HP Officejet 5740 Printers - An 'Incompatible Print Settings' Message Displays for Borderless Printing
This document is for HP Officejet 5740, 5742, 5744, 5745, and 5746 e-All-in-One printers.
When you select a media type, you see a recommended print quality automatically selected for that type. If you change the print quality setting and it is not supported by the media type, you see an alert icon () at the beginning of the media type.
Not all combinations of print options support borderless printing. The incompatible settings might include media type, paper size, printing on both sides, or output quality. If you receive "Incompatible Print Settings" message when printing from computer, change one or the other of the incompatiable settings to continue printing. You may see an alert icon () at the beginning of the incompatiable option.
For example, you may receive this message if you select Borderless Printing and Maximum dpi as output quality for printing on plain paper. You may change the output quality to Normal to fix this issue.
Country: Flag Vietnam
