    Fix HP Printer issue on macOS
Document ID: c04348922
Version: 1
HP Flexible Thin Client, PLUS Flexible Thin Client Systems - The System Locks-Up After Upgrading From ThinPro4.x or Smart Zero Core4.x to ThinPro50xxx or Smart Zero Core50xxx
Release date : 24-Jun-2014
Last updated : 24-Jun-2014
DESCRIPTION
After upgrading the Thin Client Operating System (OS) to ThinPro50xxx or Smart Zero Core50xxx by Smart Client Services, Auto Update, Easy Update or Thin State, the system locks up after reboot.
SCOPE
Systems:
  • HP t505 Base Model Flexible Thin Client
  • HP t505 Flexible Thin Client
  • HP t510 Base Model Flexible Thin Client
  • HP t510 Flexible Thin Client (ENERGY STAR)
  • HP t610 Base Model Flexible Thin Client
  • HP t610 Flexible Thin Client (ENERGY STAR)
  • HP t610 PLUS Base Model Flexible Thin Client
  • HP t610 PLUS Flexible Thin Client (ENERGY STAR)
  • HP t620 Base Model Flexible Thin Client
  • HP t620 Flexible Thin Client
  • HP t620 Flexible Thin Client (ENERGY STAR)
  • HP t620 Flexible Thin Client (ENERGY STAR) Bundle
  • HP t620 PLUS Base Model Flexible Thin Client
  • HP t620 PLUS Flexible Thin Client (ENERGY STAR)
Operating Systems:
  • HP ThinPro4.x
  • HP Smart Zero Core4.x
RESOLUTION
Prior to upgrading ThinPro4.x or Smart Zero Core 4.x to ThinPro50xxx or Smart Zero Core50xxx, Softpaq SP66784 must be applied. Failure to do so will result in a system lockup after reboot.
To resolve this issue, download the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
ThinPro ThinState Addon (Service Pack) for 4.x
Version: 1.0
Revision: 1
NOTE: A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
To install update for Smart Zero Core4.4.x:
  1. Double click SP66784.
  2. Browse to the folder C:\hptc-addons\ThinState_patch_1.0\softpaq
  3. Copy the file hptc-thinstate-5.0-patch_1.0_i386.deb to C:\Program Files (x86)\Hewlett-Packard\HP Smart Client Service\auto-update\Packages folder.
  4. When the system is turned on or restarted, the patch will be applied.
  5. The client can now be upgraded to ThinPro T6X50xxx.
To install ThinPro4.4.x update files:
  1. Use the installer to deploy files to the server.
  2. Copy the add-on from the appropriate directory to the "/tmp" directory.
  3. On the system to be upgraded, run the command as follows:
    dpkg -i /tmp/hptc-thinstate-5.0-patch_1.0_i386.deb
  4. Restart the affected system.
NOTE: If a system upgrade was performed without the SoftPaq update, the system must be restored via USB. Restore image is available at www.hp.com
Hardware platforms affected : HP t510 Flexible Thin Client
Support Communication Cross Reference ID : IA04348922
