Disabling the Connected Standby option in BIOS causes the Realtek HD audio driver to be displayed as an Unknown Device in Device Manager.
- ${title}
- ${title}
- ${title}
- ${title}
Document ID: c04423228
Version: 1
HP Elite X2 1011 G1 and EliteBook Folio 1020 G1 PCs - When Connected Standby Is Disabled in BIOS, Device Manager Displays Realtek HD Audio Driver as an Unknown Device
Release date : 26-Aug-2014
Last updated : 26-Aug-2014
Affected Platforms:
HP Elite x2 1011 G1
HP EliteBook Folio 1020 Notebook PC
Software:
Realtek HD Audio Driver version 6.0.1.7293
Operating Systems:
- Microsoft Windows 8.1 (Standard)
- Microsoft Windows 8.1 (Pro)
- Microsoft Windows 8.1 (Enterprise)
To resolve this issue perform one (1) of the following procedures:
Procedure 1: Enable
Connected Standby in BIOS setting.
- Power on Computer.
- Immediately press Esc button during startup (Esc button displays the startup menu).
- Press F10, select Advance and choose Device Configurations.
- Scroll down to Connected Standby.
- Check the box to enable Connected Standby.
- Press the F10 key to accept the change.
- Click Yes on the Save Changes screen to exit the BIOS.
- Sign into Windows and open Device Manager.
- Tap or click arrow to expand Sound, video and game controllers.
- Verify Realtek High Definition Audio is displayed correctly.
- Close Device Manager.
Procedure 2: If
Connected Standby is disabled in BIOS, run HP Software Setup to reinstall the audio driver.
- On the Start screen, tap or click the Search button to open Search.
- Enter HP Software Setup in the Search field.
- Select HP Software Setup from the results list.
- Tap or click Yes when the User Account Control (UAC) appears.
- The HP Software Setup utility will open.
- Tap or click Hardware Enabling Drivers.
- Locate and select the Realtek HD Audio Driver.
- Tap or click Install.
- Allow the installation process to complete the driver install.
- Tap or click Continue.
- The computer will restart.
- Tap or click Sound, video and game controllers.
Hardware platforms affected :
HP Elite x2 1011 G1, HP EliteBook Folio 1020 G1 Notebook PC
Support Communication Cross Reference ID : IA04423228
© Copyright 2021 HP Development Company, L.P.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
