This document provides information about how to resolve common supplies related error messages. It also provides information for ordering replacement cartridges and identifying non-hp cartridges.
- ${title}
- ${title}
- ${title}
- ${title}
HP LaserJet Pro - Troubleshoot 10.xx and Supplies messages
Troubleshooting control panel messages and event codes
The following table lists supplies related control panel messages and event codes for HP LaserJet printers. It also lists descriptions of the codes and the actions recommend to resolve the errors.
note:This document does not contain all of the possible error codes for the HP LaserJet printer. The following table includes only the most common error codes associated with supplies.
Control panel message/Event code
Recommended action
10.0004 Supply Error
10.1004 Supply memory error
There is a communication failure with the imaging drum.
If the error persists, contact HP. Visit www.hp.com/go/support for contact options.
10.000X Supply memory error
10.100X Supply memory error
There is a communication failure with one of the toner cartridges.
In the error code, the "X" indicates which toner cartridge is causing the error:
10.330X
Used (X) supply.
Replace the toner cartridge.
note: note: |
10.700X
The toner cartridge life has passed the Very Low stage
note: |
10.7100
One of the color toner cartridges is at the estimated end of its useful life.
The printer will print only in black.
note: |
10.8100
The black toner cartridge is at the estimated end of its useful life.
The printer will stop printing in black.
note: |
Cartridge is low
The toner cartridge is nearing the estimated end of its useful life.
Ensure that a replacement toner cartridge is available.
note: note: |
Cartridge is very low
The toner cartridge is at the estimated end of its useful life.
note: note: note: |
Cartridge Missing
The toner cartridge is not installed.
Used <color> cartridge is installed
A used supply has been installed. The toner cartridge is most likely a refilled cartridge.
Install a genuine HP toner cartridge.
note: If you believe you purchased a genuine HP supply, visit www.hp.com/go/anticounterfeit to determine if the toner cartridge is a genuine HP cartridge, and learn what to do if it is not a genuine HP cartridge.
Used cartridges installed
Used supplies have been installed. The toner cartridges are most likely refilled cartridges.
Used supplies in use
10.400X
Genuine HP supplies have been installed.
No action is necessary.
This message is for informational purposes only.
10.310X
Non-HP supplies installed
Order supplies
Maintaining the HP LaserJet Pro printer will sometimes require ordering new supplies. See the table below for information about how to order HP LaserJet supplies.
Order supplies and paper
Order through service or support providers
Contact an HP-authorized service or support provider.
Order using the HP Embedded Web Server (EWS)
To access, in a supported Web browser on your computer, enter the printer IP address or host name in the address/URL field. The EWS contains a link to the HP SureSupply Web site, which provides options for purchasing Original HP supplies.
Identify non-HP toner cartridge
Hewlett-Packard Company cannot recommend the use of non-HP toner cartridges, either new or remanufactured.
note:Any damage caused by a non-HP toner cartridge is not covered under the HP warranty and service agreements.
The HP Anti-Counterfeit Information Web site (www.hp.com/go/anticounterfeit) helps to determine if a toner cartridge is a genuine HP cartridge, and what to do if it is not a genuine HP cartridge.
The toner cartridge might not be a genuine HP toner cartridge if you notice the following:
The supplies status page indicates that a non-HP supply is installed.
There are a high number of problems with the toner cartridge.
The cartridge does not look as it usually does (for example, the packaging differs from HP packaging).
note:Instructions for replacing toner cartridges can be found on the printer’s Web page on www.hp.com/go/support.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
