Removing and Replacing the Hard Drive for HP Pavilion 14-v000 Notebook PCs
This document applies to HP Pavilion 14-v000 notebook computers.
Before you begin
  • You need a Phillips head screwdriver, tweezers or needle-nose pliers, and a non-metallic prying tool.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures for the hard drive apply to all configurations of HP Pavilion 14-v000 notebook computers.
Removing the hard drive
Follow the steps in this section to remove the hard drive.
  warning:
Step 1
Remove the battery.
For instructions to remove the battery, see the HP support document, Removing and Replacing the Battery for HP Pavilion 14-v000 Notebook PCs.
Removing the battery
Step 2
Remove the optical drive.
For instructions to remove the optical drive, see the HP support document, Removing and Replacing the Optical Drive for HP Pavilion 14-v000 Notebook PCs.
Removing the optical drive
Step 3
Remove the service cover.
Loosen the two captive Phillips-head screws that secure the service cover to the base enclosure.
Service cover screws
Step 4
Lift and remove the service cover.
Removing the service cover
Step 5
Remove the rear corner covers.
First, on the bottom of the notebook, remove the two rubber feet from the rear corners.
Removing the two rubber feet from the bottom corners
Step 6
Remove the two Phillips-head screws that secure the corner covers to the base enclosure.
Screws that secure the corner covers to the base enclosure
Step 7
Carefully lift the corner covers to disengage the tabs that secure them to the base enclosure and remove.
Lifting and removing the corner covers
Step 8
Remove the top cover.
For instructions to remove the top cover, see the HP support document, Removing and Replacing the Top Cover for HP Pavilion 14-v000 Notebook PCs.
Removing the top cover
Step 9
Remove the USB board.
Carefully and using minimal force, lift up on the locking bar on the connector...
Lifting up on the locking bar on the connector
... to disconnect the USB board ribbon cable from the system board.
Disconnecting the USB board cable from the system board
Step 10
Release the left edge of the USB board from the retention clip...
Lifting the USB board from its retention clip
...and slide the USB board external connectors out of the cut outs in the base enclosure and remove it.
Place the USB board in a static dissipative bag.
Sliding the USB board connectors out of the cut outs in the base enclosure
Step 11
Now, to remove the hard drive, carefully and using minimal force lift the locking bar up on the hard disk drive adapter connector...
Lifting the locking bar on the hard disk drive adapter connector
...and disconnect the hard disk drive adapter ribbon cable from the system board.
Disconnecting the hard disk drive adapter cable from the system board
Step 12
Lift the right edge of the hard disk drive assembly and slide the tabs on the right side of the hard disk drive assembly out of the notches in the base enclosure.
To protect it form electrostatic discharge damage, place the hard drive in a static dissipative bag.
Lifting the hard drive out of the base enclosure
Replacing the hard drive
Follow the steps in this section to replace the hard drive.
Step 1
Insert the tabs on the hard disk drive assembly into the notches in the base enclosure...
Inserting the tabs on the drive assembly into the notches in the base enclosure
...and lower the hard disk drive assembly into position.
Lowering the hard drive into place
Step 2
Carefully insert the hard disk drive adapter ribbon cable into the hard disk drive adapter connector on the system board and press the locking bar down to lock the cable into place.
Reconnecting the hard disk drive adapter ribbon cable
Step 3
Insert the external connectors on the USB board into the cut outs in the base enclosure.
Inserting the connectors into the cut outs on the base enclosure
Step 4
Place the USB board under the retention clip.
Placing the USB board under the retention tab
Step 5
Insert the USB board ribbon cable into the USB board connector on the system board...
Reconnecting the USB ribbon cable
...and press the locking bar down to lock the cable into place.
Pressing the locking bar on the
Step 6
Replace the top cover.
For instructions to replace the top cover, see the HP support document, Removing and Replacing the Top Cover for HP Pavilion 14-v000 Notebook PCs.
Replacing the top cover
Step 7
Replace the corner covers.
Align the corner covers with the base enclosure and press down on the corner covers to secure them into position.
Aligning the corner covers and pressing them into position
Step 8
Replace the two Phillips-head screws that secure the corner covers to the base enclosure.
Corner cover screw locations
Step 9
Replace the two rubber feet onto the rear corners of the base enclosure.
Replacing the rubber feet on the rear corners of the base enclosure
Step 10
Insert the tabs on the rear edge of the service cover into the base enclosure and apply pressure to the service cover to snap it into place.
Replacing the service cover
Step 11
Tighten the two captive Phillips-head screws that secure the service cover to the base enclosure.
Screw locations that secure the service cover to the base enclosure
Step 12
Replace the optical drive.
Replacing the optical drive
Step 13
Replace the battery.
For instructions to replace the battery, see the HP support document, Removing and Replacing the Battery for HP Pavilion 14-v000 Notebook PCs.
Replacing the battery
