HP Scanjet 5590 scanners - How to scan to email
Use the E-MAIL button to scan documents or pictures and insert them in an e-mail message as an attachment. You must have an Internet connection and a supported e-mail software program.
E-mail a scanned document or picture
  1. Place the original face-down on the scanner glass, as indicated by the reference marks, or face-up in the automatic document feeder (ADF).
  2. Press the E-MAIL button. The HP Solution Center main menu appears.
  3. From the HP Solution Center main menu, click Scan Document or Scan Picture.
    Figure : HP Solution Center main menu
  4. The Scanning from the Scan Document button (Solution Center) or the Scanning from the Scan Picture button screen appears.
    Figure : Scanning from the Scan Document button screen
  5. Under the Scan to: option, select E-mail.
  6. Under the File Type: option, select the file format for the attachment.
  7. Click Scan to start the scan.
  8. When you are finished scanning, click Done. Your e-mail program opens and the scanned file is attached to an e-mail message.
  9. The E-mail attachment dialog box appears. Type a file name, and then select a file type.
  10. Click Continue. Follow the on-screen instructions.
  11. Use your e-mail program to complete and send the e-mail.
To view the scanned image before you e-mail it, double-click the attachment in your e-mail software.
