Document ID: c04222551
Version: 1
HP EliteBook Revolve 810 Convertible Tablet Notebook PCs - Nonresponsive Touchpad and Keyboard in McAfee Endpoint Encryption Logon Environment
Release date : 01-Apr-2014
Last updated : 01-Apr-2014
DESCRIPTION
The following symptoms may occur after restarting the computer:
  • The touchpad does not respond in the McAfee preboot authentication environment.
  • The cursor may move erratically around the screen or move to the LCD screen's upper right corner.
  • The keyboard keys do not respond when pressed.
This does not occur when a physical keyboard and mouse are used when the computer is powering on.
SCOPE
Computer:
  • HP EliteBook Revolve 810 G1 Convertible Tablet
Operating Systems:
  • Microsoft Windows 8 Pro
  • Microsoft Windows 7 Professional (64-bit)
McAfee Endpoint Encryption:
  • Version 6.2.1.315
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
HP Notebook System BIOS Update
Version: F.48
A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
Hardware platforms affected : HP EliteBook Revolve 810 G1 Tablet
Operating systems affected : Microsoft Windows 7 Professional (64-bit) (deleted)
Support Communication Cross Reference ID : IA04222551
