    Apache Log4j Update
HP Notebook - 15-r112nt Product Specifications
Product Name
15-r112nt
Product Number
K1G40EA
Intel Core i5-4210U with Intel HD Graphics 4400 (1.7 GHz, 3 MB cache, 2 cores)
Memory
4 GB 1600 MHz DDR3L SDRAM (1 x 4 GB)
Video Graphics
NVIDIA GeForce 820M (2 GB DDR3 dedicated)
Hard Drive
500 GB 5400 rpm SATA
Multimedia Drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal HD BrightView WLED-backlit (1366 x 768)
Network Card
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth 4.0 combo (Miracast compatible)
Sound
Dual speakers
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing Device
External Ports
1 HDMI
1 headphone/microphone combo
2 USB 2.0
1 USB 3.0
1 RJ-45
Dimensions
37.8 x 25.9 x 2.53 cm
2.23 kg
Power
65 W AC power adapter
4-cell, 41 Wh Li-ion polymer
Camera
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
Operating System:
Windows 8.1 (64 bits)
Security and Support:
McAfee LiveSafe
HP Registration for Windows 8
Getting Started guide with Windows 8
HP Utility Center
HP Recovery Manager (recovery partition, recovery USB/Flash unit creation tool)
Internet Solutions:
Adobe Shockwave Player
CyberLink Media Suite
Evernote
Foxit PhantomPDF Express for HP
Mahjong
Skype
Solitaire
TripAdvisor
7-Zip
