    Windows 11 Upgrade Guide
HP Latex 3000 Printer Series - New printhead is rejected
If the printer will not accept a new printhead, try the following steps in sequence:
  1. Ensure that the printhead was correctly stored in its orange cap.
  2. Ensure that the electrical contacts are clean.
  3. Run the primer system diagnostic.
  4. Exchange the printhead with the printhead of the same color in the other row.
  5. Assume that the printhead is faulty, and try another one.
  6. If no printhead works in that slot, call your service representative.
