Document ID: c04376966
Version: 1
Advisory: HP DreamColor Z24x Professional Display - Factory Default Settings May Result in Slight Color Differences Between Different Displays
Release date : 18-Jul-2014
Last updated : 18-Jul-2014
DESCRIPTION
There may be subtle differences in color rendering between multiple DreamColor Z24x displays when using the factory default color space setting.
sourceInformation
SCOPE
Displays:
RESOLUTION
Minimize color differences between multiple DreamColor Z24x displays by selecting the same pre-calibrated color space (i.e.; BT.709, AdobeRGB or sRGB) on all of the displays where color matching is required.
Enable a pre-calibrated color space as follows:
  1. Press any button on the right side of the front bezel to activate the buttons.
    NOTE: the button labels are displayed on screen and may change depending on the active menu or sub-menu.
  2. Press the bottom button (Open Menu) to open the On-Screen Display (OSD).
  3. Press the Color Space button.
  4. Press the Up button to choose a factory calibrated color space (i.e.; BT.709, AdobeRGB, or sRGB).
  5. Press the Select button.
  6. Repeat for all displays.
Hardware platforms affected : HP DreamColor Z24x Display
Support Communication Cross Reference ID : IA04376966
Country: Flag Vietnam
