by country according to local regulations.
3. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
WLAN supplier's client utility is required for Cisco Compatible Extensions support with Microsoft Windows XP. WLAN may also be compatible with certain third-party software supplicants. WLAN supplier IHV extensions required for Cisco Compatible Extensions support for Microsoft Windows Vista and Win7.
* Wireless access point and internet service required. Availability of public wireless access points limited.
** Sold separately or as an optional add-on feature.
Ralink 802.11b/g/n Bluetooth 4.0 Combo Card*, **
Specification
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency Band
2.402 – 2.482 GHz
Data Rates
Modulation
Security1
  • Supports 64- and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST, WAPI
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 5) with Microsoft Windows Vista and XP only
Sub-channels
Roaming
Output Power (for CCK)2
13.5dBm, minimum
Power Consumption
  • Idle unassociated: 150 mW
  • Transmit: 2.0 W (max)
  • Receive: 2.0 W (max)
Power Management
  • 11b:-88 dBm at 11Mbps
  • 11g:-74 dBm at 54Mbps
  • 11n:-70 dBm at 72Mbps
Antenna type
High efficiency dual antenna with spatial diversity, mounted in the display enclosure
Form Factor
PCI-Express Half-MiniCard v1.2
6 g
Dimensions
Operating Voltage
3.3v +/- 10%
Temperature
  • Operating: -10° to 65° C (14° to 149° F)
  • Non-operating: -40° to 80° C (-40° to 176° F)
Humidity
Altitude
LED Activity
LED Off – Radio OFF; Solid LED On – Radio ON
Bluetooth Specification
V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0
Number of Available Channels
79 (1 MHz) available channels
Data Rates and Throughput
  • 3 Mbps data rate; throughput up to 2.17 Mbps
  • Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
  • Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit Power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power Consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep less than 17 mW
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical Interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth Software Supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link Topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power Management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth Profiles Supported
  • Generic Access Profile (GAP)
  • Service Discovery Application Profile (SDAP)
  • Serial Port Profile (SPP)
  • Dial_Up Networking Profile (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Basic Printing Profile (BPP)
  • Video Distribution Profile (VDP)
  • Audio Video Remote Control Profile (AVRCP)
Broadcom 802.11 a/b/g/n (2x2) with Bluetooth 4.0 combo*, **
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency Band
  • 802.11b/g/n
    • 2.402 – 2.482 GHz
  • 802.11a/n
    • 4.9 - 4.95 GHz (Japan)
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
    • 2.402 - 2.482 GHz
Data Rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54Mbps
  • 802.11n: card will support rates for NSS=1 and NSS=2 for RX and TX for 20 and 40 MHz channels. Short and long guard interval shall be supported.
Modulation
  • BPSK, QPSK, CCK, 16-QAM, 64-QAM
Security1
  • IEEE and WiFi compliant 64/128-bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
  • WAPI
Roaming
Output Power2
  • 2.4G: +13.5dBm minimum
  • 5G: +12dBm minimum
  • Maximum output power must be able to achieve modular regulatory certification with notebooks that have antennas greater than 20cm from the user and peak gain of +3dBi at 2.4GHz and +4dBi at 5GHz
Power Consumption
  • Receive: 1.6 W (max)
  • Idle mode (PSP): 250 mW (WLAN Associated)
  • Idle mode: 100 mW (WLAN unassociated)
  • Radio disabled: 75 mW
Power Management
  • ACPI and PCI Express compliant power management
802.11b
  • -95 dBm (1 Mbps)
  • -93 dBm (2 Mbps)
  • -91 dBm (5.5 Mbps)
  • -88 dBm (11 Mbps)
802.11a/g
  • -90 dBm (6 Mbps)
  • -89 dBm (9 Mbps)
  • -87 dBm (12 Mbps)
  • -85 dBm (18 Mbps)
  • -82 dBm (24 Mbps)
  • -79 dBm (36 Mbps)
  • -76 dBm (48 Mbps)
  • -74 dBm (54 Mbps)
802.11n
  • -69 dBm (72.2 Mbps)
  • -66 dBm (300 Mbps)
Antenna type
  • High efficiency antenna with spatial diversity, mounted in the display enclosure
  • Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications
Form Factor
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Operating Voltage
3.3v +/- 9%
Temperature
  • Operating: -10° to 70° C (14° to 158° F)
Humidity
Altitude
LED Activity
3. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CKK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
Transmit Power
Power Consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
Antenna
Range
Up to 10 m (33 ft)
  • USB 2.0 compliant
Link Topology
Security
Power Management
Certifications
  • FAX Profile (FAX)
Audio/Multimedia
Specification
Audio hardware
Implementation
Realtek ALC3201-GR High Definition audio
Volume controls
Up, down, and mute function keys
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Integrated microphone
Yes
Audio output quality
Frequency response
10 Hz - 22 kHz
Signal to noise ratio
Typical 95 dB FSA (DAC)
Total harmonic distortion
Typical -88 dB FS (DAC)
Noise floor
- 110 dB
Play/Record sampling rate(s)
Up to 192 KHz
DAC
24 bits
ADC
24 bits
Integrated stereo speakers
Power rating
1.5 W
Impedance
4 ohms
Multimedia integrated HD webcam
Up to 30 frames/sec Fixed focus lens
Power
HP 45W Smart AC Adapter
Specification
Input
  • 100 to 240 VAC
  • Input Efficiency: 87% min at 115 VAC
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.7 A at 90 VAC
Output
  • Output power: 65W
  • DC output: 18.5/19.5V
  • Hold-up time: 5 msec at 115 VAC input
  • Output current limit: Less than 11A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
  • Operating temperature: 5° to 35° C (41° to 95° F)
  • Non-operating (storage) temperature: -20° to 85° C (-4° to 185° F)
  • Altitude: 0 to 1,524 m (0 to 5,000 ft)
  • Humidity: 20% to 95%
  • Storage Humidity: 10% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
HP 65W AC Adapter
Specification
Dimensions
10.7 x 4.7 x 3.0 cm (4.21 x 1.85 x 1.18 in)
280 g (0.62 lb)
Input
  • 100 to 240 VAC
Output
  • Output power: 65W
Connector
4-Cell (41 WHr) Lithium-Ion battery
Specification
Cells/type
4-cell Lithium-Ion
Energy temperature
  • Watt-hour capacity: 41 WHr
  • Operating (Charging): 0° to 45° C (32° to 113° F)
  • Operating (Discharging): -10° to 60° C (14° to 140° F)
  • Non-operating: -20° to 60° C (-4° to 140° F)
Battery re-charge time
  • System in OFF or Standby Mode: 2.5 hours
  • System ON: 3 to 5 hours (depending on system power consumption)
  • HP Fast Charge Technology: Charges the battery up to 90% within 90 minutes when system is OFF
System specifications
Specification
Stand-alone power requirements (AC power)
Nominal operating voltage: 18.5/19.5 V
Average operating power: Integrated graphics: TBD
Max operating power: Less than 65 W
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating
  • -20° to 60° C (-4° to 140° F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating:
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR: Select models
  • EPEAT: Registered Silver in United States
  • ICES: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
Physical specifications
Feature
Weights
Starting at 2.30 kg (5.07 lbs)
Weight varies by configuration.
Dimensions (Wx D x H)
26.1 x 38.4 x 2.31 cm (10.28 x 15.12 x .91 in)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components.
Software/OS
Feature
Preinstalled software with Windows operating system
Buy Office
Recovery Manager Installer
Cyberlink Youcam DE
Cyberlink Power DVD (available on select models)
McAfee Internet Security 2013*
Getting Started with Windows 8.1
* Internet access required. First 60 days included. Subscription required for live updates afterwards.
Security
Security lock slot
Fingerprint Reader (select models only)
TPM 1.2
