Removing and Replacing the Battery for HP Chromebook 11-2000
This document applies to HP Chromebook 11-2000 notebook computers.
Before you begin
  • You need a Phillips head screwdriver, tweezers or needle-nose pliers, and a nonmetallic stick or similar prying tool.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
This video shows how to remove and replace the battery for the HP Chromebook 11-2000.
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations of HP Chromebook 11-2000 notebook computers.
Removing the battery
Follow the steps in this section to remove the battery.
  warning:
Step 1
Remove the top cover.
For instructions to remove the top cover, see the HP support document, Remove and Replace the Top Cover for HP Chromebook 11-2000.
Removing the top cover
Step 2
Remove the six screws that secure the battery to the base enclosure.
The six screw locations securing the battery to the base enclosure
Step 3
Lift the battery off the alignment pins and remove it from the base enclosure.
Removing the battery from the base enclosure
Replacing the battery
Use the steps in this section to replace the battery.
Step 1
Place the battery on the alignment pins on the base enclosure.
Placing the battery on the alignment pins
Step 2
Replace the six screws that secure the battery to the base enclosure.
Step 3
Replace the top cover.
For instructions to replace the top cover, see the HP support document, Remove and Replace the Top Cover for HP Chromebook 11-2000 .
Replacing the top cover
Country: Flag Vietnam
