    Apache Log4j Update
HP Pavilion 11-n080ng x360 PC Product Specifications
Product Name
11-n080ng
Product Number
K0W11EA
Intel Celeron N2840 with Intel HD Graphics (2.16 GHz, 1 MB cache, 2 cores)
Memory
4 GB 1600 MHz DDR3L SDRAM (1 x 4 GB)
Video Graphics
Intel HD Graphics
Hard Drive
500 GB 5400 rpm SATA
29.5 cm (11.6") diagonal HD LED-backlit touch screen (1366 x 768)
Network Card
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth 4.0 combo (Miracast compatible)
Sound
Beats Audio with 2 speakers
Keyboard
97% size island-style
Pointing Device
External Ports
1 HDMI
2 USB 2.0
1 USB 3.0
1 RJ-45
Dimensions
30.8 x 21.5 x 2.19 cm
1.4 kg
Power
45 W AC power adapter
2-cell, 29 Wh prismatic
Camera
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Operating System:
Windows 8.1 (64 bits)
Security and Support:
McAfee LiveSafe
HP Registration for Windows 8
Getting Started guide with Windows 8
HP Utility Center
HP Recovery Manager (recovery partition, recovery USB/Flash unit creation tool)
Internet Solutions:
BeatsAudio with SRS 3D
CyberLink PowerDVD
CyberLink YouCam DE
Internet Explorer 11
Windows Live Essentials
7-Zip
