    Apache Log4j Update
HP Latex 3000 Printer Series - Maintain the printheads
You should perform an automatic printhead check and clean every morning, before starting to print. While the printer is idle, the components of the ink can precipitate inside the printhead and block the nozzles. The check and clean process pre-cleans the printheads, checks them with the drop detectors, and cleans them further if necessary. It takes between 10 and 30 minutes, depending on the condition of the printheads.
To maintain the best print quality, replace a printhead when it reaches its expiration date. An alert notifies you when any printhead reaches its expiration date.
You can also check a printhead's expiration date at any time: see Printer status and alertsPrinter status and alerts.
Printheads should be aligned from time to time: see Align the printheadsAlign the printheads.
If you remove an unexpired printhead from the printer, planning to reuse it later, the best way to protect it is by replacing the protective caps that you removed before inserting it into the printer.
It is important to use the HP Latex Optimizer sealing cap for the HP Latex Optimizer printhead.
