HP Designjet Z6800 and Z6600 Printer Series - Color drift on area fill edges
Color differences can be seen on the edge of a wide non-printed area. In some specific cases, there may be some color variation that is present when the edge of this area fill is composed of light colors.
To reduce this problem try the following:
  • Rotate the image 90º or 180º.
  • Print in fast and normal modes.
  • Print in unidirectional mode.
  • Add color bars at the sides of the image.
  • Print closer to the right hand side of the printer.
  • Use a special paper preset with more servicing. New presets exist for plain paper, coated, heavyweight coated, super heavyweight coated and high gloss/satin photo paper. In the EWS, go to the Configuration tab, select the Paper management option, and the Show/hide papers tab. From the hidden list of medias, select the one to use by moving it to the visible list and click on Apply button.
Country: Flag Vietnam
