    We are upgrading our website
HP Officejet Enterprise Color X555 and HP Officejet Enterprise Color MFP X585/X585 Flow - Install the printer cabinet and stand
This document provides the procedure to install the optional printer cabinet and stand for the HP Officejet Enterprise Color X555 and HP Officejet Enterprise Color MFP X585/X585 Flow.
Figure : Cabinet stand
  1. Press the power button to turn off the product.
    Figure : Turn off product
  2. Disconnect the power cable and either the USB cable or the network ethernet cable from the back of the product.
    Figure : Disconnect cables
  3. Place the product on top of the cabinet stand, and ensure that the posts on the tray assembly securely enter the corresponding slots in the product. If the product includes optional Tray 3, place the product and Tray 3 on top of the cabinet stand.
    Figure : Place the product on top of the cabinet stand
    Hewlett-Packard recommends that two people lift the product to move it.
  4. At the bottom of the cabinet stand, push the stabilizing feet down toward the floor.
    Figure : Push stabilizing feet down
  5. At the back of the product, insert the brace plate tabs into the slots in the bottom of the product, and then let the bottom of the brace swing downward.
    Figure : Install the brace
  6. Install two screws through the bottom of the brace into the cabinet stand.
    Figure : Install brace screws
  7. Insert the support bracket bottom tabs into the cabinet stand.
    Figure : Connect the support bracket
  8. Install four screws to secure the bracket to the cabinet stand.
    Figure : Install bracket screws
  9. Reconnect the power cable and either the USB cable or the network cable to the back of the product.
    Figure : Reconnect the cables
  10. Press the power button to turn on the product.
    Figure : Turn on the product
